Creep in composites is a well known phenomena that is more or less observable depending on the types of resins used as well as the types and amounts of catalyst used. Composites in general continue to cure for years and years, but some combinations cure more quickly (or completely) than others. Those that cure more slowly or those which have not cured completely enough are more prone to creep and, as noted, the amount of creep is directly proportional to temperature. Bottom line, it can happen with most any composite, but is more likely to happen with unsuitable materials. (The composites used in early "kit cars" were often unsuitable, as I discovered in an Avenger body years ago.)
As an FYI about body storage, the area above my two car garage door was found to be the perfect size to store my front and rear clips. I built a loft over my garage door which had a 36" high opening between its floor and the ceiling and stored the body there while building the chassis.
Lynn
