LinkBack (6) Thread Tools Display Modes
Old 03-21-07, 08:17 PM   #21 (permalink)
Dlampe's Avatar
Dlampe
Silver Supporter
GT40: RCR GT 40
Re: Dean's new RCR build thread
I wanted to give you a quick look at the engine. We are still waiting on the Weber intake for the 8.7 deck height Yates head motor. Check out those Headers! The rear suspension actually runs through the exhaust. The tubes are 1 7/8 to handle the high flow engine. I am not going to coat them. I am just going to spray them with WD40 and let them yellow out naturally.
Dlampe is offline
Old 03-21-07, 10:40 PM   #22 (permalink)
Big-Foot's Avatar
Big-Foot
Gold Supporter
GT40: Replica
Rep Power: 19 Big-Foot has a brilliant futureBig-Foot has a brilliant futureBig-Foot has a brilliant future
Dean - I like the idea behind the 2" flares and think they'll look great on your car.
That said - I have always ground / sanded away the Gel-coat when adding fiberglass.. Not sure how good the bond will be here.
Maybe Bill H or Fran or someone else more knowledgable than I will chime in.
Regards - Randy
Big-Foot is offline
Old 03-24-07, 11:27 PM   #23 (permalink)
ckouba's Avatar
ckouba
5 Tenths
GT40: RCR40-31
I've heard the same thing- grind through the gelcoat before glassing or glass to the backside of the part.
I am a real rookie though- others will hopefully confirm.
Chris
RCR40 #31 - SBF, ZF, 15" BRM, LHD, Center shift
10 Jan 07 - Picked it up
25 Feb 07 - Body mounted
15 Mar 07 - Motor/trans installed for the first time
30 Mar 07 - Wide track rear suspension installed
05 May 07 - Cage built and installed
June 07 - Sept 07: Sabbatical!!
Oct 07 - today: Never-ending body prep
My Build Thread
ckouba is offline
Old 03-25-07, 12:20 AM   #24 (permalink)
Dlampe's Avatar
Dlampe
Silver Supporter
GT40: RCR GT 40
I made sure they ground through the gel coat on the otherside. They did scuff that side pretty well. I am not to concerned. It will all be glassed from the back after all the extra material is ground out from the under side. I have some more pictures but I haven't down loaded them yet.
Dlampe is offline
Old 03-25-07, 08:22 AM   #25 (permalink)
FRPGUY
3 Tenths
GT40: Norwell, Mass. USA
Dean, You don't have to grind through the gelcoat, but it's better to. If you leave the gel, rough it up with #36 grit dry and all you need is a 4" wide strip of mat on the outside with as wide as you want on the underside. It's best to tear the mat than cut it. I should have the ducts done this week for you.
FRPGUY is offline
Old 04-07-07, 05:50 PM   #26 (permalink)
petek
GT40: Not yet...
Rep Power: 9 petek has a spectacular aura about
Dean - 'bout time for an update!
Pete K.
When your memories out number your aspirations you are officially "old."
petek is offline
Old 04-12-07, 06:17 PM   #27 (permalink)
Dlampe's Avatar
Dlampe
Silver Supporter
GT40: RCR GT 40
Pete you are right, I have a lot so share. The body shop has been busy but hey work slow. I am always amazed at how much longer it takes to get from 90% to 100%. They have finished up the flares. They turned out great. The 2 inch wider hips are really cool. I actually thought I had better pictures but here it is....
Name:	iceing flare.JPG
The under side looks like it was built this way after the extra material was removed.
Name:	inner flare2.JPG
Name:	inner flare3.JPG
Dlampe is offline
Old 04-12-07, 06:30 PM   #28 (permalink)
Dlampe's Avatar
Dlampe
Silver Supporter
GT40: RCR GT 40
They have also been hard at work on the gurney bubble. I was going to just pop rivot the thing on but I didn't like the look so we ended up glassing it in. I really like the smooth lines.
