Go Back   GT40s.com > GT40 Replica Manufacturers' Corner > CAV GT40 Talk
CAV GT40 Talk CAV GT40 discussion sponsored by VIP Classics.
Old 10-18-06, 09:35 AM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
JCoop's Avatar
JCoop
2 Tenths
GT40: CAVMONO29
Rep Power: 5 JCoop will become famous soon enough
Engines' skewed a bit...
My engine seems to tilt a bit to one side as evidenced by the Weber turkey pan rubbing on 1 side of the clip opening. Would there be any harm, you think, if I installed a couple of washers under the motor mounts and the transaxle mounts on 1 side?
Ray
GT40 CAV Mono29
Cobra SPF #1052
MB CL600 V12
'67 Austin Mini Cooper S
MB E350 4matic (commuter)
Looking for a Cessna Aerobat
JCoop is offline
Old 10-18-06, 04:34 PM   #2 (permalink)
Fatal Attraction's Avatar
Fatal Attraction
GT40: Ex-DRB #35
Re: Engines' skewed a bit...
Ray,
The rubbing that you've noticed is probably due to movement caused by engine torque. Let me guess....left side of the induction opening? Solid or urethane motor mounts should solve the problem.
Ex-Gt40 Australia #35
351W 425HP
TWM 8 stack TBI
MOTEC M4
G50/Quaife LSD
Fatal Attraction is offline
Old 10-18-06, 08:52 PM   #3 (permalink)
JCoop's Avatar
JCoop
2 Tenths
GT40: CAVMONO29
Yup, Bill. LH side...but I DO have solid motor mounts and poly T-axle mounts. Washers may be too small to take the load so maybe I'll cut a length of steel 3/8" thick the size of the mount plate and drilled to fit the 2 bolts that hold it all together...
Ray
GT40 CAV Mono29
Cobra SPF #1052
MB CL600 V12
JCoop is offline
Old 10-19-06, 07:41 AM   #4 (permalink)
Fatal Attraction
GT40: Ex-DRB #35
Ray,
Is anything flexing visibly under acceleration?
Maybe a passenger could take a look, while you're standing on the throttle.
Broken motor mount? Wouldn't be the first time that happened.
How small is the gap between the turkey pan and the f/glass?
351W 425HP
TWM 8 stack TBI
MOTEC M4
G50/Quaife LSD
Old 10-19-06, 08:35 AM   #5 (permalink)
JCoop's Avatar
JCoop
2 Tenths
GT40: CAVMONO29
She's rock steady and only rubs when I open up the clip. I think it may be one of those things that the early CAVs may have had or maybe at engine install (I didn't do the install)...although I've basically redone most everything. It didn't look bad or matter when she had the Holley, but now, there's about a 1" discrepancy between R&L. Here's a shot, and it's right at the corner nearest the lens.
Ray
GT40 CAV Mono29
Cobra SPF #1052
MB CL600 V12
JCoop is offline
Old 10-19-06, 08:42 AM   #6 (permalink)
GT40: New York
Ray have you checked the measurements to confirm that the hole cut in the fiberglass is centered? Are the trumpets level? I would think if the trumpets are level that the engine is level and the problem is in the fiberglass.
Gregg is offline
Old 10-19-06, 09:00 AM   #7 (permalink)
Fatal Attraction
GT40: Ex-DRB #35
Ray,
When I installed my TWM manifold, I had to do a minor "adjustment" on the fiberglass at the rear of the hole, in order to accomodate the fuel rail crossover block. I sanded the radiused edge back from the underside, so not to get into the paint, then touched up the black underneath.
I was thinking that your turkey pan sat underneath the clip, not through it.
Too bad that your pan isn't just a tad more vertical toward the back.
351W 425HP
TWM 8 stack TBI
MOTEC M4
G50/Quaife LSD
Old 10-19-06, 09:45 AM   #8 (permalink)
Chris Liokos's Avatar
Chris Liokos
7 Tenths
GT40: RF40
Rep Power: 14 Chris Liokos will become famous soon enough
Ray,
I’ve noticed that it’s not uncommon for GT40 bodies to have been fitted out of square relative to the chassis (most bodies are not totally symmetrical anyway) so it may not necessarily be the engine that is skewed. The easiest way to check this is to squat down behind the car and compare how each rear wheel lines up with the outer edge of the bodywork (use the tyre tread pattern as a marker). It’s my guess that you will see enough difference to explain your engine location issue. Having said that, the simplest solution may still be to re-locate the engine.
RF40
Chassis No 18
302W
Chris Liokos is offline
Old 10-19-06, 06:17 PM   #9 (permalink)
JCoop's Avatar
JCoop
2 Tenths
GT40: CAVMONO29
Gregg, Being that it's a CAV (turnkey-minus) I would think the hole is centered. The edges are also radiused so I think the hole is in the mold.
I'll have to put the bubble level to the trumpets, I guess. I'll use a frame crossmember as reference.
Ray
GT40 CAV Mono29
Cobra SPF #1052
MB CL600 V12
JCoop is offline
Old 10-19-06, 06:21 PM   #10 (permalink)
JCoop's Avatar
JCoop
2 Tenths
GT40: CAVMONO29
Originally Posted by Fatal Attraction
Ray,
I've done a bit of that adjustment (sanding). Looking at the pan directly from the rear, though shows at least an inch discrepancy. I may just raise the left side a bit with a wedge or washers. I'm just afraid I'd twist things and compromise the integrity of the engine mounting.
Ray
GT40 CAV Mono29
Cobra SPF #1052
MB CL600 V12
JCoop is offline
Old 10-31-06, 08:19 PM   #11 (permalink)
Canuk40's Avatar
Canuk40
Supporting Vendor
GT40: CAV GT
Hi Ray,
The biggest cause of your clearance issues is the Getrag transaxle. It requires the engine to sit higher as the input shaft on the transaxle goes in above the diff rather than below as in the ZF application.
On our 302/347 Weber or 8 Stack EFI units the heat sheild doesn't protrude through the rear deck so no clearance issues.
Of course changing to a ZF is a tiny bit more costly than sanding off some material Car looks fabulous BTW.
Here's a pic of a 347 EFI/ZF sitting at correct height. Sorry I don't have a pic of it with a heat sheild on but you can clearly see how much lower the engine is in the car. Food for thought...
Ian Clark
President
CAV Canada MotorSports Inc.
International: 905 637 9362
cavgtcanada@yahoo.ca
Canuk40 is offline
LinkBacks (?)
LinkBack to this Thread: http://www.gt40s.com/forum/cav-gt40-talk/19562-engines-skewed-bit.html
Posted By For Type Date
GT40s.com This thread Refback 10-18-06 11:18 AM
Similar Threads
5.4L Boss Engines JackW GT40 Wanted - Parts or Services Needed 4 10-19-06 06:19 AM
UK crate engines....... Malcolm GT40 Tech - Engines/Induction/Exhaust 6 02-25-04 10:44 AM
5.4 lt engines fitted to what ? Roaring Forties GT40 Tech - Engines/Induction/Exhaust 18 02-04-04 12:32 PM
New and nearly new engines wbmusarra All GT40 13 06-10-02 11:35 AM
Levy Racing Engines - Driving impressions Roaring Forties All GT40 10 03-21-02 12:30 AM
