Go Back   GT40s.com > GT40 Replica Manufacturers' Corner > DRB GT40s
DRB GT40s Sponsored by DRB Sports Cars.
Old 10-03-08, 11:23 AM   #1 (permalink)
HiFlow
GT40: DRB
Rep Power: 2 HiFlow is on a distinguished road
DRB Chassis #7
Well here's another DRB on the road. Finally registered in South Australia. I think the first one here.
Registered here with standard 5.0L HO 1989 Mustang motor and EEC-IV.
Its taken me a while but finally the project is finished.
You can see in the attached pics that its sitting a little high - this was to keep the minimum 100mm ground clearance, so i pushed it up to about 110mm just to make sure.
ID:	33015   Click image for larger version
HiFlow is offline
Old 10-03-08, 12:21 PM   #2 (permalink)
crossle43's Avatar
crossle43
GT40: RCR40 #27
Rep Power: 9 crossle43 is on a distinguished road
Re: DRB Chassis #7
One more piece of eye-candy for Australia!
Great accomplishment and beautiful color - well done!
Every job is a self-portrait of the person who does it... autograph your work with excellence - unknown
crossle43 is offline
Old 10-15-08, 08:33 AM   #3 (permalink)
greg_drb17's Avatar
greg_drb17
GT40: DRB
Rep Power: 4 greg_drb17 is on a distinguished road
Re: DRB Chassis #7
Hi C
Looks beeaauutiful. what wheels did you get as they look like the ones i have been chasing for my drb17 although in a different colour.
Greg Q
DRB#17
302/G50
Old fan, new fanatic
greg_drb17 is offline
Old 10-15-08, 09:06 AM   #4 (permalink)
flatchat's Avatar
flatchat
7 Tenths
Rep Power: 14 flatchat is just really nice
Re: DRB Chassis #7
Yeah! good job Chris --its almost vintage already--finally, you can go cruisin'. Enjoy!
Greg -- looks like Simmons wheels just like the Orange ones you have
Wheel Range
Ex:- DRB # 17
(GT40 australia)
Our Ford which art in heaven
Hallowed be thy frame.
Now, an Ally mono tub
RCR 70 spyder with a
CHEVY LS6 -- 930 trans
Forever young !
flatchat is offline
Old 10-15-08, 06:51 PM   #5 (permalink)
Pete's Avatar
Pete
GT40: GT40 Australia.
Rep Power: 41 Pete has a brilliant futurePete has a brilliant futurePete has a brilliant future
Re: DRB Chassis #7
Congratulations mate, I like the colour.
Cheers, Pete.
DRB chassis 48.
Queensland Australia.
Pete is offline
Old 10-26-08, 08:14 PM   #6 (permalink)
G Ashman
Rep Power: 3 G Ashman is on a distinguished road
Re: DRB Chassis #7
Hi Chris
Good to see you got it finished. Hopefully mine will get to that stage one day. It looks fantastic in its new paint and will inspire me to get out in the shed and work on mine. Great job. Hope to catch up with you soon.
G Ashman is offline
Old 11-04-08, 08:39 AM   #7 (permalink)
delaneyp's Avatar
delaneyp
Peter D
GT40: DRB #27
Re: DRB Chassis #7
Hi Chris,
Congratulations !! The car looks superb & I love the colour (no bias here !!). Did you end up using that old stock Mustang induction setup for rego ? Any plans to "work" the motor now that you have got rego ?
Now comes the hard part - what to do with your spare time - finish off all those minor outstanding items, or just go for a drive ! 4 years after my rego, I still haven't got around to a professional carpet job, headlining, decent handbrake, etc !!
Kind Regards,
Peter D.
DRB (GT40 Australia) #27
331 Windsor / GD-50
8-Stack EFI / Autronic
Dark Metallic Blue Pearl
delaneyp is offline
Old 11-14-08, 07:05 AM   #8 (permalink)
HiFlow
GT40: DRB
Re: DRB Chassis #7
Hi Guy's,
Thanks for the compliments. I am stoked its finally finished.
To answer some of your questions. The wheels are Simmons, F90 - and I matched the silver stripes over the body to the centre colour of the wheels. A small touch but makes a difference. The colour is from the Nissan 350Z. Simmons have the specs required for the DRB setup. ie required offsets etc.
Peter: yes i did use the manifold you sent me - worked a treat - no questions. Just painted it nice and black to hide anything which may have attracted attention. Well now the manifold comes off and the 8-stack goes on. I have got the Autronic ECU, and thats going on next. What setup did you use on the ignition side? I have an auto elec mate who is putting this together for me now so would be good to know what setup you have? Individual coils? Did you need to put in any additional sensors - ie crank position sensor?
Now i have driven it - i would like to improve the brakes - cant seem to get the f/r bias correct, so may have to go to the tilton setup with balance bar. Need to get the electronics and that sorted first then i can take it out on the track to test it comprehensively.
As for other minor outstanding items, the car needs to be pretty much complete here in South Aust, so i have got basically everything done from interior to hand brake. The only minor thing outstanding is gassing the A/C. I have a leak somewhere and cant find it, so I forsee will be multiple hours sourcing that!
HiFlow is offline
Old 11-14-08, 07:38 AM   #9 (permalink)
delaneyp's Avatar
delaneyp
Peter D
GT40: DRB #27
Re: DRB Chassis #7
Hi Chris,
We had to cut down the dizzy & go with coil-packs because the fronts of the fuel rails ended up in the middle of the dizzy cap ! The rails were run up the middle of the stacks (instead of outside as per standard) on advice from a mate who is an emissions expert. His opinion was that we would get a better burn if the injectors pointed straight at the ports, & I guess he was right - to our knowledge, this is the only 8-stack to ever pass the RTA's IM240 emissions test ! Mind you, it makes everything very hard to get at, so if I wasn't worried about emissions, I would not have bothered.
From memory, there were 2 x toothed rings inserted into the dizzy (one for cam & 1 for crank position, I think), & a flat plate/cover was made up to replace the dizzy cap.
We used 4 x dual coil-packs, so it is effectively a "wasted spark" setup (& cheaper than 8 individual coil-packs, etc). Each coil-pack is fired by an "igniter module", which is in turn triggered by the Autronic ECU.
Hope this helps a bit.
Kind Regards,
Peter D.
331 Windsor / GD-50
delaneyp is offline
Old 11-19-08, 01:50 PM   #10 (permalink)
HiFlow
GT40: DRB
Re: DRB Chassis #7
Thanks Pete - this is good info. I'll pass this onto the my auto elec expert to see what he thinks. My plan atm is to get it going with the Autronic so when i come back to Aust at xmas i can at least drive it around and have some fun.
HiFlow is offline
Similar Threads
D&d Ttr Chassis N#002 ddcobra Vendor and Manufacturer Announcements 36 04-24-07 06:02 PM
NEW RCR CHASSIS gt40fran RCR Forum - RCR40 / RCR70 / P4 / MKIV 4 05-22-05 11:59 PM
GTD CHASSIS AVAILABLE AGAIN Roy_Smart GT40 Parts For Sale 5 06-08-04 01:50 PM
Chassis 111 josvdp GT40 Cars For Sale 8 03-12-03 04:03 AM
GTD chassis gt40fran GT40 Cars For Sale 2 08-05-02 09:53 PM
