Howard Jones
I know this has been discussed in the past, so in order to get this info all in one place and into the search function what would be the most current, 4/9/18, BEST and strongest hubs to use on a track use SLC. I need to replace all four corners ASAP.
First a few questions:
1. What year and model are the OEM direct replacement parts. Front and then rear.
2. I know the rears have a important factor that relates to the spline count of the stub axle. What is the required spline count and which model/ year corvette is this used on.
3. Please provide any source information that would be useful such as links to vendors.
4. Also add any good experience as to assembly/disassembly process, torque values, etc. and pictures you might have.
Thanks in advance, Howard
