Old 08-13-07, 10:43 PM   #61 (permalink)
Rob
VintageVenom's Avatar
VintageVenom
6 Tenths
GT40: RCR-40
Re: Rob's RCR40 Build
Ricky,
Check your PM.
So...where's your build thread..?
What ideas have you used?
Rob
aka "VintageVenom"
www.vintagevenom.com
VintageVenom is offline
Old 08-14-07, 03:14 PM   #62 (permalink)
RICKY GRICE
GT40: mk1 rcr
Rep Power: 2 RICKY GRICE is on a distinguished road
hi rob,
thanks for pm. my build thread will begin shortly. fran supplied black powdercoated
chassic, 17 black rims with goodyear eagle tyres with 331 motor and zf gearbox(arriving shortly). pics will be posted shortly.
regards
ricky
RICKY GRICE is offline
Old 09-16-07, 09:29 PM   #63 (permalink)
Rob
VintageVenom
6 Tenths
GT40: RCR-40
It's been a little while, so thought I'd post a quick update.
Cage is in.
Dash is in
Wiring is all but done. As far as I can until the F & R clips are on anyway.
Cooling system done.
A/C done.
Fuel system started.
Totally feasible I could spark it up next weekend, so long as I don't run up against any unforseen challenges with the fuel system.
ID:	23640  Click image for larger version
ID:	23641  Click image for larger version
ID:	23642  Click image for larger version
ID:	23643  Click image for larger version
ID:	23645  Click image for larger version
ID:	23646  Click image for larger version
ID:	23648  Click image for larger version
Rob
aka "VintageVenom"
Old 09-16-07, 09:41 PM   #64 (permalink)
Pantera1889's Avatar
Pantera1889
GT40: RCR MK1
It looks INCREDIBLE!!! The AC system seems to fit great and look very "factory"
RCR GT40 MK1 chassis #14
DeTomaso Pantera #1889
Pantera1889 is online now
Old 09-16-07, 09:47 PM   #65 (permalink)
gt40fran's Avatar
gt40fran
Sponsoring Vendor
GT40: Michigan,USA
Rep Power: 41 gt40fran has a brilliant futuregt40fran has a brilliant futuregt40fran has a brilliant future
Rob,
great pics and fabulous work as always....all credit to you.....
RCR-40..Mk1, 2 and Mk4
RCR-70 Mk3b
RCR-70 Spider
RCR-P4
Superlite Coupe
RCR917
XJ13 for SCF
www.RACECARREPLICAS.COM
www.superlitecars.com
gt40fran is offline
Old 09-17-07, 07:35 AM   #66 (permalink)
Rob
VintageVenom
6 Tenths
GT40: RCR-40
Thanks gents.
Ron, I'm very pleased with the A/C system final fit/finish. It really does look OE factory installed and not like an aftermarket universal kit.
Rob
aka "VintageVenom"
Old 09-17-07, 09:38 AM   #67 (permalink)
MReid's Avatar
MReid
4 Tenths
GT40: RCR Mk1
Rep Power: 6 MReid is a glorious beacon of light
Looking good, Rob! What part of the kill switch will be visible when the rear clip is closed? I was checking out 1083 at Limerock a couple weeks ago and noticed the fire supression system trigger mounted in about the same place. Probably paranoia on my part, but I worried about some idiot dumping the system while I sat at a red light!
Have fun with your build! - Mark
FFR Daytona Coupe
RCR Gt40 Mk1 in the garage, and underway!
MReid is offline
Old 09-17-07, 10:38 AM   #68 (permalink)
Bill D's Avatar
Bill D
I Have No Life
Excellent job!! Keep the pics coming as they will help me do mine!
Bill D
RCR GT40 Mk1 Gulf
Bill D is offline
Old 09-17-07, 12:44 PM   #69 (permalink)
Rob
VintageVenom
6 Tenths
GT40: RCR-40
MReid,
I attempted to pay homage to the below pic of 1076. If you look up the string a bit to the shot where the rear clip is opened up. There is a notch on the LH side (wrt vehicle) where the switch will sit. Visible, yes, but not outside of the plane of the body surface. Not aware of an external fire system release on 1076.
