Go Back   GT40s.com > >
Thread Tools Display Modes
Old 21st October 2017, 06:29 PM   #581
JIMMYMAC's Avatar
JIMMYMAC
GT40: Monocoque
Re: Jimmymac & Alistair's Cars
Originally Posted by alistair nuttall View Post
Hi Ian,
its to clear the radiator edges, have a look at GT40P 1049
BR
Alistair
Here is the front of P1049 next to my car.
There are a few cars out there with this front modification.
I am using an original Serck brass radiator and the reliefs help avoiding clashing with the thin brass envelope when the front clip is dropped on.
There are also two aluminium rubbing strips protecting the top corners of the radiator.
Jimmymac & Alistair's Cars-img_20171021_121147_hdr-jpg   Jimmymac & Alistair's Cars-gt40p1049-jpg   Jimmymac & Alistair's Cars-ford-gt40-1966-oa-front-900x600-jpg
James
Festina Lente
GT40 Monocoque, Original MKI Engine & Drivetrain
JIMMYMAC is offline   Reply With Quote
Old 22nd October 2017, 01:39 PM   #582
JIMMYMAC's Avatar
JIMMYMAC
GT40: Monocoque
I have decided to cut the holes in my lower light pods to fit the road car lights instead of the Cibie spots which we fitted to Alistair's racer.
A small upgrade to the orange indicator however as I am fitting a pair of matching period Marchals which are better made fittings than the usual Prince o' Darkness rubber boot kit.
James
Festina Lente
Old 22nd October 2017, 08:49 PM   #583
RWoerz's Avatar
RWoerz
6 Tenths
GT40: GT40 MKI P2197
Great news about the progress. Looking forward to seeing it finished. Might have to cross the pond to see it in person.
I'm still hoping someone can come up with the paint code for the blue on P1049. My car is currently Porsche Midnight Blue which it turns out is black 80% of the time. Not looking to to make a clone of P1049 just like the blue color. Sorry for the drift, "and now back to our regularly scheduled programming".
Richard
GT40 MK1 P2197
1966 GT350H 6S1844
1997 Eagle Talon Tsi
RWoerz is offline   Reply With Quote
Old 28th October 2017, 07:59 AM   #584
JIMMYMAC's Avatar
JIMMYMAC
GT40: Monocoque
We have had a bit of trouble recently finding a good fit bell housing.
Well, I found this original 4-bolt bellhousing a while back and although the lower lugs are missing it is in great shape and still of good use to me.
I am now having it 3D scanned to make a new casting pattern.
James
Festina Lente
Old 10th November 2017, 01:47 PM   #585
JIMMYMAC's Avatar
JIMMYMAC
GT40: Monocoque
Alloy fuel tanks going in.
These took quite a bit of work but the original sparge collector, baffles, return unit and level sensor fittings have been configured and built into the tank design.
Jimmymac & Alistair's Cars-img_3552_1-jpg   Jimmymac & Alistair's Cars-img_3546_1-jpg   Jimmymac & Alistair's Cars-img_3547_1-jpg   Jimmymac & Alistair's Cars-img_3549_1-jpg
James
Festina Lente
Old 10th November 2017, 04:18 PM   #586
JIMMYMAC's Avatar
JIMMYMAC
GT40: Monocoque
Fuel vents, original design but fitted with in-line roll-over safety valves.
Jimmymac & Alistair's Cars-img_3539-jpg
James
Festina Lente
Old 17th November 2017, 02:12 PM   #587
JIMMYMAC's Avatar
JIMMYMAC
GT40: Monocoque
The tank sketches were accurate enough and everything went in nicely, albeit a bit fiddly.
Some sealant to remove on the locking covers.
Fuel pumps tested OK but Alistair is now retrofitting all of the seals on the Stewart Warners.
Jimmymac & Alistair's Cars-img_3583-jpg   Jimmymac & Alistair's Cars-img_3582-jpg
James
Festina Lente
Old 1st December 2017, 03:39 PM   #588
JIMMYMAC's Avatar
JIMMYMAC
GT40: Monocoque
It's getting busy in the back of the first car now.
Jimmymac & Alistair's Cars-img_3605-jpg
James
Festina Lente
Old 1st December 2017, 05:09 PM   #589
New Zealand
GT40: New Zealand
Exciting times.
Classic Car Developments
Scratch built monocoque
351W, 48 IDAs, ZF DS25-1
brianstewart is offline   Reply With Quote
Old 1st December 2017, 07:16 PM   #590
Rod Brace's Avatar
Rod Brace
Silver Supporter
GT40: McLaren replica
That is a thing of beauty!
