| Notices | Hi member,
Enjoy the forum!
Why not start with your first post today and become an active part of GT40s.com now! And, if you find you enjoy GT40s.com think about becoming a Forum Supporter. | | GT40 Build Logs For build threads and build diaries only. |
04-12-08, 01:08 PM
#141 (permalink)
| | EGLITOM 3 Tenths
Rep Power: 5  | Re: Rob's RCR40 Build Rob
Thanks again for spending your time with us. It was a real pleasure talking to you and take a first hand look at the beauty you are building.
TOM
__________________ RCR 40 ; LEVY RACING 331; G50/05; gulfwide |
05-04-08, 10:19 PM
#142 (permalink)
| | VintageVenom 6 Tenths
Join Date: Oct 2005 Location: Michigan, USA GT40: RCR-40
Rep Power: 11   | Re: Rob's RCR40 Build Yahoo..... finally working on the 40 again. The Stang is done and gone. Family trip to Florida behind me. My weekends will be mine for a while...well accept for when the boss says they aren't...
Worked three projects this weekend. Replaced the coolant catch can with a lower profile piece, due to an interference issue when the rear cover was closed. Made up some screens for the side scoops. Started on the front dzus fasteners. Finished to two at the windshield base.
Tom, more than welcome. It was fun meeting you guys. |
05-04-08, 10:41 PM
#143 (permalink)
| | Big-Foot Gold Supporter
Join Date: Jan 2007 Location: Minneapolis, MN GT40: Replica
| Re: Rob's RCR40 Build Rob - Looking good and I know you must have been chomping at the bit to get back to work on it..
I'm using the same coolant reservoir as you too!
Curious where you sourced the Big-Wing Dzus fasteners... I was just about to start making some (a rather tedious task)... |
05-05-08, 12:01 AM
#144 (permalink)
| | Bill D I Have No Life
Rep Power: 33   | Re: Rob's RCR40 Build Rob-
Great progress.
Now for a question
I am also doing the two Dzus fasteners in the same position. But I noticed iin your photo the brackets you have are really tiny. Too small for the springs. What are you using to catch the fastener?
Bill |
05-05-08, 12:15 PM
#145 (permalink)
Rep Power: 11   | Re: Rob's RCR40 Build Randy, the dzus wings are from Sandy. He had a bunch laser cut a while back. Don't know if he still has any....??? I then welded them to standard slot head fasteners.
Bill, I will post a closer pic for you tonight. I bent the spring tab mount around 180º, then fab'd a riser base. The pic will be worth a thousand words, so I'll stop with that. |
05-05-08, 07:04 PM
#146 (permalink)
Rep Power: 11   | Re: Rob's RCR40 Build Bill,
Close ups promised above...... |
05-06-08, 10:49 AM
#147 (permalink)
Rep Power: 33   | Re: Rob's RCR40 Build Thanks Rob. Really slick!! |
05-06-08, 11:11 AM
#148 (permalink)
| | MReid 4 Tenths
Rep Power: 6  | Re: Rob's RCR40 Build Very nice, Rob. Looks like I will follow your design!
__________________ Have fun with your build! - Mark FFR Daytona Coupe RCR Gt40 Mk1 in the garage, and underway! |
05-11-08, 05:55 PM
#149 (permalink)
Rep Power: 11   | Re: Rob's RCR40 Build Didn't get too much done this weekend, with Mother's day today and Julie was in a concert yesterday, but thought I'd share my small progress I did make...
Finished up the front Dzus fasteners.... |
05-11-08, 07:23 PM
#150 (permalink)
Rep Power: 33   | Re: Rob's RCR40 Build Very nicely done!! |
05-12-08, 12:07 AM
#151 (permalink)
| | CESLAW Gold Supporter
Rep Power: 5  | Re: Rob's RCR40 Build Rob:
Looking very good, always inspirational! Those Dsuz fasteners are a nice touch. |
05-18-08, 07:25 PM
#152 (permalink)
Rep Power: 11   | Re: Rob's RCR40 Build Finished up the rear hinges today by installing hydraulic lift arms. Opening and closing is much easier, and holds the clip up/open nicely. Pleased with outcome.... |
05-24-08, 09:25 PM
#153 (permalink)
Rep Power: 11   | Re: Rob's RCR40 Build Hi guys.... finished up the rear exhaust mounts today. Tomorrow is the rear hatch hood pins mounts..... |
05-24-08, 11:45 PM
#154 (permalink)
| Re: Rob's RCR40 Build Rob - Nice work as usual...
It appears that you shortened the megaphones and inlets on the mufflers - right?
What springs did you use and where do you find them? I'm planning a similar mount for mine and just shortened the inlets almost 4" and straightened them out (they were canted about 15 degrees).. |
05-25-08, 11:09 AM
#155 (permalink)
Rep Power: 11   | Re: Rob's RCR40 Build Thanks Randy..
Yes, I did make them shorter. The orig length was no issue in the orig location, but going shorter was necessary to clear the body because I raised them a bit.
The springs were from McMaster (pn 9065K435). |
05-25-08, 01:14 PM
#156 (permalink)
| Re: Rob's RCR40 Build Thanks for the McMaster # Rob... I had to raise my exhaust too since I had no clearance on the longer (but modified) G50/03 Trans.. |
05-25-08, 11:40 PM
#157 (permalink)
Rep Power: 11   | Re: Rob's RCR40 Build Rear pins tackled.... |
05-26-08, 03:21 AM
#158 (permalink)
| | Womabt Silver Supporter
Rep Power: 3  | Re: Rob's RCR40 Build Hi Rob, Very nicely done. Where did you source these from or did you fab them yourself ?
Simon.
__________________ RCR 40, Ally block 302 B&S to 370 ci by T&L engines, ZF trans. |
