| Re: Rear Suspension Upgrade Clay, I think that the benefit is that you can set up the basic castor angle first (by setting the inner a-arm mount at the correct angle), then lock on the lower trailing arm to suit. Fine castor can then be set with the top trailing arm, & then you end up with a very simple toe-in adjustment at the outer end of the a-arm without affecting the previous settings.
If you have a mormal a-arm setup, toe-in adjustment (chassis end of the arm) will muck up your castor angle (unless you compensate by changing the upper trailing arm as well.
The reversed a-arm just seems easier to set up - I just went thru this whole precedure today with a local suspension expert on my DRB (very similar setup to the CAV, but also has a rose-joint at the outer-front of the reversed a-arm). He was rapt - just do steps 1, 2, 3, etc & nothing affects anything you did before !
Kind Regards,
Peter D. |
