LinkBack (3) Thread Tools Display Modes
Old 01-04-08, 06:15 AM   #141 (permalink)
Frank Beuker's Avatar
Frank Beuker
Gold Supporter
Netherlands
GT40: kva
Re: Frank's KVA Build
I've seen them on the internet
but don't know enyone who'se got it
frank
cleaning up the mess the preowners
You're never to old to start doing what you realy like doing
Frank Beuker is offline
Old 01-05-08, 08:50 AM   #142 (permalink)
Frank Beuker
Gold Supporter
Netherlands
GT40: kva
Removed the front an rear clip and it's looking beastly
Started on making a test setup for the steeringarms it's not rigid enough so i've got to change that,made some calls for the instrument to set up caster but nothing so still searching
Name:	IMG_2840 (Small).jpg
ID:	26294   Click image for larger version
Name:	IMG_2841 (Small).jpg
ID:	26295   Click image for larger version
Name:	IMG_2842 (Small).jpg
ID:	26296   Click image for larger version
Name:	IMG_2843 (Small).jpg
Old 01-05-08, 12:18 PM   #143 (permalink)
Julian West's Avatar
Julian West
7 Tenths
GT40: GTD
Frank,
looking good, your fabrication skill shows!!
How do you calculate the length of the steering arm, ie the distance from th the kingpin to the the trackrod end centrelines??
Too short & the steering is too quick, too long & the steering is too lazy... ???
Regds,
Julian West is offline
Old 01-05-08, 07:28 PM   #144 (permalink)
Frank Beuker
Gold Supporter
Netherlands
GT40: kva
Julian,
thank you
I don't know yet how long to make the steeringarm,the position it's on at the moment it will take one turn for max steering (don't know the right term)
If someone can tell me how many turn's or part's of a turn they've got all info welcome
Frank
Old 01-09-08, 01:19 PM   #145 (permalink)
Frank Beuker
Gold Supporter
Netherlands
GT40: kva
Made a simple tool to see how the caster is
Name:	IMG_2850 (Small).jpg
ID:	26403   Click image for larger version
Name:	IMG_2851 (Small).jpg
ID:	26404   Click image for larger version
Name:	IMG_2852 (Small).jpg
ID:	26405   Click image for larger version
Name:	IMG_2853 (Small).jpg
Old 01-16-08, 04:59 PM   #146 (permalink)
Frank Beuker
Gold Supporter
Netherlands
GT40: kva
I had some trouble with the steering rods, when the wheels were in droop the rods cam against the upper arms so i had two choices drop the steeringrack or putt the balljoints higher
because i did find it easier to make two bushes i first made the balljoints fit somewhat higher
and this is the result
picture one is the position at ride hight 12cm bottom clearance
picture two at 14,5 cm
third at max droop at 18 cm
Name:	IMG_2854 (Small).jpg
ID:	26523   Click image for larger version
Name:	IMG_2857 (Small).jpg
ID:	26524   Click image for larger version
Name:	IMG_2858 (Small).jpg
ID:	26525   Click image for larger version
Name:	IMG_2859 (Small).jpg
Old 01-18-08, 02:40 AM   #147 (permalink)
jac mac's Avatar
jac mac
I Have No Life
New Zealand
Frank, have you also checked that you have clearance at full lock each way in the full droop position. Going by your pics I wonder if the rack end may foul the w/bone as well.
jac mac is offline
Old 01-18-08, 11:11 AM   #148 (permalink)
Frank Beuker
Gold Supporter
Netherlands
GT40: kva
Jac Mac,
I did and it's as tight as a piece of paper
frank
Old 01-18-08, 03:46 PM   #149 (permalink)
jac mac's Avatar
jac mac
I Have No Life
New Zealand
Thought so, looks like you might have to lower the rack below that chassis rail & repeat the process. Before you do that make absolutely sure you are happy with ride height and other suspension geometry as it fitted now to avoid further rework.