Rod Brace is offline   Reply With Quote
Old 1st December 2017, 08:14 PM   #591
MHNCO's Avatar
MHNCO
GT40: SPF 2161
MHNCO is offline   Reply With Quote
Old 6th December 2017, 12:07 PM   #592
JIMMYMAC's Avatar
JIMMYMAC
GT40: Monocoque
Thanks Guys !
Another shot of progress. The Ford Racing covers were only fitted as protection for the engine lift. The original style covers with the catch tanks are being fitted soon.
Jimmymac & Alistair's Cars-img_3609-jpg   Jimmymac & Alistair's Cars-valve-covers-006-jpg
James
Festina Lente
Old 6th December 2017, 12:17 PM   #593
MHNCO's Avatar
MHNCO
GT40: SPF 2161
I was wondering about those...
Can you explain the plumbing on the originals?
Old 6th December 2017, 12:31 PM   #594
JIMMYMAC's Avatar
JIMMYMAC
GT40: Monocoque
Mike,
I believe these are coalescers.
Quote from Jay Cushman about these covers from a while back.
The MK1 street cars usualy came with cast aluminum COBRA valve covers made by Buddy Bar in southern Ca. and the exact same as used on early shelbys.
The Mk1 competition coupes usualy came with the tall boxed valve covers made on 1964 1/2 to 1966 289 non lettered valve covers. These were used to help stop the oil from blowing out of the breathers. The idea was that the high pressure from the crankcase would pass thru a small opening into a large as possible low pressure area ( The box) and the oil would seperate from the air and fall to the bottom of the box and then drain thru a hose on each side back to the oil pan. These valve covers were needed as the usable RPMs rose and straight aways grew. Another issue that caused blowby was the increased stroke of some of the small block engines that moves the rod throws further away from centerline and into the oil reserve of the pan. 347s have alot off added windage and Ford was playing with strokers themselves back then as well.
Jay Cushman
James
Festina Lente
Old 6th December 2017, 02:17 PM   #595
glloyd's Avatar
glloyd
GT40: Southern GT
I had that problem with my 331 Jimmy. When I first started using it in anger it would rapidly fill the catch tank within a few laps. I copied those original additions and the problem was cured at a stroke. (No pun intended!)
I was also told that another cure was to enlarge the drainage holes in the block, but the boxes seemed an easier fix and worked, so I stopped there.
glloyd is offline   Reply With Quote
Old 7th December 2017, 01:55 PM   #596
JIMMYMAC's Avatar
JIMMYMAC
GT40: Monocoque
Thumbs up Re: Jimmymac & Alistair's Cars
Hi Glenn,
With your results they are proven for sure.
Jimmymac & Alistair's Cars-img_3619-jpg   Jimmymac & Alistair's Cars-img_3621_1-jpg
James
Festina Lente
Old 27th January 2018, 11:58 AM   #597
JIMMYMAC's Avatar
JIMMYMAC
GT40: Monocoque
Fibreglass work almost complete on the second car.
Jimmymac & Alistair's Cars-img_20171013_132652_hdr-jpg   Jimmymac & Alistair's Cars-img_20180123_155021_hdr-jpg   Jimmymac & Alistair's Cars-img_20180123_155451_hdr-jpg
James
Festina Lente
Old 27th January 2018, 06:51 PM   #598
New Zealand
GT40: New Zealand
Looking good.
Old 27th January 2018, 10:40 PM   #599
MHNCO's Avatar
MHNCO
GT40: SPF 2161
Any idea when they will be done? Can’t to see both of them!
Old 28th January 2018, 06:40 AM   #600
JIMMYMAC's Avatar
JIMMYMAC
GT40: Monocoque
Alistair's car is complete and he turned over the engine first time last week.
I retired from work last month so this one should move a bit now.
You know that you are welcome over here anytime mate.
James
Festina Lente
Forum Jump
Similar Threads
Mirage Automotive Monocoque Chassis Charlie Farley GT40 Build Logs 28 1st March 2011 09:17 AM
Ray Webber - Mirage Automotive Ltd jazzyspies All GT40 5 10th August 2008 08:54 AM
Mirage gt40 chuck 1 All GT40 4 13th September 2006 10:47 PM
Mirage gt40 magmills GT40 Build Logs 17 7th October 2005 02:07 PM
Mirage Automotive simonjrwinter All GT40 1 31st March 2004 02:29 PM
