Go Back   GT40s.com > >
Thread Tools Display Modes
Old 3rd September 2013, 09:46 AM   #161
MN12's Avatar
MN12
5 Tenths
GT40: FFR 65 Coupe
Re: DRB #5
Bill,
First and foremost it's good to hear you wife is doing well if there is anything you two need don't hesitate to give us a call. It's really good to see you have the GT on the road now I know it has been a long road with ups and downs along the way. I bet it felt great the first time you took her out under her own power.
http://homeschoolcoupe.blogspot.com/
MN12 is offline   Reply With Quote
Old 3rd September 2013, 10:31 AM   #162
wbmusarra's Avatar
wbmusarra
I Have No Life
GT40: DRB#5
Re: DRB #5
Tim,
I know it has been a long time since we got together, but you and I need to do that so you can get that ride. Maybe your wife will even want one. Just name the day and I will be there. Hope you don't mind one that is still in the works so to speak.
DRB#5
351W/408 TWM FI. AFR 205s 930 Porsche LSD
wbmusarra is offline   Reply With Quote
Old 4th September 2013, 11:15 AM   #163
nextstep's Avatar
nextstep
GT40: GT40 MK1-Coyote
Re: DRB #5
Hi Bill,
It certainly switches your priority when someone close gets ill.
Good to hear your wife is doing well! All the best!
Nice to see your car close to completion.
But, it's never really finished is it?
It's the tinkering we all enjoy...
Renato
nextstep is offline   Reply With Quote
Old 4th September 2013, 12:28 PM   #164
Pete's Avatar
Pete
GT40: GT40 Australia.
Re: DRB #5
Hi Bill, I haven't looked in here for awhile, glad your wife is doing well, the car looks fantastic. I just finished reading your story of the coil packs and the broken ring gear. I have coil packs and so far they have worked perfectly touchwood, but now every time I start up it is with trepidation .
Best wishes for you both.
Cheers, Pete.
Queensland Australia.
The power of accurate observation is frequently called cynicism by those who don't have it.
DRB #48
Pete is offline   Reply With Quote
Old 7th March 2014, 11:57 AM   #165
HiFlow
GT40: DRB
Re: DRB #5
Hi Bill,
I dont log on to GT40's.com very often now, so now tat i have I looked up your build log.
I have DRB #7, and have had it registered since 2008. I believe I sent you some drawings and details of the DRB chassis back in 2003, when you first purchased the car from Aust.
I must say your build log is an epic adventure. Its amazing how long a build time takes. Mine took me 12 years (with a 3 year break).
Anyway congratulations on getting the car going.
HiFlow is offline   Reply With Quote
Old 7th March 2014, 04:05 PM   #166
wbmusarra's Avatar
wbmusarra
I Have No Life
GT40: DRB#5
Re: DRB #5
What is it with us DRB guys?? Seems to take forever to build them. You are the first one that has taken longer than me(10years) to get their car on the road. I didn't take a break, just kids that wouldn't let me stick with a budget. I think they call that priorities!!
You do know as Renato stated, you never really finish these cars. I can attest to that. The tinkering does go on forever it seems. I am trying to make sure this winter is the last lay up for mine. There are some updates with mine but not on the build log. More like redo or rebuild!! Go here for more news on DRB#5:
Experiment
I had one stupid mistake(not the first or the last) that really set me back, but I am learning new skills and slowly conquering those frontiers.
Rookie mistake and the concequences
Here is the progress so far after the incident. Still a ways to go. Just waiting for some more packages to arrive.
Paint my Ride
DRB#5
Old 15th January 2018, 02:23 PM   #167
wbmusarra's Avatar
wbmusarra
I Have No Life
GT40: DRB#5
Re: DRB #5
Well guys, I am back into working on the 40 this winter. The car has performed great with minor issues that have been overcome. Lost am alternator belt demonstrating to a buddy the awesome power of the car. Noticed a drop in the voltage which told me right away that the belt was gone. Managed to get to my son's house in Woodstock as the electronics finally gave up the ghost. Had to trailer the car back to the house. An easy repair. Later on the water pump gave up as the seal expanded from a low level post overheat on the way to a show. Replaced the pump with a new pump that was a change in design that allowed the filling process to eliminate all air bubbles.
