Old 02-27-08, 12:34 AM   #1 (permalink)
A DOPO
Rep Power: 1 A DOPO is on a distinguished road
Help indentifing left hand shift, left hand drive
I saw a GT 40 kit today that is for sale, but was surprised to see it was left hand drive, and left hand shift on the sill. What's this about? Why that configuration? Yes I am new, and this is my first post, so your help is appreciated.
A DOPO is offline
Old 02-27-08, 01:20 AM   #2 (permalink)
Kalun_D's Avatar
Kalun_D
5 Tenths
GT40: KVA body, scrat
Rep Power: 10 Kalun_D will become famous soon enough
Re: Help indentifing left hand shift, left hand drive
There's 2 basic types of shifter systems. Linkage and cable. Linkage is more or less rigid metal connections from front to back. Cable is just that, flexible sheathed cables between mechanisms front and back.
Cable can be anywhere but linkage usually works better if it's on the sill because it's hard to linkage around the engine when coming from the center. This is probably a linkage type system.
Done properly they are both about the same as far as shift quality. The cable setup is much more flexible as far as routing and placement. Linkage usually entails designing most everything else around where the linkage is best placed.
Kalun_D is offline
Old 02-27-08, 06:51 AM   #3 (permalink)
Brian McCarthy's Avatar
Brian McCarthy
GT40: GTD
Rep Power: 11 Brian McCarthy is a glorious beacon of light
There are at least two GTD with LHD left hand shift that I know of and one of them is mine. I decided to go that route in order to give more room in the cockpit and make installation of the shifter basically a straight shot. Yes it's only a few inches of seat width, but when you are spatially challenged like myself, every inch counts. When all is done, I suspect that a left hand shift is significantly more expensive than a center shift becasue of the chassis mods required and cost of the linkage itself.
Brian
...GTD-40
...LHD-LHS
...302 Roller Block
...R-21
...BRM Pin Drive wheels
...Gulf livery
Brian McCarthy is offline
Old 02-27-08, 09:56 AM   #4 (permalink)
A DOPO
Thanks for the reply, I guess it will take some getting use to shifting with the left hand, but looks like it will work.
A DOPO is offline
Old 02-27-08, 09:57 AM   #5 (permalink)
chuck 1's Avatar
chuck 1
7 Tenths
GT40: CAV
where are you located?
chuck smith
CAV MONO GT40-302
SPF Daytona Coupe- Roush 427r
Kirkham 427 cobra- 427so
chuck 1 is offline
Old 02-27-08, 10:41 AM   #6 (permalink)
Future 40 owner
Rep Power: 2 Future 40 owner is on a distinguished road
That's what i plan to do with mine... (when i finally get it)... it'll be far more straight forward for UK drivers to get used to that set up as we shift with the left hand anyway.
Future 40 owner is offline
Old 02-27-08, 09:00 PM   #7 (permalink)
A DOPO
US, I saw this car in Atlanta, most of the heavy work looked to have been done, needs paint, glass, not sure what he kit is, but the shifter threw me.
A DOPO is offline
