Old 04-07-05, 09:35 AM   #41 (permalink)
nota2266's Avatar
nota2266
GT40: Kurrajong, Australia
Re: Bolts and washers ?
Very true Paul, you may notice that in an earlier post I said that in some instances I used Mild Steel bolts, this is purely so the bolt can be proofed correctly where using a higher tensile bolt and higher torque to proof the bolt results in damage to the components being fastened. I also use them in some areas where it is better for them to bend rather than break (if you hit something !!)
nota2266 is offline
Old 04-07-05, 10:51 AM   #42 (permalink)
bchildress's Avatar
bchildress
Gold Supporter
GT40: CAV w/Roush 342
Rep Power: 7 bchildress is a name known to all
This has been an interesting running discussion. It is always good to know "reasons behind the methods."
I am in the middle of some suspension work right now and would find it helpful it someone could also give a little discussion about marking paints for nuts and bolts to give a visual indication if the fastener has stayed secure. Are there preferred brands of paint for this purpose?
Bob
bchildress is offline
Old 04-07-05, 01:08 PM   #43 (permalink)
Kalun_D's Avatar
Kalun_D
5 Tenths
GT40: KVA body, scrat
Rep Power: 10 Kalun_D will become famous soon enough
My bad,
I forgot to mention the other two types of lock nuts which unlike nylocs work in high temp areas. .
Split beam. The split-beam locknut has slots in the top, and the thread diameter is undersized in the slotted portion.
Deformed thread. The deformed-thread locknut is a common locknut, particularly in the aerospace industry. The upper locking area is oval shaped.
Kalun_D is offline