I am working on the cameras at present as they may be in the beginning stages of failure. The front end issues are fixed. I finally got around to taking it to a front end shop that does race cars and they couldn't align the front end. So a new set of adjustable A arms was fabricated for the car. They are very stout and should hold up to anything I throw at it. Here is the old setup which we found out was the early C-4 setups.
And here is the new setup.
The starter raised its ugly head again. I was getting that nasty grinding noise. Hoped it wasn't the ring gear which it wasn't. This time I checked it out and found a broken collar in the starter itself, which was replaced by the shop in California. The car was starting just as it should,,,,, for about 3 starts. Then the grinding started again. Upon inspection the runout on the starter was around 40 thousants which was allowing the nose gear to move away from the ring gear. Bad news is that the movement allowed for the wearing of the ring gear so much that the nose gear was hitting the edge of the teeth and now just spins freely with no engagement. The guys at the shop did only the repair, and didn't check to see what was causing the broken collar. To do this repair the engine and trans will have to be pulled. The distributor is touching the cross member and tilting the trans up over the rear frame member will destroy it. Really didn't want to disengage the motor mounts. They are a bear to line up.
Well I retired on December of 2016,and had my 72nd birthday in December of last year. Have been having a good time until now.
When I retired my wife has constantly been reminding me that we are now on a fixed income and there wasn't any room for repairs that might come along with the car. So I planned ahead and started working again,,,,, in the movie business. Doing background acting. It doesnot pay well at all, but it keeps me busy with something to do and gives me some money to do things with. Have had some good camera time in several movies. "Kevin probably saves the word", "Valor", "The Front Runner"(Gary Hart's run for the Presidency in the 80s), "The Residents" a series about young doctors during their residencies. This one will probably win Emmys or Golden globes. Very well done. Lots of the movies will be filler types for the networks and you won't recognize any of the stars(least I didn't). Got to work with a few names some that some might recognize, like Queen Latifa, and Hugh Jackman, Have dealt with my brother's passing during the last year and have spend some time repairing and rebuilding his two cars. The Audi A-4 has been sold as it was in terrible shape, and a 72 Olds Cutlass Convertible, being restored for driving only, and will be shipped to my nephew this spring in Sweden. Most of the repairs are to make it functional. Tires, steering wheel and miscellaneous other things like getting the top to go up and down. All is almost done, so just waiting on the weather.
Now to the other part. My age is catching up with me. Bad arthritis in my hands and all the manly things that go with old age. Time is beginning to run out for me, as no one in my family(last generation or this one ) has lasted past 75 yet. I am the most fit of all of them as I exercise regularly and still run 2-4 miles a week, so I am thinking seriously of doing something radical as a final effort with the 40. I am toying with disposing of the entire drive train and converting it to electric. Not to putter around in but to build the fastest 40 on the planet. I have thought it out and should be able to do it and with a little luck, break even on the deal. More to follow.
Here are a few teasers.
The Craziest Electric Vehicles | Translogic - YouTube
This Electric E36 Makes 850 lb/ft of Torque at the Wheels! - /TUNED - YouTube
Electric Factory Five 818 Project - Track Shakedown - EV West / 33 Machine - YouTube
DRB#5
Old 15th January 2018, 03:50 PM   #168
YerDugliness's Avatar
YerDugliness
GT40: 1/24 scale MKII
Re: DRB #5
Nice to see you back around, Bill! I get ya on the whole issue of being in your 70's...I'll turn 70 by the end of the year. I keep telling my friends that the protoplasm may be approaching 70, but the spirit is still 32.
