Go Back   GT40s.com > >
Thread Tools Display Modes
Old 11th July 2008, 07:37 AM   #281
fordgt90
GT40: N/A
Re: GT90 from ground up
Apparantly the GT90 is at this years Goodwood Festival of Speed in England, running the next 3 days. So if anyone here is going to that please get me shots (if it is there that is).
fordgt90 is offline   Reply With Quote
Old 12th July 2008, 06:32 AM   #282
Des
Des's Avatar
Des
GT40: WPS GT90
some pics finally
fine tuned door closing positions and working on blending rear guards to arch to triangles and sills
slow going during this stage chasing line flow from rear guards through doors to front
lunatics
you still have a fair bit to go yourself, should be a looker when finished.
Des
GT90 from ground up-dsc03046-jpg   GT90 from ground up-dsc03047-jpg   GT90 from ground up-dsc03048-jpg   GT90 from ground up-dsc03049-jpg
Des is offline   Reply With Quote
Old 12th July 2008, 12:13 PM   #283
fordgt90
GT40: N/A
Still looking great Des, so keep it up.
EDIT: The only image of the GT90 at GoodWood I've found so far:
EDIT AGAIN: Found two hi res shots on the Auto Trader blog:
Old 12th July 2008, 06:11 PM   #284
JoeT's Avatar
JoeT
GT40: GT90... sorta
Ryan you beat me to it lol, nice pictures. Des, looking great as always. I think i'll have to fly out to Australia from Florida when your done to see in person . Actually I probably couldn't afford the trip .
Joe
JoeT is offline   Reply With Quote
Old 18th July 2008, 12:31 PM   #285
fordgt90
GT40: N/A
Saved and found loads of GT90 pictures, will all be on my site soon enough!
This one I had to post early though, I had no idea about this...
Seems the guys involved in the project signed a plaque which is just underneath the exhaust cluster on the rear. I always wondered what that little wierd sticker was on my Maisto model there, thought it was just a bad sticker.
Old 9th August 2008, 02:20 PM   #286
JoeT's Avatar
JoeT
GT40: GT90... sorta
Hey Des, hope everything is going well... ... updates... Im sure you are very busy, anyhow hope alls well.
Joe
Old 9th August 2008, 07:06 PM   #287
Des
Des's Avatar
Des
GT40: WPS GT90
joet
yes everythings still fine
work has meant a trip away for most of last week
how many pics of the same white panels can you bear.
some pics soon
Des
Old 25th August 2008, 05:32 AM   #288
fuoriserie's Avatar
fuoriserie
Italy
GT40: none
Hi Des,
I've been following your build from the beginning, and have to say that that it has been great to watch your progress, and i'm really looking forward to your finished prototype in the future.
Keep the pictures coming......
Ciao
Italo
fuoriserie is offline   Reply With Quote
Old 26th August 2008, 05:47 AM   #289
Des
Des's Avatar
Des
GT40: WPS GT90
Yes some pics
It seems many many hours go in and no visible change comes out and then it just looks right.....
thanks for putting up with me
sides of rear guards, arches and triangles are finally playing nice and are all on the same plane.
lines are now close to final
I have started on doors and front guards to continue the lines through to front arch.
door to guard edges and gaps coming along as well in process.
Des
GT90 from ground up-dsc03053-jpg   GT90 from ground up-dsc03054-jpg   GT90 from ground up-dsc03055-jpg   GT90 from ground up-dsc03056-jpg   GT90 from ground up-dsc03057-jpg
GT90 from ground up-dsc03058-jpg
Old 1st September 2008, 11:42 AM   #290
jvb
south africa
GT40: kit car
Hi there, it is so wonderful to see stuff like these. Please tell me, did you make use of the corvette c5 front a arms. We need the sizes of the pivot points from x and y lines. if it will be possable, thanks. JVB
south africa is offline   Reply With Quote
Old 1st September 2008, 07:06 PM   #291
CraigW's Avatar
CraigW
7 Tenths
Des, beautiful work. It's certainly the time consuming part of the project. Keep the photos coming.
