| Notices | Hi member,
Enjoy the forum!
Why not start with your first post today and become an active part of GT40s.com now! And, if you find you enjoy GT40s.com think about becoming a Forum Supporter. | | GT40 Build Logs For build threads and build diaries only. |
04-12-08, 03:31 PM
#121 (permalink)
Join Date: Nov 2003 Location: Heathrow, London, UK GT40: Dax 40 Mk1 (Rover3.9EFi)
Rep Power: 18  | Re: DAX Build Up Collected the car and WOW what adifference 3 weeks at the paint shop has made. It is better than I expected and he pictures do not really do it justice.
I managed to crick my back today so could not get out to take petter shots
04-13-08, 03:29 AM
#122 (permalink)
| | wolodymyr Bronze Supporter
Rep Power: 9  | Re: DAX Build Up Ian,
great job, look forward to seeing it in the flesh. What are your plans for striping etc ?
__________________ DAX 302 Installing Alloy Rad |
04-13-08, 06:06 AM
#123 (permalink)
Rep Power: 18  | Re: DAX Build Up Hi Dave
I'm hoping to get sticker stripes and sidesill stripes done in Black
totally monochrome for now but will allow for changes as and when the mood changes. I may even change to something like Martine at a later date.
06-28-08, 06:21 PM
#124 (permalink)
Rep Power: 18  | Re: DAX Build Up Well it is now 2 years since I got the DAX registered and on the road and thaught things were starting to come together nicely, painted. going well, sorting the small bits for Le Mans etc.
Then I noticed when up at full temp with the fan running there was a water drip from the front of the engine. Tightened all hoses and still dripping. Got ot to a garage today and they did a pressure test - 1/2 hour later pressure was the same. Ran it to temp and it dripped AGAIN. Came home and pulled the water pump - serious evidence of the leak - seems the seal has gone and the drain hole to stop the water getting to the bearing did it;s job and dripped it on the pulley casing it to spray!
New pump on order and should be here n Monday.
Then the car has been out to Brian's and he fitted the outside door handles - no need to slide my hand through the opening of the window.
He also figured out how to get air deom the front ducts through a pair of bilge room fans into the car. I recon 250 cfm per side should suffice- well today I got the plumbing done on one side and did a test run - now have a bad hair day! Loads of air movement s my "tight arse air conditioning system" should work at LE Mans and I'll not need to drive without the windows! To end the day I wired the fans and also a manual over ride for the rad fan.
Then fitted a power socket for the sat nav
Tomorrow I'll refit the interior of the car doors - removed for the handle fitting and redo the carpeting in the door pockets.
I'll fit the black rubber seal around the drivers side door window.
finish the ducting on the drivers side blower system
And fit another 2 of the bilge fan motors inside the rear clip to keep air moving in case of traffic jams.
Monday should see the water pump refitted and then it's just time to do the wash and polish for the trip.
I'll take pictures tomorrow of the completed ducting and fan set up.
Tired but happy with today's progress
06-29-08, 05:59 AM
#125 (permalink)
my heart fell when I read the first para, thought it was something major. In my case its the a/c compressor, but then the engine doesnt need that to run!
Take care with all those fans, if they are all on at once you may be donning a pilots hat  seriously tho, check the current and wiring, make sure that no switches are overloaded as they must add up to a serious amount of current.
Keep up the good work, cant wait to see the car.
Dave
06-30-08, 04:00 AM
#126 (permalink)
Rep Power: 18  | Re: DAX Build Up Dave
Thanks for the comments
Fans are all through fused circuits but also only draw 4 amps max each (possibly more if the blades get stopped by something like a small child!)
I would hope never to have to use them all at the same time but it is definately something I'll be watching - keep an eye on the volts and a sniff out for burning
Total draw if everything was on at once could be a silly number
Lights, hazards,spots, fog, 2 fuel pumps for efi, efi brain, 4 recent addition fans (2 cockpit and 2 rear) and 2 x 175watt demister units for the SVA test!
Just as well I have a 650 amp hour rangie battery fitted!
07-02-08, 08:58 AM
#127 (permalink)
Rep Power: 18  | Re: DAX Build Up Found a water pump it is the P6 variety (to get a short nose)
Needed to modify the mounting holes as a non P6 pulley is used to line up with the crank pulley.