I look forward to what you'll be doing...electric is the way to go for brutal accelleration, I hear, but there's hardly room for an overnight bag in a 40, so I'll be interested in how you manage to get all the batteries in. This is going to be one great build!
Cheers to you!
Doug
YD,E./PNB
Alís RIGHT...Buy American!!!
Retired twice, now back at work, but still attempting to age disgracefully
YerDugliness is offline   Reply With Quote
Old 15th January 2018, 04:39 PM   #169
blueovalz's Avatar
blueovalz
Skinny Man
GT40: An orange car
Re: DRB #5
What is it with you DRB guys?? Seems to take forever to post anything. I'm electrified by the prospect of watching an electric build.
Terry
blueovalz is offline   Reply With Quote
Old 15th January 2018, 05:38 PM   #170
MN12's Avatar
MN12
5 Tenths
GT40: FFR 65 Coupe
Re: DRB #5
Really great to see a post from you Bill. I often wondered how you were doing but then life got busy and I neglected to pick up the phone. Hope you and your wife are both enjoying retirement. Let me know if my 50 year old hands can be of assistance
Old 15th January 2018, 05:42 PM   #171
YerDugliness
Re: DRB #5
Pun intended, I hope!
Cheers to you, Terry!
Doug
YD,E./PNB
Old 15th January 2018, 06:28 PM   #172
blueovalz's Avatar
blueovalz
Skinny Man
GT40: An orange car
Re: DRB #5
Yep. Rock Chalk!
Terry
Old 15th January 2018, 06:49 PM   #173
Ozflyer
GT40: DRB #97
Re: DRB #5
Here ya go Bill..
Electric DRB that I purchased late last year.
All the electrics have been removed now as Iím going the other way with it.
DRB #5-afd0559e-5966-4bba-b519-53646638a957-jpeg   DRB #5-60d8d5f5-8413-4b6a-9b8c-476ec9155512-jpeg
Ozflyer is offline   Reply With Quote
Old 1st February 2018, 09:09 PM   #174
Robert Rauch's Avatar
Robert Rauch
GT40: Project
Re: DRB #5
You guys amaze me.
Robert Rauch is offline   Reply With Quote
Old 16th May 2018, 11:42 AM   #175
wbmusarra's Avatar
wbmusarra
I Have No Life
GT40: DRB#5
Re: DRB #5
Got to doing some cleaning in old files and such. Stumbled across an old pic of my 40 from February 2016, at Coffee and Octane. This is one of the biggest shows probably in the country. They hold it on the 2nd Sunday of each month weather permitting. It is held at Perimeter Mall on I-285. This is probably the 2nd or 3rd largest shopping mall in the state. Usually runs from 8-11 AM, but if you aren't there by 6:30 you won't get a spot. Every parking space is taken up by either Exotics, Classics, Sponsored cars and at least 50 car clubs. Attendance is in the order of 5-10,000 people. The place is wall to wall people.
At any rate, as I was entering and going to park, one of the film crew spotted the car on its entrance and got probably one of the best shots ever taken of my car. So here it is:
This year I made it to both Caffeine and Octane and Caffeine and Exotics(this one you have to submit an application to exhibit). I spotted the listing in "Southeast Wheels" two years ago and decided on a whim to aply. Figured I would be able to show the rejection letter as a good number of that crowd are pretty snobby. Really surprised I got an invite. Met up with Bruce, one of the owners of the event and he turned out to be a really nice guy. While there this year, the film crew approached me to do a feature article for NBC Sports and will be filming in the next few weeks.
DRB#5
Old 16th May 2018, 06:51 PM   #176
Big-Foot's Avatar
Big-Foot
Administrator
GT40: Gulf Cart
Re: DRB #5
Drooling all over my iPad here Bill....
Love the Linden Green!
Regards - Randy
-- Youth and talent are no match for old age and treachery!
GT40 RCR40 #45 G50-331-Weber IDAs ((Sold))
My build site:
Forum Jump
