Go Back   GT40s.com > >
Thread Tools Display Modes
Old 24th August 2016, 04:19 PM   #1
Lofty27
GT40: KVA
KVA GTD (C) 351W in bits in the shed
Hi to everyone. Yes its spread out between two sheds and the garage. I have owned the chassis and body for almost two years, during which time I have been collecting other parts. The plan is for a road going car capable of the occasional trackday. Chassis modifications are almost complete. I have been reading posts on here for some time and have taken many ideas and plenty of inspiration from them, so many thanks to the members. Hoping to catch some members at Oulton Park this weekend, more photographs required to answer the endless amount of technical queries. Best wishes from Liverpool
Lofty27 is offline   Reply With Quote
Old 24th August 2016, 05:05 PM   #2
MikeP's Avatar
MikeP
Silver Supporter
GT40: GTD
Re: KVA GTD (C) 351W in bits in the shed
Hi Patrick,
You can meet up with the NW GT40 Club members on Sunday or Monday. We will be in the usual spot overlooking cascades. Should be 5 cars and other members around. I have a fair bit of info on KVAs etc.
MikeP is offline   Reply With Quote
Old 25th August 2016, 06:56 AM   #3
john_douglass's Avatar
john_douglass
GT40: KVA
Patrick,
I have a KVA - post some pictures of what you got.
John
john_douglass is offline   Reply With Quote
Old 20th March 2017, 04:20 PM   #4
Lofty27
GT40: KVA
Hi John sorry its ages since my post. I will attempt to attach some pics. I would welcome your comments regarding my assumptions on the chassis type etc. Regards Patrick
KVA GTD (C) 351W in bits in the shed-20160530_140707-jpg   KVA GTD (C) 351W in bits in the shed-20160530_140606-jpg   KVA GTD (C) 351W in bits in the shed-20160525_191302-jpg
Old 20th March 2017, 07:49 PM   #5
MikeP's Avatar
MikeP
Silver Supporter
GT40: GTD
Hi Patrick,
Having looked at your pics there are some significant differences between what you have and a KVA C type chassis. The rear uprights are not like a KVA and look more like GTD. The chassis front is completely different to a KVA. The KVA chassis is tapered in at the front and therefore the front wishbones have a short and a long side. I don't know if your car was always like this or if it has been radically modified. It may be that it is a car that was intermediate car built by GTD between the KVAs built by GTD and the first GTDs. To me your chassis is far more like GTD than a KVA C type. A bit more investigation may help. Is there a chassis number anywhere?
I will look up some KVA and GTD chassis pics for comparison purposes. I have way too many pics to post here so I have sent you a private mail via this forum. See left above.
Old 20th March 2017, 09:58 PM   #6
Mike Surber
GT40: none
The way the rear suspension pick up points are just kind of hung out there. Behind the rear bulkhead looks pretty weak. Looks like they made the chassis too short & just had to tack them on behind. Just my 2 cents worth but I'd sure be looking at that.
Mike Surber is offline   Reply With Quote
Old 21st March 2017, 04:56 AM   #7
Kev Farrington
GT40: KVA/GTD+GTDin p
Hi the photos are of the early KVA with GTD subframes welded on which was how GTD first started making GT40s. They did a bolt on front subframe as an alternative if you preferred. My car is built using GTD suspension mounted on my own subframes on the same early KVA. Hope this helps, Kev Farrington
Kev Farrington is offline   Reply With Quote
Old 22nd March 2017, 03:04 PM   #8
Lofty27
GT40: KVA
Hi thank you for the replies and information, all taken note of. I will post some more pics and will continue to do so through the build process. Cheers
Forum Jump
