| All GT40 GT40 and Ford GT Talk - All the time! |
3rd April 2012, 04:39 PM
#1 (permalink)
| | nickshelby500kr
| help me identify real or reproduction I have been trying to identify whether this 1966 ford gt40 mkII is a real original production road car, or a reproduction replica model? I only just stumbled upon this forum and figured yall would be the best option to help determine. These are all the photos I have right now. I will have more on april 21st. |
3rd April 2012, 04:53 PM
#2 (permalink)
| | Scott Calabro 10 tenths
Join Date: Oct 2006 Location: Southwick, Ma. GT40: Tornado TS40
| Re: help me identify real or reproduction Spaceframe replica, but would need close up shots of the structure with the front and rear clips open to detemine mfg.
__________________ CF TS40, Coyote, UN1 |
#3 (permalink)
| | Bronze Supporter
| Re: help me identify real or reproduction Hi Nick. The steering wheel is on the wrong side, NACA ducts are closed off and it appears to have a spaceframe chassis, so definitely not an original...
__________________ Classic Car Developments
Scratch built monocoque
351W
ZF |
3rd April 2012, 05:08 PM
#4 (permalink)
Join Date: Nov 2003 Location: Ashford GT40: Dax 40 Mk1 (Rov
| Re: help me identify real or reproduction It also has webers and the Mk2 had dual holley
__________________ DAX GT40. Morgan 3.9 EFi, Worked by John Eales.
Renault Box, Always makes me smile! |
3rd April 2012, 05:50 PM
#5 (permalink)
| | Big-Foot Super Moderator
Join Date: Jan 2007 Location: Kenyon, MN GT40: RCR40 - #45
| Re: help me identify real or reproduction Who told you it was a MK2?
__________________ Regards - Randy
My build site: To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
3rd April 2012, 08:04 PM
#6 (permalink)
| | awatkins Lifetime Premier Supporter
| Re: help me identify real or reproduction Quote:
Originally Posted by nickshelby500kr I have been trying to identify whether this 1966 ford gt40 mkII . | The body shape is that of a Mk I, not a Mk II. |
4th April 2012, 01:34 AM
#7 (permalink)
| Re: help me identify real or reproduction Sorry I only looked at 1 photo and saw the webers so that blew the mk2
4th April 2012, 04:41 AM
#8 (permalink)
| | MikeP 8 Tenths
| Re: help me identify real or reproduction Replica Mk1. The spider is fibreglass and it has the ridge in the spider at the top of the door that originals don't have. Also the tanks are not as per original ie bag tanks in a ribbed steel pontoon.
Mike |
4th April 2012, 05:56 AM
#9 (permalink)
| | Kev Farrington Rookie
Join Date: May 2007 Location: Cheshire UK GT40: KVA/GTD+GTDin p
| Re: help me identify real or reproduction Hi, Cant see it all clearly but the doors make it look like KVA to me and if the rear valence goes straight accross without the up and down cut outs for body hinges seen on most replicas and of course originals then it is out of the later modified moulds and from what I can see of the chassis it must be a C type chassis. Of course I could be wrong and it might even be a one off but I doubt it. Cheers Kev Farrington |
4th April 2012, 08:04 AM
#10 (permalink)
| | Mark Pickford Bronze Supporter
Join Date: Mar 2005 Location: ENGLAND GT40: GT40 Arch Rival
| Re: help me identify real or reproduction Definately MKI Replica.
KVA's don't usually sit that low do they? I mean the rear tyres are snug with the rear clip. Of course this car appears far from set up, but even so.....
Also, those appear to be knock on wheels. How many KVA's have had those fitted out of interest?
It's an interesting find. You buying it??? |
4th April 2012, 08:45 AM
#11 (permalink)
| | Malcolm Gold Supporter
| Re: help me identify real or reproduction Looks like a GTD to me.
__________________ Malcolm
GTD40, Porsche 996 C4S, new MX5 race car project |
4th April 2012, 01:14 PM
#12 (permalink)
| Re: help me identify real or reproduction Its a strange one. I agree with Malcolm if looking at the side and ignoring the door windows. I dont remember any GTDs having mk3 doors but who knows maybe. That ridge running above window height was a GTD mod that Ray Christopher did to keep Ford happy if I remember it correctly. I havent had a good look at the chassis pictures so I`ll do that. Quite a few early KVAs were built up on the then new GTD chassis in the mid to late 1980s but that ridge still bothers me. Someone is going to know exactly what it is and we will all be wrong probably. OK I give up, |
4th April 2012, 02:14 PM
#13 (permalink)
| Re: help me identify real or reproduction Could it be a Dax version?
Looking under the front clip it looks similar to mine with the fibreglass cover removed.d
Also the radius arms seem to go fairly straight forward as opposed to going right in next to the engine. This is another Dax thing
But the body looks like a forty as the Dax has a longer bit below the rear side scoops
6th April 2012, 08:02 AM
#14 (permalink)
| | EGLITOM 10 tenths
Join Date: Sep 2007 Location: Germany GT40: RCR40;LR331;G50
| Re: help me identify real or reproduction Looks like SABRE to me, KVA based from FLorida.
TOM
__________________ RCR EUROPE by S-PERFORMANCE To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
6th April 2012, 11:32 AM
#15 (permalink)
| | allanfeldman 6 Tenths
| Re: help me identify real or reproduction Hi Ian The best visual way to tell a MK I from a MKII is that the MkII has no central Nacar duct in front of the windscreen. The MK I has this feature. Of course the extra side scoops on the rear bodywork and the hinge front panel are other characteristics of the MKII. As for Holleys only one in 1966 for the MKIIA and two in 1967 for The MKIIB.
As I am sure most of you know the KVA features the early ones had no radius on the bottom corner of the windows presumably because Ken Attwell took off all this measures from Ford's own MKIII. Thanks Ken for finally answering the question about the ridge on the GTD.
Regards Allan |
