registering a gt40 in Australia
Good day, I'm just starting to go through rego on my DRB. The engineer requires me to fit a Brake pressure fail warning light. I just can't find anything online regarding some form of fitting. the only thing I've tried is the VW type pressure switch that as am told can also do pressure fail. after following wiring diagrams. the brake pressure fail light lights up when the ignition is turned on and only goes out when the brake is depressed.
Has anyone got a better system or know how I can solve the VW one?
Cheers.
Brake Proportioning Valve - Holdenpaedia
not sure if it will work for your situation, but it mounts spate to the master cylinder and has a sliding switch internally