Thanks Bill. Yea...yea... will do...
Rob
aka "VintageVenom"
Old 09-17-07, 04:17 PM   #70 (permalink)
MReid's Avatar
MReid
4 Tenths
GT40: RCR Mk1
Rob,
Here is a picture of 1083 that my son took a couple of weeks ago. I was mistaken on the exact location. It appears to be set up exactly like 1076, but with the addition of the fire activation button just behind the door.
Your GT40 is really coming together nicely! I can't wait to hear first start and see it finished.
Mark
FFR Daytona Coupe
MReid is offline
Old 09-17-07, 05:31 PM   #71 (permalink)
Rob
VintageVenom
6 Tenths
GT40: RCR-40
Thanks Mark,
Me too......
Rob
aka "VintageVenom"
Old 09-17-07, 06:08 PM   #72 (permalink)
CESLAW
3 Tenths
Rep Power: 5 CESLAW is a glorious beacon of light
Rob:
The timing of your post was perfect. I am trying to fit the AC lines under the front clip on my RCR and could not figure our how they should go. Your pictures revealed that whomever is responsbile for bending pipe at Hot Rod air bent mine backwards, or sent plumbing for a different kit. Another little challenge . . . .
Your build is lookng great. Keep the pictures coming!!
Chuck and Ryan
CESLAW is offline
Old 09-17-07, 06:49 PM   #73 (permalink)
gt40fran's Avatar
gt40fran
Sponsoring Vendor
GT40: Michigan,USA
Chuck,
they may have sent you RHD by mistake....
RCR-70 Mk3b
RCR-70 Spider
RCR-P4
Superlite Coupe
RCR917
XJ13 for SCF
gt40fran is offline
Old 09-17-07, 07:24 PM   #74 (permalink)
Rob
VintageVenom
6 Tenths
GT40: RCR-40
Hi Chuck,
Glad the pics helped. They are pretty much the same as what's in the RCR assembly manual if memory serves correct. No matter....glad they were helpful.
Have you started a build thread yet?
Rob
aka "VintageVenom"
Old 09-17-07, 10:12 PM   #75 (permalink)
CESLAW
3 Tenths
Our build thread is in the early stages. Will be posting a lot shortly. Today put the final coat of paint on the dashboard after getting it trimmed and shapped, so it will be back to wiring and gauges. Also have got the AC unit pretty much laid out including the plenum, so the dash can be permanently installed. Our build site is "Chuck and Ryans RCR Build".
The AC pipes sent were for a right hand drive care. Mine is left hand drive.
CESLAW is offline
Old 09-30-07, 10:27 PM   #76 (permalink)
Rob
VintageVenom
6 Tenths
GT40: RCR-40
Time for an update.....
I've spent the last couple weekends plumbing the Cooling system, finishing up wiring the accessories and creating the fuel plumbing.
Had this all finished at about 6pm tonight, decided to spark it up, but had no spark. Determined the pertronix electronic ignition was the root cause. Had to go old school and install a set of points. By the time I got this all done it was 9:30pm, so no tuning what so ever, but here it is.....
Here is vid of 5 mins after the first spark up:
YouTube - It's alive..........." GT40 first start "
ID:	24101  Click image for larger version
ID:	24102  Click image for larger version
ID:	24103  Click image for larger version
ID:	24104  Click image for larger version
Rob
aka "VintageVenom"
Old 09-30-07, 11:02 PM   #77 (permalink)
Pantera1889
GT40: RCR MK1
Thumbs up Re: Rob's RCR40 Build
CONGRATS ROB!!! What a milestone!!! Your car is looking amazing!!!
Won't be long now.
Old 09-30-07, 11:24 PM   #78 (permalink)
paul butvila's Avatar
paul butvila
Canada
GT40: Still looking/drooling
Rep Power: 2 paul butvila will become famous soon enough
What a beautiful looking car. Great job! I originally did not think too much of the Gulf colours, but after seeing so many posts of them I gotta say I am warming up very fast to the Gulf scheme.
Fools rush in...& get the best seats
paul butvila is offline