Finished at 10:30 last night so did not start it as the neighbours would have had a fit.
Tonight I'll start and see if it is sealed!
IAn
07-03-08, 03:40 AM
#128 (permalink)
Rep Power: 18  | Re: DAX Build Up Ran up to temp and spewed water everywhere
Simple fix - I had missed on of the hose clips!
Tightened and tan to temp - fan cycled 4 times and temperature steady as a rock.
Refitted cover, seats etc.
Ready to take for a drive tonight
IAn
07-03-08, 03:56 PM
#129 (permalink)
Rep Power: 18  | Re: DAX Build Up Sme pics of the work done in the last couple of weeks
Polished 18 years of corrosion off the fuel fillers and ali surrounds
07-03-08, 04:05 PM
#130 (permalink)
Rep Power: 18  | Re: DAX Build Up Door handles fitted and mechanism made to attach to inner handles. These use normal bearclaw catches. (not those from a Mini)
The rubber band will be replaced by a spring to hold the outside handle closed
Handles made from Ali bar - shaped by an enthusiast Club member
2 bilts through the fiberglass hold the hinge bracket in place
Inner handle opens by pulling forward and returns to up position when closed.Locks - not yet.
07-03-08, 04:07 PM
#131 (permalink)
Rep Power: 18  | Re: DAX Build Up The water pump that sprung a leak
07-03-08, 04:21 PM
#132 (permalink)
Rep Power: 18  | Re: DAX Build Up My "tight arse" air system AKA ram air
Ducted from the brake duct inlets next to the rad
Over the mounts for the Radiator
Through a duct from rectangular to square
Through a bilge pump on each side (250cfm 4 inch)
Into 2 by 2 inch duct pipes per side - oneper side to the eyeball vent and the other in footwell area.
Fans are independently switched
Should not be necessary when moving but will give a good flow when stationary
07-06-08, 03:27 AM
#133 (permalink)
| | saxoncross Rookie
Rep Power: 2  | Re: DAX Build Up Hi Ian
I like the way you've done the door handles, as I never liked the idea of the pivot bolt for the handle being into the fibreglass, as I've seen on many other kits
Good luck with your trip to LeMans
Andy |
07-06-08, 04:22 AM
#134 (permalink)
Rep Power: 9  | Re: DAX Build Up Nice job Ian,
looking forward to seeing it in the flesh soon.
Agree with Andy on the doorhandles, quite robust.
Mental picture of you in the car, wearing flying goggles and a scarf flying in the wind from all those fans. It will surely make you a lot more comfortable in the heat and traffic.
When you ran the car to temperature you didnt say what temperature you reached, mine was about 92deg, interested for comparison.
Dave
07-06-08, 04:53 PM
#135 (permalink)
Rep Power: 18  | Re: DAX Build Up Fans kick in on the thermostat at about 92 - 93 and turn off again about 87 -88
Today I went for a drice to Tony Hunt's for lunch and to drop of tickets for Le Mans Got into a jam and running the rad fan on manual the temp never moved from it's standard position.
Heat started cming through from the engine bay and I turned on the 2 fans blowing on the engine block - a minute or two later and the radiated heat off the bukhead reduced.
The Ram air ducts from the front work really well and give an amazing flow of air anything above 30 mph without the fans running and below that the fans work wonders - that said today was cool an WET - aquaplaned a couple of times on the way home.
07-06-08, 05:04 PM
#136 (permalink)
| | Martin Potts A Tenth
Rep Power: 3  | Re: DAX Build Up Great job with those ducts Ian.
Martin |
08-21-08, 07:48 AM
#137 (permalink)
Rep Power: 18  | Re: DAX Build Up Two and a half years ago I started a journey - to build a GT40
After the 30 months I call this a result!
Taken in Dunlop Curves at the Le Mans Classic 2008!
Thanks must go to a lot of people who helped make this possible - not least of all Paul Walton who did so much of the build, and Brian Magee for fettling and adding some missing bits (Air ducts and door handles to mention 2) and af course Roy Snook for organising the lap time. Lastly to GT40s.com for all the assistance and advice - without which this picture would not have been possible.
Thanks again everyone.
08-21-08, 07:56 AM
#138 ( | |
