Old 02-15-08, 05:20 PM   #61 (permalink)
Keith1's Avatar
Keith1
GT40: Nine
Re: Tornado TS40 #875
Originally Posted by FRPGUY View Post
Great idea Eric! LOL! Poor Scott ! You can do it Scott !
For sure. Scott rules!
Keith1 is offline
Old 02-16-08, 09:41 PM   #62 (permalink)
Scott Calabro's Avatar
Scott Calabro
GT40: TS40 # 875
Keith,
Thank you for the kind words.
This Saturdays work;
Layed out interior rivets and drilled pilots.
Started rear bulkhead.
Finished up steering rack front cover and access panel (just have to cut cooling pipe holes).
Cut battery box hole.
Installed fuel tanks for mock up of fuel quantity sender covers in the sill top panels.
S
ID:	27322   Click image for larger version
ID:	27323   Click image for larger version
ID:	27324   Click image for larger version
ID:	27325   Click image for larger version
ID:	27327   Click image for larger version
ID:	27328   Click image for larger version
ID:	27329   Click image for larger version
ID:	27330   Click image for larger version
Scott Calabro is offline
Old 02-16-08, 09:47 PM   #63 (permalink)
Bill D's Avatar
Bill D
I Have No Life
Beautiful!! Is that polished aluminum or SSTL?
Great progress Scott!
Bill D is offline
Old 02-16-08, 09:50 PM   #64 (permalink)
Scott Calabro
GT40: TS40 # 875
Thank you Bill.
It is all pre-polished aluminum alloy that is included with the kit.
S
Old 02-17-08, 04:20 AM   #65 (permalink)
albanygt40
4 Tenths
GT40: Albany west Aus
Looking good Scott
Really like the polished Alloy look.
DRB GT40 #103 Hopefully here in March 2010
albanygt40 is offline
Old 02-17-08, 07:12 AM   #66 (permalink)
JackW's Avatar
JackW
3 Tenths
GT40: Melbourne, Aust
Scott you are panelling up that baby a treat. At this rate you will be ready for painting in no time. Your build so far is certainly a great advertisement for Tornado cars. Keep up the great work.
Jack
Keeping the dream alive!
Original Mach 2 - From Xbox Forza
JackW is offline
Old 02-17-08, 06:54 PM   #67 (permalink)
Scott Calabro
GT40: TS40 # 875
Thanks Dave and Jack.
I took it easy today .... rest is good.
Finished steering rack front cover with water pipes mocked up.
Not too shabby for an old A&P, if I do say so myself
S
ID:	27352   Click image for larger version
ID:	27353   Click image for larger version
ID:	27354   Click image for larger version
ID:	27355   Click image for larger version
Old 02-18-08, 03:48 AM   #68 (permalink)
kenshiro8's Avatar
kenshiro8
I Have No Life
Italy
GT40: Fujimi 1/24
So fast and (seems so) easy assembly!.
Welldone Scott...go on go on!
If not already present in the manual, u can add all those assembly pictures as a dvd for the cars sold (why not also make small videos with homemade camera?).
Pictures nice as those are always better than any draw or description
Paolo:)
kenshiro8 is offline
Old 02-18-08, 08:35 AM   #69 (permalink)
550spydr's Avatar
550spydr
4 Tenths
GT40: GTD
Wow,
I better get over to see your build before you're finished!
Eric Johnson
GTD 347 w/Webers R30
550spydr is offline
Old 02-18-08, 09:37 AM   #70 (permalink)
FRPGUY
5 Tenths
GT40: Norwell, Mass.
Scott, are you going to build the GT as is or put some of your own modifications to it? I find that personal mods slow down the build with most kits.
FRPGUY is offline
Old 02-18-08, 10:51 AM   #71 (permalink)
Bill D's Avatar
Bill D
I Have No Life
Boy, ain't that the truth
Bill D is offline
Old 02-18-08, 11:32 AM   #72 (permalink)
Scott Calabro
GT40: TS40 # 875
FRPGUY,
Only one deviation from TSC, I have room to install a small storage box just aft of where the dual fuel pumps will be installed, on the right side of the car. It will end up being about 9L x 7W X 5D.
S
Old 02-18-08, 11:39 AM   #73 (permalink)
saxoncross's Avatar
saxoncross
2 Tenths
GT40: Tornado
Impressive work Scott, keep this up & it will be finished by the Spring
What are you using to seal the panels to the chassis with. Mine was done with bathroom sealant (white!!) which is OK but can't be overpainted
Andy
saxoncross is offline
Old 02-18-08, 06:46 PM   #74 (permalink)
Scott Calabro
GT40: TS40 # 875
Thank you Andy.
The sealant used was included in the Deluxe Package.
I do not know what it is made of.
S
Old 02-18-08, 11:04 PM   #75 (permalink)
Scott Calabro
GT40: TS40 # 875
Tonights work;
Rear bulkhead almost done. Just need to cut window hole and install riv- nuts for the GRP engine access panel.
Finished vertical sills.
Could not help myself and had to slap on the spider and front clip to have a look!
S
ID:	27397   Click image for larger version
ID:	27398   Click image for larger version
ID:	27399   Click image for larger version
ID:	27400   Click image for larger version
Old 02-18-08, 11:14 PM   #76 (permalink)
Bill D's Avatar
Bill D
I Have No Life
Great progress Scott!!
Bill D is offline
Old 02-18-08, 11:20 PM   #77 (permalink)
Scott Calabro
GT40: TS40 # 875
Thanks Bill.
S
Old 02-18-08, 11:35 PM   #78 (permalink)
Randy V Moderator
Big-Foot's Avatar
Big-Foot
GT40: RCR40 - #45
Scott - So on the Tornado, do you locate the Spider and then everything else dials in off of that or?
RE: Personal Mods - No kidding... I've had my car in the shop now since the end of October and I've barely started the actual build for all the engineering changes and fabrication because I've deviated so far from the text-book build... That's okay though because I'm doing it my way..
Regards - Randy
My build site:
Big-Foot is offline
Old 02-19-08, 04:44 AM   #79 (permalink)
IanAnderson's Avatar
IanAnderson
Gold Supporter
GT40: Dax 40 Mk1 (Rov
Scott
The build looks brilliant.
A quick question - are the radiator pipes copper? If so are you running an Ali radiator or heads?
If so you will lose ali through electrolisis. It can be eased back with inhibitors but will still happen. So it may be easier to change to Ali pipes now rather than later with the added expense of an new radiator.
DAX GT40. Rover 3.9 EFi, Worked by John Eales.
IanAnderson is offline
Old 02-19-08, 06:52 AM   #80 (permalink)
Scott Calabro
GT40: TS40 # 875
Randy,
Yes the spider is located first.
Ian,
Thank you.
Yes I have both alloy radiator and heads.
I'm not worried about "electrolisis" though.
TSC has been continually developing the car for 19 years now. If it was a significant issue it would be set up differently.
I do understand your concern, however by using distilled water and high quality ethlyene glycol, it is a non issue.
American "Muscle Cars" have run alloy heads with copper/brass radiators for decades with no problems.
S
