Southern GT in Indonesia
SGT chassis #25
Fist thing first is fitting the A arm and all suspension. I do not open the wrapping on the A arm because I don't want to scratch them.
A week later, my SGT more looks like a car after I bought tyres and put it on the wheels.
I also do a paneling in suspension area. I do not rivet it yet but I was using some screws to tie the panels to the chassis. When this fitting complete, then I will rivet them. I do this because I'm afraid doing some mistakes, because I don't have a manual to build this SGT. Anyway, I really enjoy in every steps. It was challenging.
As you can see, all the wrapping on the panels are still there, because I don't want to scratch or make the panels dirty.
I will update if any other progress. I expect this SGT will finish in a year or more, because I want to make my GT40 as perfect as I can do. I will try to minimize default when I build it.
Any ideas on engine gearbox and induction? and pictures...loads of pictures.....
Dear Andy,
I bought my ford engine from URE in USA. This is a 363 stroke engine and have 504hp. Below is specification engine from URE:
1. Block: ATECH BLOCK (Everything on the 504 HP is 100% Brand New except the Atech Block itself)
2. Heads: TRUE RENAGADE AFR CNC PORTED ALUMINUM HEADS
3. Intake Manifold: DUAL PLANE EDELBROCK RPM AIR GAP
4. Carburetor: QUICK FUEL 780 CFM
5. Distributor: CHEVROLET V8 GM LICENCED HEI
6. Valve Covers: CUSTOM DIE CAST ALUMINUM VALVE COVERS
7. Air Cleaner: CHROME with Ford emblem)
8. Water Pump: ALUMINUM POLISHED FINISH
9. Harmonic Balancer: SFI RATED 1045 STEEL DAMPER
10. Flexplate / Flywheel: SFI RATED STEEL (MANUAL TRANS FLYWHEEL)
11. Pulleys: UPPER & LOWER (CHROME FINISH)
12. Gaskets: FEL-PRO
13. Forged Crankshaft: SCAT FULLY FORGED 4340 STROKE CRANKSHAFT(Fully Racing Grade Forged Crankshaft)
14. Forged Rods: SCAT FULLY FORGED 4340 RODS (Fully Racing Grade Forged Crankshaft)
15. Forged Pistons: KIETH BLACK FULLY FORGED PISTONS (Fully Racing Grade Forged Crankshaft)
16. Roller Camshaft: COMP CAMS HYDRAULIC ROLLER CAMSHAFT (Custom Ground Roller Camshaft)
17. Roller Lifters: COMP CAMS HYDRAULIC ROLLER LIFTERS (Roller Lifters) 18. Roller Rockers: STAINLESS HYDRAULIC ROLLER PRECISION - 1.6 RATIO (Full 1.6 Roller Rockers)
19. Rings: SPEED PRO
20. Bearings: KING ALLECULAR
21. Double Roller Timing Set: PRECISION TRUE ROLLER
22. Oil Pump: MELLING
23. Oil Pump Driveshaft: MELLING
24. Oil Pump Pickup Screen:MELLING
25. Valve Springs: AFR (AIR FLOW RESEARCH)
26. Seats: AFR (AIR FLOW RESEARCH)
About the gearbox, I'm using Audi 01E 6 speed Gearbox with LSD. I bought this gearbox from GT Racing (Home - GT Racing)
So Irvin, you have a 383 cu. in. Chevy with a Ford air badged air cleaner! That's very sneaky :sneaky:
:laugh:
A week before Christmas, I was trying to put the engine and gearbox. This is only a dummy engine, just for fitting on the engine bay
Merry Christmas to all my friends in GT40s forum. Christmas is a season of great joy: a time for rememnbering the past and hoping for the future. May the glorius message of peace and love fill all of us with joy during this wonderful season...
