Part 1.
Well the (very) Daunting task of the GT40 build process begins.
I have a whole shed load of parts and body panels and brand New double garage in the build. some of the parts are good some not so good. somewhat of a 2 teps back to get going sort of build. The chassis and parts I have purchased have been dormant for 10yrs. a new lease of life heads now there way.
I have been trawling all the build logs and I have had great deal of support and advice from many members, trust me it is all heeded.
25 yrs in engineering design, fabrication and construction should see me through. I hope ??
I now work mainly from home designing and building water recycling and biological water treatment systems for industrial applications using my own polymeric UF membranes (little plug there, sorry ).
Job List 1 :
Remove all Ali uprights, brakes, coils and wishbones, strip and clean.
Shot balst corroded chassis / tub parts & treat
Spec at present :
GTD chassis ( at least I think It is )
Rose jointed
Roy Smart engine mounts
Anti roll bars
Ali uprights front and rear
Steering rack
6x piston Wilwood calipers front 4x piston rears
Front window screen (Cracked :furious
6x pin knock on hubs
Outer door handles
Front nose clip / full vent opening( want twin)
Rear clip
Roof spider
2x side sill / rocker panels
2x doors with inside pockets
Good second hand head lights (corroded )
1 Rear light (simca)
Demister vent
Battery isolation switch
Good second hand high torque starter motor
Motolite steering wheel
Side windows
Headlight covers
2x fuel filler caps.
Front to rear stainless cooling pipes
Propsed Engine/ trans body build spec
ford 302
ali heads
48 IDF webers
maybe Renault transaxle
electric water Pump
Maybe dry sump with oil cooler and pump.
Twin fuel pumps and filters.
aircon
so if any of you guys have any GT40 parts collecting dust on the shelves or not wanted give me a shout or if you can give me some good sources for parts I would welcome any feedback.
cheers for now
Job List 1 :
Spec at present :
Rose jointed
Anti roll bars
Steering rack
Outer door handles
Rear clip
Roof spider
Demister vent
Side windows
Headlight covers
ford 302
ali heads
48 IDF webers
electric water Pump
aircon
cheers for now
