1965 Mk II - spec
Hi all - looking for a little info on the spec that the Mk II ran at Le Mans in 1965 - any ideas? Did the Mk II run at any other races in 1965?
All help gratefully received...
Hi Tom,
You're obviously referring to GT/106 and GT107 which it appears, only ran at Le Mans in 1965.
A lot of the info you're after is in Ronnie Spain's book.
For detailed spec of the Mk.II, you need to refer to the SAE Papers although I do know that the spec of these cars did change almost daily.
Hi Tom, are you perchance related to Alan?
Pics I have suggest these cars ran wet sumps/pans at Le Mans 65, I have a photo somewhere that I might be able to gleen further info from. IIRC Jay Cushman mentioned in another thread that these two cars (106/107) in that 65 period were in testing / development prior to the SAE MKII papers which include dry sump info.
Charlie Farley
Hello Tom,
What specs are you after ?
I will help you as far as i can, mainly through some contacts i have.
Good to see you pop up here. We last met in the Infield GT40 parking
at The Classic, 2008 ?
And as i recall, you were surprised to see i had brought your Father's Superformance there, resplendent in your Father's old team colours.
Hope to hear from you.
Best
Andrew.
