Go Back   GT40s.com > >
Thread Tools Display Modes
Old 3rd February 2018, 10:25 AM   #81
H Craft Customs
Gold Supporter
GT40: Superlite GTR
Re: H Craft GT-R, Jared's build.
Originally Posted by [email protected] View Post
H no doubt I will be ordering parts from you just curious if anyone knows where I can find the intake setup used on th Radicals 3.5 twin turbo car with or without the charge coolers or does anyone know anyone in the aftermarket maybe producing a intake manifold for the 3.5 Ecoboost twin turbo if not I may take on this challenge
Larry I've put my feelers out to buddies at Roush who are on the Ford GT engine program ill let you know if they come up with anything.
H
H Craft Customs is offline   Reply With Quote
Old 4th February 2018, 12:41 PM   #82
GT40: None
Andy thank you very much just as a side note if anyone is looking to purchase a newer Chevy Silverado or GMC Serria Pickup I just got mine delivered yesterday from an auction site called Copart they have 50 Silverados and 41 GMC Serria Trucks that were in the Houston Flood and no water intrusion I got a 2017 Chevy Silverado Crew Cab All Star Edtion for 28,300.00 and the truck retails for $ 48,000.00 Just go to Copart.com go to find vehicle and plug in info look for water/ flood damage.
lkishel@wmjdonovan.com is offline   Reply With Quote
Old 4th February 2018, 06:46 PM   #83
H Craft Customs
Gold Supporter
GT40: Superlite GTR
Larry, No joy with the Roush Yates guys its all a bit too proprietary, and they are not involved in the Radical stuff so best you contact Radical and see what they have to offer.
H
Old 5th February 2018, 07:36 PM   #84
H Craft Customs
Gold Supporter
GT40: Superlite GTR
Re structuring the bulk head, lots of welding to do here.
This is to sit over the intake pipe.
Then I cleaned up the opening trying to give some access to the front of the engine just incase.
Then to start and weld it all together.
Im adding some vertical stiffener's to the inside that will be tied together below the hole, the hole will have a removable panel that will house the base speaker and if removed allow access to do a belt change etc.
Hope to finish this up tomorrow.
Old 6th February 2018, 10:14 PM   #85
H Craft Customs
Gold Supporter
GT40: Superlite GTR
So four hours into today I managed to finish up the welding of the bulkhead reconstruction.
Then turned my attention to creating a window frame aperture, its a little shallower than OEM but will still be sufficient to se out the rear.
Old 12th February 2018, 08:00 PM   #86
H Craft Customs
Gold Supporter
GT40: Superlite GTR
So whilst the engine is in place for a while I'm going to work on some exhausts.
Jared had supplied me with some Hookers headers and a whole bunch of 3" pipe and mandrel bends.
In order to at least make a dent in the mountain of pipe I decided to first head off on a forward direction adding a shorty Cat and a 190 bend before heading towards the rear of the car, we wanted to run an X pipe so the only place suitable for this was tucked under the trans.
To be continued
Old 12th February 2018, 08:55 PM   #87
lobelsteve's Avatar
lobelsteve
GT40: SLC GT-R
At what stage of my build should i bring it by for you to build my exhaust?
lobelsteve is offline   Reply With Quote
Old 12th February 2018, 09:16 PM   #88
H Craft Customs
Gold Supporter
GT40: Superlite GTR
Hi Steve
Any time now that the motor and trans are in, as long as you know where all the big pieces are going to be within the engine bay, and before they are all crammed to permanently in the way. You will also need to know where you want you tips to end up.
H
Old 12th February 2018, 11:00 PM   #89
dallas_
Silver Supporter
GT40: SLC in progress
Dang. Beautiful work Andy, really nice. You are an artist.
dallas_ is offline   Reply With Quote
Old 14th February 2018, 11:38 AM   #90
GT40: None
H great work ok Fran has my order and paperwork and the Ecoboost motor arrived so I guess as soon as I send the deposit in I will join the GTR brotherhood Andy I think we can be super creative with this car and you have proved that so far
Old 14th February 2018, 08:51 PM   #91
H Craft Customs
Gold Supporter
GT40: Superlite GTR
Congratulations Larry, yes these kits have great potential for sure.
Old 19th February 2018, 08:29 PM   #92
H Craft Customs
Gold Supporter
GT40: Superlite GTR
A little more progress on the exhausts, not far from the rear now.
Old 20th February 2018, 07:10 PM   #93
H Craft Customs
Gold Supporter
GT40: Superlite GTR
Moving on to the charge cooler, the electric pump has been mounted to the bulkhead and ill bend up some aluminum water pipes to carry the water to the cooling rad which will sit over the transmission, It will have cold air ducted from the engine cover and pushed through the rad.
Here is the plenum fabricated up out of 065" and 090" 3003 aluminum, the two holes are for the ducted cold air.
Old 21st February 2018, 08:52 AM   #94
GT40: None
H your charge cooler gives me some ideas when it comes to my car, again great work.
Old 22nd February 2018, 07:52 PM   #95
H Craft Customs
Gold Supporter
GT40: Superlite GTR
So more of the charge cooler parts coming together, two four inch pipes will get air from within the rear upper wheel arches which are fed cold air from the engine cover scoops.
The water is feed by these 5/8" pipes from the front of the motor to the charge cooler.
Now working on the air filter and intake runner, the air filter is going to be enclosed and ducted from the side scoops
Old 1st March 2018, 09:13 PM   #96
H Craft Customs
Gold Supporter
GT40: Superlite GTR
Trying to close in the air filter so as to capture only cool air from the side scoop.
also got the header tank brackets done for mounting to the bulkhead.
Old 2nd March 2018, 09:08 PM   #97
HardRocker
Wow. Fantastic engineering and fabrication work!
HardRocker is offline   Reply With Quote
Old 2nd March 2018, 09:51 PM   #98
H Craft Customs
Gold Supporter
GT40: Superlite GTR
Finished up the exhaust tail pipes today, its all a little tight in the rear end, especially when you need to fit in a couple of expensive looking tips.
Oh well expensive or not there was not enough room for them without cutting them in half.
Old 3rd March 2018, 09:20 AM   #99
johnny cobra's Avatar
johnny cobra
4 Tenths
GT40: Tornado GT 40.
That is a bloody work of art ...................
Tornado 40 330 BHP IVA passed ........
johnny cobra is offline   Reply With Quote
Old 3rd March 2018, 09:44 PM   #100
H Craft Customs
Gold Supporter
GT40: Superlite GTR
Thanks Johnny
Tags
bend, bulkhead, engine, intake, throttle
Forum Jump
