Old 02-15-05, 04:11 PM   #1 (permalink)
Netherlands
GT40: Tilburg, The Netherlands
Rep Power: 5 danielzijlmans is on a distinguished road
Dashboard left hand drive
Hi Everybody. I own a GTD with a right hand drive dashboard, does anyone know if I can still purchase a dashboard for a GTD, a left hand drive of course. Does a dashboard of another factory fit? Tornado for example?????
Thanx
danielzijlmans is offline
Old 02-15-05, 04:54 PM   #2 (permalink)
Henrik_Smedberg's Avatar
Henrik_Smedberg
Sweden
GT40: GOX40
Rep Power: 6 Henrik_Smedberg is on a distinguished road
Re: Dashboard left hand drive
I would contact MDA since their kit is more like the former GTD than Tornado
Henrik_Smedberg is offline
Old 02-15-05, 10:04 PM   #3 (permalink)
Phil's Avatar
Phil
3 Tenths
GT40: scratch built Mk1
Daniel
I may have access to a left hand GTD dash, let me look and I will let you know
Phil
Phil is offline
Old 02-16-05, 04:20 AM   #4 (permalink)
Netherlands
Thank you very much!!!
Old 02-16-05, 07:58 AM   #5 (permalink)
Daniel Olofsson's Avatar
Daniel Olofsson
Sweden
GT40: MDA Mk I
Rep Power: 4 Daniel Olofsson is on a distinguished road
Call Mark at MDA. He worked for GTD when they still were around. I know he helps the GTD people to get parts for their GT40.
Daniel
Daniel Olofsson is offline
Old 02-16-05, 08:50 AM   #6 (permalink)
brettmcc's Avatar
brettmcc
GT40: RSGTD
Daniel,
Before you buy the dashboard, you have considered, that you will need to make provision for swapping the coolant pipes over and modifying the chassis for the gear change? I am assuming that you have a right hand drive chassis to go with the current dashboard.
Brett
brettmcc is offline
Old 02-16-05, 12:49 PM   #7 (permalink)
Netherlands
Hi Bret,
Absolutely, I tear down the whole front section of the car ( everything between the dash and the radiator ). I'm working on a new floortype pedalbox. I could guide the radiator pipes on the outside (better for the heat too). I would have to install the shifter in between and since I'm installing a brandnew engine and porsche 930-4 speed trans, I need to make a new shifter guider anyway. So, actually the only thing now is a dashboard, cooling pipes and a little axtra work for the shifter, but it would be a great advantage to sit on the lefthandside here in Holland!!! I'm also making changing to the chassis construction around the front suspension so that would be alright. When I'm done, I'll put some pictures.
Old 02-16-05, 04:48 PM   #8 (permalink)
Lee Dawson
GT40: No forty at pre
Rep Power: 6 Lee Dawson is on a distinguished road
Hello Daniel,
I have the original GTD body moulds, & am producing parts from them. All parts are avalible. Left or right hand. E-mail me for details
Lee
Lee Dawson is offline
Old 03-21-05, 11:48 PM   #9 (permalink)
Wolfman
GT40: Body shell only...looking at chassis options or unfinished kit
Rep Power: 5 Wolfman is on a distinguished road
Lee/Phil,
Please PM me with the info about your dash and/or body panels you are producing...I may need a couple of parts.
Wolfman is offline
