Old 04-21-07, 11:19 AM   #61 (permalink)
brettmcc's Avatar
brettmcc
GT40: RSGTD
Re: Brett's RS GTD
Well after spending two hours cursing Kennedy this morning I decided to see if my other task for today would turn out as disasterous... not so. Been down to my local engineering shop this morning to get a 5 3/4" holesaw and a little fettling on the edges with the stone grinder and volia the lower driving light apertures are done. Just got to fix them in now!
brettmcc is offline
Old 04-21-07, 03:10 PM   #62 (permalink)
Julian West's Avatar
Julian West
7 Tenths
GT40: GTD
Rep Power: 14 Julian West has a spectacular aura about
Re: Brett's RS GTD
Nice lights Brett, they look superb! Do you have a part number & source for those driving lights?
Julian West is offline
Old 04-21-07, 03:37 PM   #63 (permalink)
Bill D's Avatar
Bill D
I Have No Life
Re: Brett's RS GTD
VERY nice!! Glad you could recupe from the KEP disaster.
Bill D
RCR GT40 Mk1 Gulf
Bill D is offline
Old 04-21-07, 04:16 PM   #64 (permalink)
brettmcc's Avatar
brettmcc
GT40: RSGTD
Re: Brett's RS GTD
Julian,
The lights are from SVC. I picked them up at Detling last week. They are £30 for the pair plus you have to buy the shells. The ones I've got are the H1 variety. The other comes with a H4 and side.
Brett
brettmcc is offline
Old 04-23-07, 05:10 PM   #65 (permalink)
brettmcc's Avatar
brettmcc
GT40: RSGTD
Re: Brett's RS GTD
Made the pedal box this weekend and finished it off tonight. Just got to make the brackets to attach it to the chassis to allow it to adjust slightly.
brettmcc is offline
Old 05-07-07, 05:33 PM   #66 (permalink)
brettmcc's Avatar
brettmcc
GT40: RSGTD
Re: Brett's RS GTD
The pedal box more formally in place, with the beginning of a centre tunnel...
brettmcc is offline
Old 05-07-07, 05:34 PM   #67 (permalink)
brettmcc's Avatar
brettmcc
GT40: RSGTD
Re: Brett's RS GTD
Front Bulkhead section nearly done
brettmcc is offline
Old 05-07-07, 06:10 PM   #68 (permalink)
wolodymyr's Avatar
wolodymyr
GT40: DAX40
Rep Power: 9 wolodymyr is on a distinguished road
Re: Brett's RS GTD
Great Work Brett,
looking very tidy and coming on a treat. Pics remind me to put an anti roll bar on my to do list as my car was built without.
Dave
DAX 302 Installing Alloy Rad
wolodymyr is offline
Old 06-17-07, 02:21 PM   #69 (permalink)
brettmcc's Avatar
brettmcc
GT40: RSGTD
Re: Brett's RS GTD
Well I haven't posted on the build for a while.. mainly because I have been really busy and not had time to do anything
Here's what I have managed to do.. start to get the electric water pump in
ID:	20984   Click image for larger version
brettmcc is offline
Old 07-01-07, 05:25 AM   #70 (permalink)
brettmcc's Avatar
brettmcc
GT40: RSGTD
Re: Brett's RS GTD
Harness bar done, just have to get it powder coated
brettmcc is offline
Old 07-01-07, 12:56 PM   #71 (permalink)
huntsen's Avatar
huntsen
5 Tenths
GT40: Factory-blt GTD
Rep Power: 12 huntsen is a splendid one to behold
Re: Brett's RS GTD
Hi Brett,
It looks as if you have a similar problem to mine when I bought my car - the shoulder harness eyes aren't vertical. This means the harness has to twist before it can lie flat.
The answer is shim washers. They fit between the eye and the harness bar and can be peeled off at, I think .005" increments. You fit the minimum thickness to allow you to rotate the eye the minimum distance to get it vertical.
I probably have some left over - e-mail me.
Tony Hunt
huntsen is offline
Old 07-01-07, 01:22 PM   #72 (permalink)
brettmcc's Avatar
brettmcc
GT40: RSGTD
Re: Brett's RS GTD
Thanks Tony,
I'll see how it comes back after powder coating.
