3rd November 2010, 10:30 PM
#1 (permalink)
| | fearsom Rookie
| Jim's ERA build |
4th November 2010, 06:12 PM
#2 (permalink)
| | SpeedQuest A Tenth
Join Date: Jun 2006 Location: US - Midwest GT40: ERA #2013
| Re: Jim's ERA build Please post more pictures of your chassis!
Darnel
__________________ ERA #2013, 302, ZF Trans |
5th November 2010, 11:35 AM
#3 (permalink)
| | YerDugliness Lifetime Premier Supporter
Join Date: Mar 2006 Location: near Houston TX GT40: 1/24 scale MKII
| Re: Jim's ERA build So, Jim, were the photos of the chassis taken at the ERA factory before the powdercoat was applied?
REALLY nice chassis, IMHO!
I know the ERA factory will factory "bond" the body to the chassis on their Cobra replicas.....did you have them do it for your ERA GT?
Would you mind expanding on the manner in which your "kit" was delivered? I have heard that rather than having all of the parts in boxes in the cabin, when a GT kit from ERA arrives, all the parts are installed in the place where they belong. It is still necessary to "deconstruct" the kit to complete it, but it seems to me that if what I have heard is true, it would sure eliminate a lot of guessing and general gnashing of teeth, wondering where to put this and that.
Thanks for starting this build thread! I'll be following it with great interest.....
Cheers from Doug!
__________________ YD,E./PNB
Retired once, back at work, still attempting to age disgracefully To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
5th November 2010, 11:38 PM
#4 (permalink)
| | fearsom Rookie
| Re: Jim's ERA build |
8th November 2010, 11:41 AM
#5 (permalink)
| | fearsom Rookie
| Re: Jim's ERA build The car is home and the  creativity begins |
8th November 2010, 08:25 PM
#6 (permalink)
| | Dalton 10 tenths
| Re: Jim's ERA build Oooh Yeeaaahhh! Looking good. |
8th November 2010, 10:09 PM
#7 (permalink)
| | fearsom Rookie
9th November 2010, 07:41 AM
#8 (permalink)
| | kcoffield Lifetime Premier Supporter
| Re: Jim's ERA build Hey JIm, looking good. Happen to have any other pictures o fthose ERA rear uprights? I've never seen those before and would like some more details if available.
Best,
Kelly
__________________ SPF GT40 Mk II, 74 Pantera GTS, 64 Corvette Roadster |
9th November 2010, 10:18 PM
#9 (permalink)
| | fearsom Rookie
| Re: Jim's ERA build Kelly. here are some photos of the back as I was building the suspension. Is this what you wanted to see? if not I can take a few more pictures. Jim |
10th November 2010, 02:37 PM
#10 (permalink)
| | blueovalz Silver Supporter
| Re: Jim's ERA build Nice rear uprights. The 3-hole pattern suggests I may be able to use something like this in lieu of my home-built uprights (uses GM bearing carrier). I suppose I should contact the manufacturer and get more info.
__________________ Terry To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
10th November 2010, 02:47 PM
#11 (permalink)
| | Ron Scarboro 2 Tenths
| Re: Jim's ERA build That is one SERIOUS rear upright.
Beautiful car. |
10th November 2010, 10:49 PM
#12 (permalink)
| Re: Jim's ERA build [QUOTE=fearsom;316232]Kelly. here are some photos of the back as I was building the suspension. Is this what you wanted to see? if not I can take a few more pictures. Jim[QUOTE]
Thanks for that Jim, that's what I was lookinf for. Nice looking pieces.
Best,
Kelly
11th November 2010, 10:57 AM
#13 (permalink)
| | fearsom Rookie
15th November 2010, 02:15 PM
#14 (permalink)
| | fearsom Rookie
19th November 2010, 02:44 PM
#15 (permalink)
| | fearsom Rookie
20th November 2010, 06:28 PM
#16 (permalink)
| | KarlB Rookie
| Re: Jim's ERA build Nice buid Jim,
We have got an ERA GT40 in our club ........build quality to die for and sweet sweet sweet.
Wish You well with the build & keep the photos coming.
karlB |
20th November 2010, 10:45 PM
#17 (permalink)
| | fearsom Rookie
| Re: Jim's ERA build When I was working on the rear of the car I did not like the multiple colors the AN fittings came in. With the blue ones they seemed to be multiple shades of blue. So I had all the fittings reanodized just red. While I was at it I anodized the cockpit panels and the wheel spinners red.
21st November 2010, 06:16 PM
#18 (permalink)
| | fearsom Rookie
| Re: Jim's ERA build The rear of the car is now developing. Now you can see the stainless steel firewall. In the upper left is the Pollak valve for routing the fuel to the correct tank. |
22nd November 2010, 08:45 AM
#19 (permalink)
| | Phil 8 Tenths
| Re: Jim's ERA build Jim;
Good looking build, I look forward to seeing the motor and gearbox going in. All of the ERA cars I have seen have a ZF.
I have used a few different types of those quick steering wheel disconnects and was not happy with them as they rattled a bit, and most could be re-attached at a number of different clock positions. I finally found a unit from NRG that uses a keyed pattern of balls with a zero-play fit and it always finds the same clock position....it did the trick for me.
Good choice on the stainless firewall.
Phil
__________________ Scratch Built Spaceframe, 289, Pin Drives, ZF Box |
24th November 2010, 10:19 AM
#20 (permalink)
| | fearsom Rookie
| Re: Jim's ERA build The cooling manifold for my weber unit came off in the wrong direction and angle. I made a new one that I could also put my temperature gauge in. |