Craig White
Absolute Pace - Australia's Leading Kit Car Manufacturer
<A HREF="
PACE 289, 427, FIA & Alumina
PACE GT
PACE Skeleton
CraigW is offline   Reply With Quote
Old 1st September 2008, 07:32 PM   #292
molleur's Avatar
molleur
GT40: SL-C LS1/930LSD
Des
Fantastic work there! When you work out the parting lines for the mold try to get them in an easily post finished location. Really an awsome job you've done. I did a Maserati A6G-CS body using the same method. Took me the better part of a year working alone.
molleur is offline   Reply With Quote
Old 7th September 2008, 07:33 AM   #293
Des
Des's Avatar
Des
GT40: WPS GT90
jvb
sorry, I did not use the C5 front I am using late C4.
Maybe give a corvette forum a go for the info
craig
yes it sure is, once this pass is done I still need to go over all panels one more time then the top coat.
molleur
one year must have been nice, I am approaching three now with this one.
some pics
doors are almost done and front guards are coming along
lines to front park lights are on track (at least to where they will be)
redid the left fuel filler panel to better fit door edge/surface
(staples are just till glue dries and then it will be puttied in)
Des
GT90 from ground up-dsc03063-jpg   GT90 from ground up-dsc03064-jpg   GT90 from ground up-dsc03066-jpg   GT90 from ground up-dsc03067-jpg   GT90 from ground up-dsc03068-jpg
GT90 from ground up-dsc03069-jpg   GT90 from ground up-dsc03070-jpg
Old 11th September 2008, 04:47 PM   #294
JoeT's Avatar
JoeT
GT40: GT90... sorta
Des, in the close up picture you can see all of the different angles that you have created from wood, I am glad that you have chosen this project because of your amazing attention to detail and dedication. I am just as hooked on this project as I was when I first seen it. Great job Des.
Old 8th November 2008, 01:50 PM   #295
kenshiro8's Avatar
kenshiro8
I Have No Life
Italy
GT40: eeehhhh....
I have no words for Des work..I have just finished now to save ALL the pictures posted in those 15 pages.
You are incredible Des, congratulations.
Paolo
Modelworks
kenshiro8 is offline   Reply With Quote
Old 23rd November 2008, 04:53 AM   #296
Bas
bperez
Hi Des,
Awesome Job! The surfacing material you refer to as "putty" - exactly what is it? I can't really tell from the photos; however, I'm thinking it's a drywall compound or is it a fiberglass body filler like "Bondo"?
Keep up the wonderful work. You're truly an inspiration to me. Most particularly since you were able to generate all of those station templates without the use of a computer!
BAS
bperez is offline   Reply With Quote
Old 2nd December 2008, 04:25 PM   #297
Des
Des's Avatar
Des
GT40: WPS GT90
Hi Sorry I've been "off forum" for a bit, had some stuff to deal with.
not much visibly different happening, removing ripples, smoothing curves and defining edges and lines
currently reworking the septum
I will try and get some pics up tomorrow
work is taking me interstate for a week from Friday
Bas
wondered when someone would ask
it's a blend Denis gave me details of, I will check with him to see if it's ok to release it
Old 2nd December 2008, 04:53 PM   #298
molleur's Avatar
molleur
Des,
I am also interested in the formulation of your "putty". I have used drywall compound before and sprayed with a product called "Kilz" which is a house paint sealer. You can use a polyester filler primer such as "featherfill or a 2K or epoxy primer over it with no problems. Even a Bondo touch up here and there if you sand carefully.
Keep up the excellent work, it inspires others!
Jack Molleur
Old 17th January 2009, 07:37 AM   #299
kav
kavio013
des my god man, you have to be the greatest car guy out there .american or not!!!!!! now if only there was a way to cut the cost up... ive heard rumors of around $100K(US), i would like to see if you would sell a copy of the mold to me feel free to email me @ [email protected]
kavio013 is offline   Reply With Quote
Old 29th January 2009, 11:27 PM   #300
JoeT's Avatar
JoeT
GT40: GT90... sorta
Found some new pics of the GT90 at '08 Goodwood. In this picture I noticed acouple of things. The black duct tape on the window seem, looks like it might have rained and I wonder if the car's windows ever sealed. Also noticed a elongated triangular shaped duct right behind the door, possible brake ducts? anyhow heres the pic.
Des, if you need anymore reference pics I have quite a few more, acouple of the gas filling area too.
Joe
Forum Jump
