| Re: BRM Wheels A possible new source. OK CAV,
I better abandon my ideas if you can produce fully machined, heat treated and race tested BRMs.
Can you supply me with two sets with unmachined pin drive holes and guarantee specification sheets?
Can you produce 14" wide rims @ 15" diameter and can you vary the in/out sets as well.
I have been inundated with private mails showing provisional order interest because of my insistence of the very best specification of materials and machining from the foundry and racing wheel rim manufacturer and a sensible projected costing and guaranteed availability if i go ahead with production. Our construction is two piece, back welded, crack tested and lighter than the currently available rims (if you can get them).
Please reply ASAP as you have a potential large order from around the world ONLY if your specifications are sound as i, for one, will be running these wheels on the limit in our racing programme here in UK and my life depends on their strength.Others will want to know this too.
GTA/Gulf Racing. |