Here is a look at how my oil tank will fit. I thought i would just through that in!
Dlampe is offline
Old 04-12-07, 06:34 PM   #29 (permalink)
Dlampe's Avatar
Dlampe
Silver Supporter
GT40: RCR GT 40
I didn't like the way the front brake duct holes looked when i bent down and looked inside. The fiberglass panel inside seemed to "split" the brake duct hole. I thought it would look beeter if it was over to one side and defininately work better if it was sealed so we did that too.
These were the after shots.
Now it will better funnel the air to the brake vent tubing.
Dlampe is offline
Old 04-12-07, 08:24 PM   #30 (permalink)
Dlampe's Avatar
Dlampe
Silver Supporter
GT40: RCR GT 40
At this point I am very happy with the progress we are making. As you look at the last pictures i posted you can see that the panels fit VERY well together with out trimming them. I had 2 guys messing with the panel alignment for 2 days. I think we have had every panel off and on countless times but they do fit. It just takes patients (or 2 body men paid by the hour!) I hope to finish up the engine tommorrow. I will post some more pictures then.
Dlampe is offline
Old 04-12-07, 09:42 PM   #31 (permalink)
Big-Foot's Avatar
Big-Foot
Gold Supporter
GT40: Replica
Looking like great progress Dean.. I guess I never noticed the panel that "split" the brake cooler duct in the front before. I'll have to consider a similar mod..
Judging from the lack of plastic filler elsewhere, they are finding the molding to be of pretty high quality!
Are you going to be doing anything to the bottom side of the spider or leaving it alone?
Regards - Randy
Big-Foot is offline
Old 04-12-07, 10:42 PM   #32 (permalink)
gt40fran's Avatar
gt40fran
Sponsoring Vendor
GT40: Michigan,USA
Rep Power: 41 gt40fran has a brilliant futuregt40fran has a brilliant futuregt40fran has a brilliant future
Randy,
the spider has an innner roof panel and is already smooth....ready and waiting for your finish of choice..
RCR-40..Mk1, 2 and Mk4
RCR-70 Mk3b
RCR-70 Spider
RCR-P4
Superlite Coupe
RCR917
XJ13 for SCF
www.RACECARREPLICAS.COM
www.superlitecars.com
gt40fran is offline
Old 04-12-07, 11:00 PM   #33 (permalink)
Big-Foot's Avatar
Big-Foot
Gold Supporter
GT40: Replica
Originally Posted by gt40fran View Post
Randy,
I like that!!!
Thanks Fran!
Regards - Randy
Big-Foot is offline
Old 04-13-07, 08:05 AM   #34 (permalink)
FRPGUY
3 Tenths
Dean, I can see by the pics, that the original brake ducts that I make you asked about, probably won't fit in the nose. The inner panel splitting the duct opening in the nose will not allow the duct to fit up to the opening.
FRPGUY is offline
Old 04-13-07, 11:58 AM   #35 (permalink)
petek
GT40: Not yet...
Looking great Dean! Is the Gurney bubble for appearance sake or necessary when you are wearing a helmet?
Pete K.
petek is offline
Old 04-13-07, 05:40 PM   #36 (permalink)
Dlampe's Avatar
Dlampe
Silver Supporter
GT40: RCR GT 40
I actually had plenty of room with out the bubble but I like the way it looks.
Dlampe is offline
Old 04-13-07, 07:13 PM   #37 (permalink)
Dlampe's Avatar
Dlampe
Silver Supporter
GT40: RCR GT 40
We finished filling all those odd little openings in the rear bonnet, some of which I created! There where a couple of holes where the panels where joined and one I created to clear the oil tank. We finished changing over the wiper to the left side too.
Part of the car was in primer when I left the shop today!
Dlampe is offline
Old 04-13-07, 11:10 PM   #38 (permalink)
YerDugliness
GT40: Yellow Wix MKII
Rep Power: 8 YerDugliness will become famous soon enough
Originally Posted by Dlampe View Post
I
