Old 04-21-05, 06:32 PM   #21 (permalink)
Alastair Ward
GT40: MDA MK1
Re: MDA GT40 MK1 in Wales, UK
A another view of the top cross support.
Alastair Ward is offline
Old 04-21-05, 10:43 PM   #22 (permalink)
aladinsane's Avatar
aladinsane
GT40: Tornado
Good work [img]/ubbthreads/images/graemlins/cool.gif[/img]
Spal fans, in my opinion, are one of the most efficient fans on the market
by moving the most CFM for each given size and depth of fan.
In addition I suggest adding a shroud to optimize the ability of the Spal
fan to move more air thru your radiator.
Just my .02 [img]/ubbthreads/images/graemlins/wink.gif[/img]
aladinsane is offline
Old 04-24-05, 02:39 PM   #23 (permalink)
Hi
I have visited the MDA web forum and see you have a problem with your sway bar and drop links,the setup you show in your pictures does not look at all correct everythig looks too close together,we purchased are sway bars and blades from RallyDesign and made our own drop links.The sway bars are identical to the ones you have but we have cut our blades to the correct length.Have you got the problem sorted out yet.? [img]/ubbthreads/images/graemlins/ooo.gif[/img]
leethac is offline
Old 04-25-05, 08:39 AM   #24 (permalink)
mb1
GT40: Bridgetown
Niiiice. [img]/ubbthreads/images/graemlins/frown.gif[/img]
mb1 is offline
Old 05-12-05, 09:41 PM   #25 (permalink)
Location: I am a Mechanical Engineering Student at UCF.
GT40: Florida , US
are the radius rods on this chassis for anti-squat?
Clay is offline
Old 05-13-05, 02:24 PM   #26 (permalink)
Alastair Ward
GT40: MDA MK1
Clay,
To be honest I haven't a clue! [img]/ubbthreads/images/graemlins/blush.gif[/img]
Maybe some of the more technically minded members on the Forum can give you the answer.
Old 05-20-05, 06:17 AM   #27 (permalink)
Daniel Olofsson's Avatar
Daniel Olofsson
Sweden
GT40: MDA Mk I
Hi Alastair!
I'm wondering about your engine...what kind of a brand does your oil pan have?
I've started measuring and I won't be able to fit my original Ford 302 oil pan, because of the bar under the engine, if you know what I mean. I've started to look after an oil pan that has rear sump.
What I would like to know is, if I you are supposed to use the original oil pan.
Best regards
Daniel
Daniel Olofsson is offline
Old 05-21-05, 04:39 PM   #28 (permalink)
Alastair Ward
GT40: MDA MK1
Daniel,
You have a PM.
Old 05-21-05, 04:44 PM   #29 (permalink)
Alastair Ward
GT40: MDA MK1
I've started to install the main wiring loom and the brake lines. Photo below shows installations, so far, in the engine bay.
I've done 356 hours of build time on her, up to now.
Old 06-02-05, 03:17 AM   #30 (permalink)
Daniel Olofsson
Sweden
GT40: MDA Mk I
Hi Alastair!
I just wonder if you have started working on your handbrakes and especially your cables. I have some troubles with them. If you have some picture on this I would appreciate it a lot if you posted them.
Thanks and best regards
Daniel
Old 06-02-05, 03:44 PM   #31 (permalink)
Alastair Ward
GT40: MDA MK1
Daniel,
I've trial fitted the handbrake lever itself and installed the primary activating cable and wiring through the rear bulkhead. You can just make them out in the above photo.
I'm waiting delivery of my actual rear brake setup, including the handbrake calipers. MDA are working on it just now.
As soon as I install them I will post some photos.
Alastair
Old 06-03-05, 02:39 AM   #32 (permalink)
Daniel Olofsson
Sweden
GT40: MDA Mk I
Ok.
As soon as you get your brake stuff and fit it, please upload the pictures.
Best regards
Daniel
Old 08-04-06, 02:05 PM   #33 (permalink)
Alastair Ward
GT40: MDA MK1
Finally got the HiSpec Engineering rear brake callipers fitted and fully commissioned.
Here are some photos showing my installation.
ID:	14638   Click image for larger version
ID:	14639   Click image for larger version
ID:	14640   Click image for larger version
alastair ward
MDA GT40 Mk1 in build.
Visit my web site at
Old 08-09-06, 06:18 PM   #34 (permalink)
MGNut's Avatar
MGNut
GT40: Sold
Talking What ! road dirt?
OOOHHH that looks goooooood !! Shame to put it on the road, musn't get it dirty!!
That is nice work, credit due.
Turncoat !?
MGNut is offline
Old 08-11-06, 02:03 PM   #35 (permalink)
Alastair Ward
GT40: MDA MK1
Here's another couple of photos of my rear braking system.
ID:	14733   Click image for larger version
ID:	14734   Click image for larger version
ID:	14735   Click image for larger version
alastair ward
Old 08-11-06, 02:11 PM   #36 (permalink)
Alastair Ward
GT40: MDA MK1
Some photos of my front bulkhead installation.
ID:	14738   Click image for larger version
ID:	14739   Click image for larger version
ID:	14741   Click image for larger version
alastair ward
Old 08-11-06, 02:15 PM   #37 (permalink)
Keith1's Avatar
Keith1
GT40: Nine
Hey Alistair, you have been busy! Ain't getting in front of you with those air horns mate..
Keith1 is offline
Old 08-12-06, 07:31 AM   #38 (permalink)
Alastair Ward
GT40: MDA MK1
Front bulkhead build up
Another couple of photos of the front bulkhead.
ID:	14744   Click image for larger version
ID:	14745   Click image for larger version
alastair ward
Old 08-12-06, 07:33 AM   #39 (permalink)
Alastair Ward
GT40: MDA MK1
Fuel pumps etc.
Some photos of my fuel pump installation.
ID:	14747   Click image for larger version
alastair ward
Old 08-12-06, 07:34 AM   #40 (permalink)
Alastair Ward
GT40: MDA MK1
Wheels and tyres
A couple of photos of my wheels and tyres which are:-
Wheels: Jongbloed Aluminium Alloy 3 piece 16" Knock-On, Pin Drive, BRM Replica, 8" wide fronts and 10" wide rears.
Tyres: KUMO EXSTA SUPRA, 225/50 ZR16 and 255/50ZR16
ID:	14752   Click image for larger version
alastair ward
