If this is your first visit please have a look at the FAQ for forum registration. GT40s.com is a free forum but you will have to register before you can post on the forums. Please have a look around, stay awhile and enjoy!
Forum Register Search
Links Gallery Members List FAQ Today's Posts Mark Forums Read
Old 09-24-09, 04:31 AM   #21 (permalink)
simonjrwinter's Avatar
simonjrwinter
I Have No Life
Re: GT40 scratch build
I see, but is that the "engine number" that identifies one engine from another?
Currently GT40-less
simonjrwinter is offline
Old 09-24-09, 04:44 AM   #22 (permalink)
JIMMYMAC
GT40: Monocoque
Use this
FORDification.com - Deciphering Your Ford Engine's ID Tag
James
Monocoque, Original MKI Engine & Drivetrain
Graviner Fire Suppression
JIMMYMAC is offline
Old 09-24-09, 04:58 AM   #23 (permalink)
simonjrwinter
I Have No Life
surely that's for identifying an engine code (ie what the engine is, where it was built etc) and not for the individual engine. If two cars came off the assembly line they would be stamped with individual engine numbers to differentiate one from another even if their "casting" and "engine code" numbers were the same?
Simon
Currently GT40-less
Old 09-24-09, 08:34 AM   #24 (permalink)
brettmcc's Avatar
brettmcc
Silver Supporter
GT40: RSGTD
Simon
The BOM (Bill Of Material) would be far too complex to manage. It is built by using the part and the the part has a line of usage. You only attribute by the line of usage against the VIN.
Sorry for the thread deviation
brettmcc is offline
Old 09-24-09, 09:33 AM   #25 (permalink)
nnrouty
GT40: home built
I've been looking for some Wilwood Brake Calipers for the Granada Discs. The discs are 260mm (10.23") in diameter and are 24mm thick
Does anyone know of a Wilwood Caliper that will be most suited?
nnrouty is offline
Old 09-25-09, 01:24 PM   #26 (permalink)
nnrouty
GT40: home built
Im going to put brakes on hold for now, lets look at suspension. Seems theres lots of options in this area.
Anyone know what is going to be the bast set up for both road and track use?
nnrouty is offline
Old 09-25-09, 02:12 PM   #27 (permalink)
zetecmk2
2 Tenths
GT40: pile of bits!
i won some opel manta rear lights today for £1.20
locost,,,oh yes!!
zetecmk2 is offline
Old 09-25-09, 02:39 PM   #28 (permalink)
nnrouty
GT40: home built
So the manta lights are the same size as the fiat 850s lights??
nnrouty is offline
Old 09-25-09, 03:05 PM   #29 (permalink)
zetecmk2
2 Tenths
GT40: pile of bits!
i'll find out when they arrive!!
locost,,,oh yes!!
zetecmk2 is offline
Old 09-25-09, 03:23 PM   #30 (permalink)
nnrouty
GT40: home built
Hope thay are ok, they look alot like the fiat lights but hard to tell weather they are the same size off a photo.
We hope to use GAZ shocks, does anyone know if they produce a suitable shock absorber for the gt40's?
nnrouty is offline
Old 09-29-09, 08:29 AM   #31 (permalink)
nnrouty
GT40: home built
I've talked to the technical guys at Wilwood, they have suggested that we use the 4-piston Dynalite or Dynapro calipers with our Granada Scorpio Discs.
We are also using 0.65 Tilton master cylinders which are already fitted to the pedal box.
I also hope to get a price from Southern GT this week for the adaptor plate, steering column and the fuel tanks and a price for the radiator from Docking Engineering.
So hopefully is shouldn't be long before we start work again on the car.
Not sure what size brake and fuel pipes i will need though.....any ideas?
nnrouty is offline
Old 09-29-09, 09:16 AM   #32 (permalink)
3 Tenths
-3 on brakes
-6 for fuel
Regards Martin.
MartinGough is offline
Old 09-29-09, 10:53 AM   #33 (permalink)
nnrouty
GT40: home built
Thanks for that Martin.
Can you recommend a suspension system?
Our rear uprights are a similar design to the original design and we are using the Granada front uprights.
nnrouty is offline
Old 09-30-09, 10:03 AM   #34 (permalink)
brettmcc's Avatar
brettmcc
Silver Supporter
GT40: RSGTD
Yes, I have them on my build. PM me.
Brett
Roy Smart GTD with Southern GT Rear modification
Chris Melia Body
Mexican block
Audi 01X
brettmcc is offline
Old 09-30-09, 03:50 PM   #35 (permalink)
nnrouty
GT40: home built
Hi Brett sent you PM
So would you recommend a GAZ system?
nnrouty is offline
Old 09-30-09, 08:23 PM   #36 (permalink)
RacerDave's Avatar
RacerDave
GT40: scratch build
Hi:
If you want AP brakes. AP also makes a Dynalight style caliper. An AP CP8250 would be a better choice.
Looking forward to the first drive
RacerDave is offline
Old 10-01-09, 05:12 AM   #37 (permalink)
nnrouty
GT40: home built
We would like to use AP brakes although it would have to be at the right price.
AP are twice the price of Wilwoods and i think wilwoods will be fine for what we want to use the car for.
Although if some AP calipers come along at a good price am sure we'll be interested.
nnrouty is offline
Old 10-01-09, 07:15 AM   #38 (permalink)
brettmcc's Avatar
brettmcc
Silver Supporter
GT40: RSGTD
Nathan,
Firstly, I live in Essex and the factory is a mere 5 mins drive from where I work.
Secondly, my car isn't built and on the road so I don't know how it handles yet.
Thirdly, there is no prescribed system. I bought just the shocks from them and gave them the specifications. They were kind enough to also make them with a slightly thicker rod (14mm). I have have just their basic shocks with singlt adjust. I bought them, as I had heard good feedback from their normal systems and they were competitively priced against AVO etc. Ultimately I will probably spend a bit on springs once the car is on the road trying out different rates, or even using a cobimation of springs like some memebers do with the the Eibach springs.
Brett
brettmcc is offline
Old 10-01-09, 07:42 AM   #39 (permalink)
nnrouty
GT40: home built
Was there an extra cost for the modified thicker rod?
Nathan
nnrouty is offline
Old 10-01-09, 07:47 AM   #40 (permalink)
robmlufc
GT40: GT40 kit soon
I had GAZ shocks on my old mini, worked a treat and at a good price for the quality you are getting!
robmlufc is offline
Similar Threads
LOLA T70 scratch build... marcus Lola T70 Lounge 107 06-26-10 09:50 AM
1TG Scratch Design & Build. Doug68 GT40 Build Logs 35 12-24-09 09:37 AM
Tank scratch build marcus The Paddock 3 04-12-08 09:29 AM
Wanting to build acurate replica from scratch, resource help gollygwagen All GT40 17 09-28-05 06:13 PM
Scratch build websites and sources? aero The Paddock 5 03-26-05 03:16 AM
Mindestic
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.2