Brett
brettmcc is offline
Old 07-14-07, 09:42 AM   #73 (permalink)
brettmcc's Avatar
brettmcc
GT40: RSGTD
Re: Brett's RS GTD
Progress slow, but at least in the right direction Started to put the fuel pumps in and will finish them off after lunch.
Got a call from Helix yesterday saying my drive plate was ready. I am hoping that CTS can get my transmission together next week now, so I can see if this experiment of Kennedy 016 plate to an 01X box will work...
brettmcc is offline
Old 07-14-07, 10:15 AM   #74 (permalink)
simonjrwinter's Avatar
simonjrwinter
GT40: GTD
Thumbs up Re: Brett's RS GTD
looking good Brett.
GTD with Southern GT rear end. Lowered engine and gearbox. 302, R21T gearbox with LSD.
simonjrwinter is offline
Old 07-14-07, 02:14 PM   #75 (permalink)
brettmcc's Avatar
brettmcc
GT40: RSGTD
Re: Brett's RS GTD
Thanks Simon, started running the aircon hoses this afternoon, and found that I need a couple more connectors the way I have run it.
ID:	21994   Click image for larger version
ID:	21995   Click image for larger version
ID:	21996   Click image for larger version
brettmcc is offline
Old 07-14-07, 11:40 PM   #76 (permalink)
Big-Foot's Avatar
Big-Foot
Gold Supporter
GT40: RCR40 - #45
Rep Power: 20 Big-Foot has a brilliant futureBig-Foot has a brilliant futureBig-Foot has a brilliant future
Re: Brett's RS GTD
Brett - what kind of manifold are you using to get the coolant into the block since you're using an electric water pump? I'm considering going this route with my own car...
Thanks!
Regards - Randy
Big-Foot is offline
Old 07-15-07, 04:25 AM   #77 (permalink)
brettmcc's Avatar
brettmcc
GT40: RSGTD
Re: Brett's RS GTD
Randy,
Nothing spectacular. I have taken the impeller section off an old water pump and will then be sealing the hole and smoothing the inside. Brian Magee will be doing the work for me, see here for one he did previously: Water Pump
There is also a link in there that Jimmy Mac posted there that hasa new machined timing cover. If you can't afford that, Kalun_D did a home made setup that bolted onto an exisiting timing cover (I had a link in a previous post, but it just throws an error and I can't find it).
Anyway, to cut a long story short, I was also going to go down this route, I even made the bosses, got adaptors and even a pump cheap. Sent the pump back to Meziere for repair and they claim they never got it, so I decided to scrap that plan and not use a Meziere pump on my build as they had pi$$ed me off so much. I decided to go with the Davies Craid unit. I still have the parts what I did for the Meziere unit and will post later for you.
Brett
Roy Smart GTD Chassis with complete Southern GT Rear modification
Chris Melia Body
Mexican block
Audi 01X that just needs the gear change sorting
brettmcc is offline
Old 07-15-07, 07:26 AM   #78 (permalink)
brettmcc's Avatar
brettmcc
GT40: RSGTD
Re: Brett's RS GTD
Randy,
This is what I did originally before I went with the Davies Craig unit. Bosses are just cut and filed away to shape and then tapped. BTW if anyone has a spare Meziere 316 motor unit, you can have this lot for next to nothing...
Edit: Sorry forgot to say just for clarity,even though it is obvious. The bosses bolt directly to the timing cover and thus saves space in the bulkhead
brettmcc is offline
Old 07-15-07, 07:30 AM   #79 (permalink)
brettmcc's Avatar
brettmcc
GT40: RSGTD
Re: Brett's RS GTD
Right back on topic. Woken up at 5 due to thunder so I got up earlier and went in the garage, oh how my neighbours must love me firing up the compressor at 7am...
Anyway, wiper motor mounted along with the drive, though I will wait to do the final tubing until the spider is mounted.
brettmcc is offline
Old 07-15-07, 10:06 AM   #80 (permalink)
Big-Foot's Avatar
Big-Foot
Gold Supporter
GT40: RCR40 - #45