jac mac is offline
Old 01-18-08, 06:38 PM   #150 (permalink)
Frank Beuker
Gold Supporter
Netherlands
GT40: kva
I did mean that there is a little gap as thick as paper
The reason for first trying to sort it out this way is so that i don't have to lower the rack
and solve the problems which are coming whit this (pedalbox)
But you're right with sorting out the hight and geometry
Old 02-13-08, 02:19 PM   #151 (permalink)
Frank Beuker
Gold Supporter
Netherlands
GT40: kva
I had to lower the rack due to the lack of clearance (Jac Mac you were right)
and are now working on the 'bumpsteer' issue so i can make my steeringarms
Name:	IMG_2873 (Small).jpg
ID:	27269   Click image for larger version
Name:	IMG_2872 (Small).jpg
ID:	27270   Click image for larger version
Name:	IMG_2870 (Small).jpg
Old 02-13-08, 04:05 PM   #152 (permalink)
Frank Beuker
Gold Supporter
Netherlands
GT40: kva
Found the perfect position
Now i've got to make the actual steeringarms
Name:	IMG_2874 (Small).jpg
Old 03-27-08, 04:54 PM   #153 (permalink)
Frank Beuker
Gold Supporter
Netherlands
GT40: kva
I've made the mountings from the suspension so there can't get water to the inside
and i bought a new tool
Name:	IMG_2899 (Small).jpg
ID:	28544   Click image for larger version
Name:	IMG_2900 (Small).jpg
ID:	28545   Click image for larger version
Name:	IMG_2901 (Small).jpg
ID:	28546   Click image for larger version
Name:	IMG_2902 (Small).jpg
ID:	28547   Click image for larger version
Name:	IMG_2903 (Small).jpg
Old 03-29-08, 08:32 AM   #154 (permalink)
Frank Beuker
Gold Supporter
Netherlands
GT40: kva
made some flares on it and gave it a colour
one side done !
frank
Name:	IMG_2904 (Small).jpg
ID:	28605   Click image for larger version
Name:	IMG_2905 (Small).jpg
ID:	28606   Click image for larger version
Name:	IMG_2906 (Small).jpg
Old 04-07-08, 03:34 PM   #155 (permalink)
Frank Beuker
Gold Supporter
Netherlands
GT40: kva
Smile Re: Frank's KVA Build
finished the handbrake mechanism only need to have the cable and rear attachment made
Name:	IMG_2913 (Small).jpg
ID:	28811   Click image for larger version
Name:	IMG_2914 (Small).jpg
ID:	28812   Click image for larger version
Name:	IMG_2915 (Small).jpg
Old 04-07-08, 03:37 PM   #156 (permalink)
Frank Beuker
Gold Supporter
Netherlands
GT40: kva
Started working on the inner panneling
Name:	IMG_2907 (Small).jpg
ID:	28814   Click image for larger version
Name:	IMG_2908 (Small).jpg
ID:	28815   Click image for larger version
Name:	IMG_2909 (Small).jpg
ID:	28816   Click image for larger version
Name:	IMG_2910 (Small).jpg
ID:	28817   Click image for larger version
Name:	IMG_2911 (Small).jpg
Name:	IMG_2912 (Small).jpg
Old 04-07-08, 06:31 PM   #157 (permalink)
Bill D's Avatar
Bill D
I Have No Life
Looking mighty nice Frank. Keep us posted!!
Bill D is offline
Old 04-09-08, 05:38 PM   #158 (permalink)
Frank Beuker
Gold Supporter
Netherlands
GT40: kva
Thank's Bill
made the holes for the steering rack/rods
first made a little tool for positioning put it in the steeringshaft and made a marker on the panel.
drilled a little hole put the panel on the car again and cut the hole in the same line as the steeringrack
Name:	IMG_2917 (Small).jpg
ID:	28856   Click image for larger version
Name:	IMG_2918 (Small).jpg
ID:	28857   Click image for larger version
Name:	IMG_2919 (Small).jpg
ID:	28858   Click image for larger version
Name:	IMG_2920 (Small).jpg
Old 04-30-08, 05:50 AM   #159 (permalink)
Willem
Denmark
Haven't been looking for a while, but you're making good progress, nice fabricating!
Willem is offline
Old 04-30-08, 06:10 AM   #160 (permalink)
altena's Avatar
altena
Netherlands
GT40: GTD40
Frank,
Keep the good work going, nice job!
See you the 11 of may at Zandvoort.
I think because of the Pinsterrace, i be before at the right of the tunnel.
Lucas
altena is offline
LinkBacks (?)
LinkBack to this Thread: http://www.gt40s.com/forum/gt40-build-logs/17758-franks-kva-build.html
Posted By For Type Date
www.v-8.org.uk :: View topic - low down This thread Refback 03-28-07 04:48 PM
www.v-8.org.uk :: View topic - low down This thread Refback 03-15-07 05:31 PM
www.v-8.org.uk :: View topic - low down This thread Refback 03-15-07 04:27 PM
