12th May 2008, 01:23 PM
#41 (permalink)
| | BigB98 2 Tenths
Join Date: Mar 2007 Location: Duvall, Wa. GT40: RCR MKIV
| Re: BigB's RCR MKIV Quote:
Originally Posted by john_douglass I notice you have a Porsce 930 Transaxle as I have. How are you going to couple the transaxle to the drive wheels? Are you going to use CV joints on each end of the drive axles, or CV joints on the inner and U-joints on the outer.
I have a CV-Ujoint combination on the drive shafts and many members have advised me that this is a source of harmonic vibration!
I have Corvette drive hubs which use Ujoints
John   | I believe the inner/outers are CV units.
Everyone, I'm thinking the engine should be plenty....We'll see just how good Porsche 930 transaxles are. |
13th May 2008, 11:53 PM
#42 (permalink)
| | Larry M
Join Date: Oct 2007 Location: Washington St. GT40: none yet
| Re: BigB's RCR MKIV Man, sorry for missing so much of the build the last couple of months! Ya have been busy on the car and its coming along nice, no, GREAT!! But the last couple of months in Mexico, Calif. and Vegas was a must!
We'll get together when ya get back from Reno and I'll give ya a hand or two.
We will be polishing that engine right??
Hope you guys are having fun at the WSCB
Larry M |
13th July 2008, 02:02 AM
#43 (permalink)
| | BigB98 2 Tenths
| Re: BigB's RCR MKIV |
13th July 2008, 03:44 AM
#44 (permalink)
| | Cliffbeer2 Gold Supporter
| Re: BigB's RCR MKIV Looking good there BigB.
Incidentally, what Goodyears are you using there? dimensions? they look pretty meaty. |
13th July 2008, 10:19 AM
#45 (permalink)
| | Big-Foot Super Moderator
Join Date: Jan 2007 Location: Kenyon, MN GT40: RCR40 - #45
| Re: BigB's RCR MKIV BigB - Are you planning on using the stock water pump? Have you figured out the pulleys and firewall yet? Don't know if the MkIV shares the same engine bay dimensions as the Mk1 - but - While I'm just running a small block, I ended up moving my engine forward a good ways in order to get the tail end of my transaxle inside the body and to get the carbs forward enough to fit through the cut-out.
Had a few hoops to jump through in regard to the starter but managed to work them all out.
Your build is going to be another exciting one to watch..
__________________ Regards - Randy
My build site: To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
13th July 2008, 11:57 AM
#46 (permalink)
| | BigB98 2 Tenths
| Re: BigB's RCR MKIV Cliff, they are Bluestreaks found here: GOODYEAR RACE TIRES 8.00-15262.00G-71758175926.813.2/109.0 to 11.510.319.0
Randy, the tail section is longer than an Mk1, though I do plan to move the engine forward more. Trying to figure out just how much though. Any guidance there would be much appreciated. Haven't done any locating of alternator or AC pump...Figured I would set it in there and try to get to desired location and then make measurements to start fabricating the brackets. |
20th September 2008, 10:46 PM
#47 (permalink)
| | BigB98 2 Tenths
21st September 2008, 02:53 AM
#48 (permalink)
| | Allen English 5 Tenths
| Re: BigB's RCR MKIV Brent - Your build looks great! Any chance you will bring the car down to the PIR Historics next year? |
21st September 2008, 03:00 AM
#49 (permalink)
| | BigB98 2 Tenths
| Re: BigB's RCR MKIV Allen, I'm hoping I'll be ready by that time. Would be great to see you gain. I see in your signature that you have an RCR on the way too! Congrats! |
21st September 2008, 03:06 AM
#50 (permalink)
| Re: BigB's RCR MKIV Brent - That would be great to have down our way again. I think it would be awesome to have a couple of Fran Hall's pieces of art on display at the event.
Yep, i just placed my order  Thanks |
28th October 2008, 09:47 PM
#51 (permalink)
| | BigB98 2 Tenths
| Re: BigB's RCR MKIV Did a quick startup yesterday!!! Oh my gawd!!!! Ok, there is something extremely sexy about an 600hp KeithCraft FE in a GT. The exhaust note is so different from the cobra with essentially the same engine. Man it is AWESOME!!!!
I started it for a little "added" motivation to get the sucker on the road. I've been making decent progress, but I could be further along by now. Hearing that engine....well....that got me excited! WOW! I'll try to get a youtube video of it this weekend.
By the way, the car is not near road worthy...I still have to pull the motor and build the alt/ac brackets and a bunch of wiring to finish....and a bunch of other stuff.
29th October 2008, 12:09 AM
#52 (permalink)
| Re: BigB's RCR MKIV BigB98, if you're in Seattle sometime and want to see a basic old CAV then let me know - happy to show it to you. Or, take it for a drive, if you're needing a little on-the-road inspiration.
Cliff |
29th October 2008, 12:28 AM
#53 (permalink)
| | BigB98 2 Tenths
| Re: BigB's RCR MKIV Cliff, I'm out in Duvall, so we're close. It wouldn't take much to convince me to take a ride with you in your "basic old CAV"!  That kind of motivation is the best there is!
-Brent Mills
29th October 2008, 11:07 PM
#54 (permalink)
| Re: BigB's RCR MKIV Hi Brent, sounds good. Yup, Duvall isn't that far. I'm around this weekend if you'd like to come by - shoot me a private message here and I'll reply with contact info. There are a couple of good guys in the area who are also gt40 gearheads - Neil in Issaquah and Tim in Arlington. We're going to have to do a WA State GT40 summer party next summer! |
15th November 2008, 04:09 AM
#55 (permalink)
| | EGLITOM 10 tenths
Join Date: Sep 2007 Location: Germany GT40: RCR40;LR331;G50
Could you post some pics of your engine installed with the exhaust system ?
Also would be interessted in knowing your gear ratios ( gears and final ratio )
Would be great if you could post them as well.
TOM
__________________ RCR EUROPE by S-PERFORMANCE To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
16th November 2008, 03:44 PM
#56 (permalink)
| | BigB98 2 Tenths
16th November 2008, 04:09 PM
#57 (permalink)
| | darksideguy A Tenth
Originally Posted by BigB98 | is there any way you can post what it sounds like |
16th November 2008, 10:36 PM
#59 (permalink)
| | jac mac I Have No Life
| Re: BigB's RCR MKIV Boy's will be Boy's----
__________________ DIY Alloy Mono MKIV,406 FE,T44(R)
Jac Mac |
18th November 2008, 05:13 PM
#60 (permalink)
| | EGLITOM 10 tenths
| Re: BigB's RCR MKIV Great thanks TOM
