Go Back   GT40s.com > GT40 Replica Manufacturers' Corner > CAV GT40 Talk
CAV GT40 Talk CAV GT40 discussion sponsored by VIP Classics.
Old 10-15-03, 09:37 PM   #1 (permalink)
GT40: Orlando, Fl
Rep Power: 7 tdm434m is on a distinguished road
CAV project
Hello, everyone, this is my first post on this web site and I'm here because I'm in the process of puchasing a wide body CAV. Being a FE big block fan I plan on putting an aluminum tunnel port with EFI in the car. Now the advice I need, what transaxel with hold up to the HP and torque? Any other advice would be appreciated and if I'm posting in the wrong area please let me know. Thanks Wayne
tdm434m is offline
Old 10-15-03, 11:26 PM   #2 (permalink)
toner's Avatar
toner
8 Tenths
GT40: ex-CAV owner (stolen)
Rep Power: 15 toner will become famous soon enough
Re: CAV project
I don't think a big block will fit in a CAV. Sounds like you really want to build a MkII replica...
toner is offline
Old 10-16-03, 08:21 AM   #3 (permalink)
CCX33911
GT40: Virginia
Re: CAV project
The CAV dealer David Wagner is completing a FE install in a CAV. I can tell you it will definately fit. You can get his phone number off of the www.cavgt.com website for details. Also consult your dealer of choice if this is something you wish to have the dealer involved in, etc.
CCX33911 is offline
Old 10-16-03, 09:31 AM   #4 (permalink)
GT40: Orlando, Fl
Re: CAV project
Thanks for the reply. I know of three CAV cars with FE's installed and hopfully mine will be the fourth. I'm curious about the transaxle, which one will hold up to the torque? A friend of mine here localy builds original trans axles for GT 40's but they are expen$ive.
tdm434m is offline
Old 10-16-03, 09:59 AM   #5 (permalink)
gt40fran's Avatar
gt40fran
Sponsoring Vendor
GT40: Michigan,USA
Rep Power: 41 gt40fran has a brilliant futuregt40fran has a brilliant futuregt40fran has a brilliant future
Re: CAV project
Porsche 930 trans will hold the power and torque
gt40fran is offline
Old 10-16-03, 10:03 AM   #6 (permalink)
llarsen's Avatar
llarsen
GT40: Sabre
Re: CAV project
Wayne, You have hit upon the issue that has been the crux of homebuilt/kit midengine cars since the beginning. There has only ever been one US built production transaxle truly capable of handling the torque of a big block engine: Toranado. In the '70s and '80s there were a number of projects built on the Toranado drive train, but it really doesn't lend itself to the kind of cars you and I would want to build and drive.
You may want to get in touch with Lee Holman as he builds copies of the T44 that was in the MkII. Or at least he tries and also wants big bucks, ~$30K, for one. The last time I talked with Lee he had 3 freshly cast magnesium cases but no one to machine them to accept the gears/shafts etc. If your friend in Orlando is building T44s, you may want to put him in touch with Lee also. (I suspect he is rebuilding ZFs.) There are several transaxles out there that will handle this kind of torque, but none will be cheap: Enco, Hewland, RBT, Ricardo, etc. The RBT was originally in the new Ford GT, but they have chose the Ricardo for production. I am sure that production volume capabilities had as much to do with the decision as anything. Lloyd Butfoy of RBT has been a contributor here and defended his 6spd version of the ZF design quite well. While these are not cheap either, they are probably the most affordable. While I am sure that Lloyd upgrades the basic design, it was able to handle the 500HP/500ft.lb. of the new Ford GT engine.
Good Luck,
Lynn
llarsen is offline
Old 10-16-03, 10:12 AM   #7 (permalink)
gt40fran's Avatar
gt40fran
Sponsoring Vendor
GT40: Michigan,USA
Re: CAV project
There is also a pretty well travelled rumour that Superformance is casting their own cases and building a reproduction T-44 style transaxle.And the price will be significantly less than other sources.....cant wait !!
gt40fran is offline
Old 10-16-03, 11:21 AM   #8 (permalink)
toner's Avatar
toner
8 Tenths
Re: CAV project
I think you'll be on your own with respect to shifter linkage if you go with anything other than one of the transaxles that CAV normally supplies (Getrag or RBT). Unless you can get them one in South Africa ahead of time so they can engineer it properly...
toner is offline
Old 10-16-03, 01:11 PM   #9 (permalink)
MikeDD's Avatar
MikeDD
GT40: DRB
Re: CAV project
Wayne
Just curious...why a wide body with FE?
Sounds like fun, but I assume you know the MK II's
were "normal" width. And now that Chris offers MK II
rear clips, that would be more authentic.
What did the other FE CAV's use for transaxles?
Who furnished the adapters?
MikeD
MikeDD is offline
Old 02-19-04, 11:06 AM   #10 (permalink)
rickchattell
GT40: UK
Rep Power: 7 rickchattell is on a distinguished road
Re: CAV project
Hiya,
You could speak to my old mate Bob Lacey in the states.
He knows everything! 001 858 3423 246
Rick
rickchattell is offline
