Old 15th April 2003, 04:37 AM   #5 (permalink)
Guest
Posts: n/a
Re: CLUTCH ADVISE FORD 302 TO RENAULT
No, the flywheel is not a standard 302 one but an Essex V6 flywheel I beleive. It is part of the standard GTD set up. If you are starting from scratch then the Tornado cast bell housing will allow you to run standard ford 302 items which has its benefits. But if you already have the adapter plate and flywheel etc then it is cheaper to stick with the renault based set up and buy strong components which are now truly tried and tested. Depends on where you are in your build.
Malcolm
