| Re: High speed lift problem Two ideas. A small 3/8in splitter at leading edge of nose,attached to tub,perpendicular to tub may spoil lift and a slightly higher rear spoiler may help. An inch higher ride height in the rear than the front may help as well. John Allen's book goes into the various things that were tried. You have to be very careful. You should consult with mfg. of your car and someone who races a car exactly the same as yours and test before you lock anything down. |
