Old 01-31-02, 07:20 PM   #6 (permalink)
Gold Supporter
Rep Power: 8 Mark Sibley is on a distinguished road
Re: GT40 replicas for sale / Parts / Upgrades
Hi Cookee, I have many brake upgrade options
If you are using 15" wheels then the choice is down to 4 main options. I can fit 4 pot fronts with larger vented discs, and at the rear either larger single pot caliper with handbrake or four pot with separate h/brake.
I can also supply 6 pot fronts. E-Mail me direct for pricing sheet and comparisons. Fuel injection is available for the 302 in the form of weber throttle bodies with injectors of a main rail. With Electronic mapable managements. Or single point F.I. It depends how much you want to spend and appearance. Throttle bodies look good, original, and suit the car. They are easier to install, though throttle is tricky sometimes if you don't get the pull just right. Smoother and better performance will be achieved. Perfect for upgraded engines, just adjust your map. Some of the guys have already gone down this route. Let me know if you want further details. All the best
Mark Sibley
Mark Sibley is offline   Reply With Quote
