Gallardo Mesh
Hi
first excuse my English if I dont explain any point right
I have different project , it was going with me since 1997 when I was searching for diablo
I went with corvette and I played around with NOS and some many thing
now after many ideas I decided to buy Gallardo to do what I was thinking to do with diablo
I bought Gallardo 2005 and it was without transmission but the seller offer me transmission from a different car
I sold the transmission and the engine with good price , swap it to ls1 engine with dodge transaxle 42le
I will take about how I fit the ls1 engine with 42le
first I face problem to fit the ls1 engine to my car so i have no option to fit the engine because the size of the engine and the space for the transaxle center
i had two option : ether to extend the wheel base or to cut the body ( behind the driver seat )
honestly i didn't want to play with the axle and the tire and the break system so i went with the option to cut the body behind the driver seat because of the free space i have
i will stop here , and when ever i know how to post picture i will show you how i did it and continue
please who ever know how to post the picture send me PM with the steps
last : i know i did many mistake with this project but this is my first project and im learning from it moreover i am not from usa or Europe
to se other projects to avoid the mistakes , please don't disappoint me
and wait for me to post the picture and write more where i am right now
thanks
during this time when i was thinking of how to solve the space engine problem i started rebuild the ls1 engine and searching for adopter for my transaxle
unfortunately my knowledge was not so good with the sites in the internet so i want t one guy from my country to do the adopter for me
he did it right but with a lot of problem and long time and the worst thing was the finishing it didn't look got at all but it working
next i will post the adopter picture with the engine and transaxle together
the reason why i did the engine and the adopter before cutting the body because i was thinking maybe i can play with the axle but i couldn't
Hi Mish.
If you have the photo already on a picture hosting site (flickr, picasa/google) then just grab the "link" and press the little postcard image in the header and then insert the link or just paste.
Eg from flickr if you look on the bottom right of the screen and there is a right arrow in the middle, click that, select BBCode and a size then copy the line at the bottom and paste it in
DSC07497 by fastdruid, on Flickr
Picassa is similar, on the right there is a "link to this photo", select "image only (no link)", pick a size, select and copy the contents of the box labeled "Embed image" then go back here, click the postcard icon and paste that line
Finally you can upload the photos. Select "Go advanced" and then at the bottom notice there under the "Submit reply" and "preview post" there is "additional options", click the button marked "Manage Attachments". A little pop up window will appear. Select "Choose file", pick a file on your computer and then press upload. After a while you'll see the file you chose in the "current attachments" section. At this point you can either leave it or click on it (it'll open in a new window), copy the URL and press the postcard icon again then paste it.
attachment.php
HTH
Hi there all. I deleted photos he posted as they were direct links to a porn site. As is normal when this happens, the poster is automatically banned. If he feels this is somehow in error, then he should re register under a different username, make contact again, and explain.
I am so sorry I just upload the picture and I didn't know that's is direct porn site
I will try doing it right then continue
again sorry for that's
here is my car first when I got it it was without engine and transaxle
and was left for 9 months
attachment.php
this is the automatic transaxle I bought from one yard with the controller
here is another mistake because I found after that's I need to reflash the controller and we don't have any one in my country do that specially with old car
in the second picture is the adopter first when I got it just to check and what we need to do more to make it fit
look bad I know :)
attachment.php
attachment.php
for automatic transaxle adopter you need two part not only one plate like the manual transaxle , is was the first problem I faced then the starter also need space so I cut small part from the adopter
here is the picture for the one part of the adopter
attachment.php
the engine , transaxle and the adopter
attachment.php
all together finally and ready to have it on my car to see how much we need to cut from the body because the axle need to be centered to the transaxle
attachment.php
by tomorrow I will upload more picture with the car and how I started the extend the space of the body
after get the engine ,adopter and the transaxle together I tried to have it to the car to see how it look like
attachment.php
attachment.php
attachment.php
attachment.php
those four yellow circles where I have problem to solve the engine need more space
the center circle : I need to cut the body
the two side circle : the gas tank , need to cut the tips from it
the down circle : is the four wheel drive shift , already I decided to remove it because my transaxle does not support the 4wd
attachment.php
during this time I start looking for some one can help me with the harness and controller for my transaxle to ls1
I find really good person and he offer me a harness with flash controller
he told me that's it need time to prepare it then send it to me so I start working with body , tank and 4wd shift to save the time
by the way : I bought the harness from : italianknightrider and was really good person he help me a lot with many different things
Hi Mish, How much do you need to trim from the firewall, most CV joints will run at about 7deg max, that's what my old Toyota Corona runs from the factory, that means you can move the motor and trans back and gain about 50mm clearance
Paulbav >>>> thank you for your replay , believe me if I had a chance to work better than that I will but can you imagine I couldn't find any one work or accept to have my car in their garage !!!
all what you see is made by my research ,I spent many many hours just to get basic information , just give me time and see how I am going change this car
Graeme S >>>>> yes you right I could move some mm but also I will have problem if I want to change any thing on the engine like the ac compressor or the belt
I have to take the engine out for small thing in the future ,so I decide to move the firewall to have space for the engine
many thanks for your advise
so I started removing the two gas tank for preparing ( cutting the side of it )
attachment.php
attachment.php
the red mark cross is the part I need to remove for both gas tank because those part is very close to the engine ( its for safety and also for the engine to be installed in free space )
attachment.php
the E gear pumping unit , I don't need them any more so I remove it and kept it in my home garage for any need in the future
next will be the hard job ( moving the firewall ) honestly I didn't want to go with this , until I found that's I have no option
finally with strong heart we move the firewall :)
attachment.php
see the second picture the OEM part was 2cm , after this cutting I decide to have wide plate than the OEM to close the firewall
attachment.php
more pictures is coming to explain how i start close the firewall
Top work, is this in real time or are you uploading pics of work you have already done? Either way enjoying it :thumbsup:
Paulbav >>>> thanks
no my friend I have been working for this project since December 2013
but my first 3 months only was searching for a car and what I do to it
first was thinking of replica but fortunately I found this real Gallardo
I am uploading those picture of my work and I have more to come ether for the body or the engine and transaxle
here is the gas tank after I did my cut for the part that's I don't need
( the part is close to the engine side ) its been done by aluminum argon welding , another issue I faced because I couldn't find some one do aluminum argon welding specially for gas tank until I find one who did it for me
attachment.php
you can see the round close part in the red circle , Its for the gas pump and OEM Gallardo has two gas pump so I decide to close one and use only one gas pump for my engine
attachment.php
the gas tank now ready to install but I will not install it now until I finish most of the work and clean the whole engine area
getting ready to remove the four wheels drive shift
attachment.php
on the second picture I decide to keep the front differential with the front axles to support the front frame of the car
attachment.php
removing the 4w drive shift
attachment.php
attachment.php
attachment.php
done with the 4w drive shift , it wasn't hard to remove
