Go Back   GT40s.com > >
Thread Tools Display Modes
Old 19th December 2017, 05:18 AM   #141
New Zealand
GT40: New Zealand
Re: Classic Car Developments Chassis #3
Thanks James. And to you and yours too.
Scratch built monocoque
351W, 48 IDAs, ZF DS25-1
brianstewart is offline   Reply With Quote
Old 5th March 2018, 11:10 PM   #142
New Zealand
GT40: New Zealand
John's been busy. Most of the wiring in, brake lines run, and fuel pumps in place.
Classic Car Developments Chassis #3-prog-1-18-jpg
Old 6th March 2018, 04:20 AM   #143
JIMMYMAC's Avatar
JIMMYMAC
GT40: Monocoque
That chassis looks great !!
Hopefully not long now.
James
Festina Lente
GT40 Monocoque, Original MKI Engine & Drivetrain
JIMMYMAC is offline   Reply With Quote
Old 6th March 2018, 06:40 PM   #144
alistair nuttall's Avatar
alistair nuttall
GT40: MONOCOQUE
Looks brilliant Brian, well done mate ,
You will soon have the engine in !!!
alistair nuttall is offline   Reply With Quote
Old 22nd March 2018, 04:12 PM   #145
New Zealand
GT40: New Zealand
Some more progress.
Classic Car Developments Chassis #3-engine-jpg   Classic Car Developments Chassis #3-engine-trans-jpg   Classic Car Developments Chassis #3-starter-jpg
Old 22nd March 2018, 05:05 PM   #146
Doc Watson's Avatar
Doc Watson
GT40: mono Mk I, zf-0
Looking very nice..... isn't that the original chassis colour of the first batch of mono's...and I'm sure you wont mind me reminding you to fix that brake line securing strap on the bottom of the rear hoop. ;-)
Andy
Doc Watson is offline   Reply With Quote
Old 22nd March 2018, 05:46 PM   #147
New Zealand
GT40: New Zealand
Thanks Andy. Yes, original mono colour (or as close as we could get).
Old 22nd March 2018, 06:26 PM   #148
JIMMYMAC's Avatar
JIMMYMAC
GT40: Monocoque
Hard yakka bro but paid off in aces.
Nice one.
James
Festina Lente
Old 29th March 2018, 05:15 AM   #149
New Zealand
GT40: New Zealand
Cooling system coming together. EWP and controller nicely nestled in behind the passenger side bulkhead making for a straightforward connection to the front of the block.
Classic Car Developments Chassis #3-front-pipes-jpg   Classic Car Developments Chassis #3-pump-jpg   Classic Car Developments Chassis #3-location-jpg
Old 4th April 2018, 05:18 PM   #150
New Zealand
GT40: New Zealand
John has all the sensors installed (water temp, oil pressure, oil temp and one for a low oil pressure warning light), and has moved the EWP controller to beside the voltage regulator behind the driver's seat. Makes it more accessible than where it was beside the EWP. (no idea why all the pictures have been flipped in the preview).
Classic Car Developments Chassis #3-senders-jpg   Classic Car Developments Chassis #3-controller-reg-jpg   Classic Car Developments Chassis #3-pump-jpg
Old 4th April 2018, 05:43 PM   #151
jac mac's Avatar
jac mac
I Have No Life
New Zealand
When you use an EWP in conjunction with the modded OE pump housing like that you cannot use either of the 5/8" hose fittings on the OE pump housing as they are now under EWP pump flow direction and due to impellor removal flow will be reverse of what they were with OE pump.
AMGT Rep Steel Mono x Plans, FE328 T44R.
[email protected]
Old 4th April 2018, 05:46 PM   #152
New Zealand
GT40: New Zealand
Thanks Jac. Will pass that on to John.
Old 6th April 2018, 01:53 AM   #153
New Zealand
GT40: New Zealand
Expansion tank on and all plumbed in. Keen for any comment on the setup JacMac. Electronic speedo drive fitted.
Classic Car Developments Chassis #3-tank-jpg   Classic Car Developments Chassis #3-plumbed-jpg   Classic Car Developments Chassis #3-speedo-drive-jpg
Old 6th April 2018, 03:41 AM   #154
jac mac's Avatar
jac mac
I Have No Life
New Zealand
Arrows on drawing show what hot ( red ) and cooled (blue ) flow directions will try to do with that EWP setup you have there. To correct this the hose's from 5/8" fittings on T/Stat and bottom of header tank need to go down to inlet side of EWP and the two redundant 5/8"fittings on old OE pump blocked off.
There is a further possible trap in using that OE pump housing without the impellor in that the pump housing design tends to favour flow to the 1234 bank before 5678 due to internal design which may lead to uneven temps on each bank, This applies more to that early pump & front cover design rather than later rev rotation pump housings.
[email protected]
Old 6th April 2018, 05:52 AM   #155
New Zealand
GT40: New Zealand
Thanks. Will pass that on.
Old 20th April 2018, 12:32 AM   #156
New Zealand
GT40: New Zealand
Things are really starting to tick along now. Webers and headers on.
Classic Car Developments Chassis #3-webers-jpg   Classic Car Developments Chassis #3-headers-jpg
Old 20th April 2018, 06:27 PM   #157
JIMMYMAC's Avatar
JIMMYMAC
GT40: Monocoque
Marvellous Brian.
Looking the part every time.
James
Festina Lente
Old 21st April 2018, 02:26 AM   #158
IanAnderson's Avatar
IanAnderson
GT40: Dax 40 Mk1 (Rov
I remember chatting with you at LMC two years ago and it had stalled and you asked them to finish Andrew’s car first.
His is stunning and I can see why people wait for this company to work on their cars as the detail is fantastic.
I am sure you will be very pleased with the final product.
Keep up the great posts
DAX GT40. Morgan 3.9 EFi, Worked by John Eales.
IanAnderson is offline   Reply With Quote
Old 28th April 2018, 01:05 AM   #159
New Zealand
GT40: New Zealand
Able to spend a little time down in the workshop last week. Carb linakges done. Roundel lights and ID lights fitted.
Right hand fule tank stuffed with foam and strapped in place. Going to cost a bit to fill at 43 litres each side...
Can't believe Carmen wanted me to throw my parent's old electric carving knife out a few years back. Turns out to be the perfect tool for trimming foam to size to fit in the fuel tanks.
Classic Car Developments Chassis #3-link-jpg   Classic Car Developments Chassis #3-lights-jpg   Classic Car Developments Chassis #3-tank-strap-jpg   Classic Car Developments Chassis #3-cutting-jpg
Old 28th April 2018, 04:08 AM   #160
Charlie Farley's Avatar
Charlie Farley
GT40: In Build
In the second photo, its good to see an old Nilfisk vac being put to good use.
Seriously good bit of kit.
Charlie Farley is offline   Reply With Quote
Forum Jump
