Old 03-10-02, 10:38 AM   #1 (permalink)
Ron Earp's Avatar
Site Administrator
Front panel and holes...
I'm fitting the last of the front panel pieces to my car and found that it looks like some of the holes were improperly cut for pipe access. Check the following photo:
It appears that the access hole for the water pipes is in the exact middle of this panel. However, in the manual the panel is shown with this oval shaped access hole off to one side, where I think it should be.
Can anyone confirm this being the case on their cars? It isn't a big issue to fix, I'll just make another panel or enlarge the hole. However, the oval cuts into a part of the panel where the clutch master is so I think I'd best start over.
Ron
