Old 10-05-06, 09:18 PM   2 links from elsewhere to this Post. Click to view. #1 (permalink)
wbmusarra's Avatar
wbmusarra
Location: Snellville, Ga. "Everybody's somebody in Snellville"
GT40: DRB#5
Rep Power: 19 wbmusarra is a name known to all
bump steer
I have gotten my steering rack, a unit from Flaming River. The rack mounts are a little narrower than what comes on the DRBs(15 1/2 vs 17) and moving them is no real problem. The point of the universal joints(don't know its real name) in the rod ends are 24" apart. The mounting bolt for the lower A arms are 24" apart. My question is, will this create or increase bump steer and if it makes it worse, what are my alternatives. I believe I read somewhere that raising the rack will help cancel out the bump steer problem. Where does the line of the shaft have to be in relation to the mounting of the rod ends(C-4 Corvette suspension)? Not being an engineer, I am way out of my knowledge base here. I also don't want to make a bunch of holes in the shiney new stainless getting it mounted. So a little info from the more knowledgable ones would be appreciated.
DRB#5
351 Windsor bored, stroked internaly balanced
DIS
TWM 8 Port F. I.
930 Porsche LSD
wbmusarra is offline
Old 10-06-06, 12:42 AM   #2 (permalink)
prre's Avatar
prre
Silver Supporter
GT40: GT40 Developments Chassis, Tornado Bodied
Rep Power: 7 prre is on a distinguished road
Re: bump steer
The best thing to do is to put the rack in and clamp it in position and check the bump steer. Depending on the results you get you can then shim it to raise the rack or move its position forward or back and clamp again and recheck until you get it right.
Paul R
Tornado Bodied GT40 Developments Chassis
prre is offline
Old 10-06-06, 07:36 AM   #3 (permalink)
wbmusarra's Avatar
wbmusarra
GT40: DRB#5
Re: bump steer
Paul,
Thanks for the imput. Since I have to move the "stock" mounting position to get the mounting holes to line up horizontally, I wa hoping someone would chime in on the vertical component. I plan on taking the car to a well known Corvette racing shop next week for front end work. They may be able to work out the bump steer. I was hoping I could go in there armed with a little information. The lower A arms have a little room for front and back movement and will have to be shimmed into place just as they do for a factory setup. I was hoping that I could get info on the geometric placement of the rack(3D) in relation to the location of the steering arm. Here are some pics of what I am working with.
DRB#5
DIS
TWM 8 Port F. I.
930 Porsche LSD
Old 10-06-06, 10:50 AM   #4 (permalink)
RTIMTE's Avatar
RTIMTE
2 Tenths
GT40: Plano, TX USA (Dallas)
Rep Power: 9 RTIMTE is a glorious beacon of light
Re: bump steer
Bill,
Here is a portion of the rack tech section on Woodwards web sight. It has some good info on getting the correct rack position and length.
Richard
Richard D. Timte
RF GT40
351W Alum Block, Yates Heads, Kinsler Fuel, TRT 800, LG600 Mark II (SOLD)
RTIMTE is offline
Old 10-06-06, 01:01 PM   #5 (permalink)
YerDugliness
GT40: Yellow Wix MKII
Rep Power: 8 YerDugliness will become famous soon enough
Off topic, but.....
Bill, I have to mention how much I drool over all the engine turned SS I see in your build! Like you, I have an affinity for the engine turned look and once this build is complete I think it will be right up there with others that set the bar high in this field!
Good luck on the bump steer issue--even if you never get it right (although I have read enough of your posts to know that you WILL get it right) I'll still be drooling every time you post photos!
Doug
YD,E./PNB
Retired and attempting to age disgracefully
YerDugliness is offline
Old 10-06-06, 01:24 PM   #6 (permalink)
prre's Avatar
prre
Silver Supporter
Re: bump steer
I see your challange and hindsight is a wonderfull thing as it would have probably been easier to sort out your rack position before cladding which I must say looks very good. Hope that you manage to get it sorted.
Paul R
prre is offline
Old 10-06-06, 08:08 PM   #7 (permalink)
jac mac's Avatar
jac mac
Rep Power: 18 jac mac has much to be proud ofjac mac has much to be proud of
Re: bump steer
Bill, while Richards article helps it does not allow for the amount the steering ball joint is outboard of KPI ( a line drawn thru the center's of the top & bottom ball joints ). You must double this & add it to the rack measurement for total rack length. If your having trouble following this PM me & I will give you a 'country boy' explanation using Richards drawing feature's as a guide.
Jac Mac
jac mac is offline
Old 10-06-06, 10:54 PM   #8 (permalink)
Phil's Avatar
Phil
3 Tenths
GT40: scratch built Mk1
Re: bump steer
Jac Mac makes the most relative point here. The upper and lower wishbones are swinging in different radii, also the steer arm connector has its own radius. The trick here is to make sure that the tie rod swings in a radius that does not move the steering arm out or in during the suspension bump or droop, causing bump steer. I would map out your suspension points, as close as you can at the pivots of the wishbones, ball joints and steering ball joint (or rod end if applicable), this will give you a very close approximation of the pivot width at the inner rack joints. From there you can cut your tie rods to size set the toe and shim the rack (or the outer tie rods) to take out the bump, or most of it. It may be difficult to take measurements of your pivot points with chassis members etc. in your way, but it is possible. If you need further help I may be able to e-mail you some basic front end diagrams showing the critical points that need to be considered.
Good Luck
Phil
Phil is offline
Old 10-07-06, 06:24 AM   #9 (permalink)
wbmusarra's Avatar
wbmusarra
GT40: DRB#5
Re: bump steer
I think Richard's article will get me started. I would appreciate any info via PMs etc. as this will be a foray into unknown territory. The alignment may wind up being exactly where it should be. The outboard ball joint is only about 1/2" beyond the lower A arm attachment point on either side. The upper A arm attachment is just outside the cladding. It apears(in my minds' eye) that movement of the rack will be minimal for cancelation of the bump steer. Richard's article will get me started, but do send any info on the setting up of the steering, as that is where I am at present. Thanks guys. I am sure this info will be helpful to a lot of others.
DRB#5
DIS
TWM 8 Port F. I.
930 Porsche LSD
Old 10-09-06, 09:02 AM   #10 (permalink)
Julian West's Avatar
Julian West
7 Tenths
GT40: GTD
Rep Power: 14 Julian West has a spectacular aura about
Re: bump steer
Bill,
Maybe this will help, it's one of the best & most simple ideas I've seen for checking bump-steer.
You can see in the photo I clipped a laser pointer to the hub. you can pick up these in the uk for 3-4 pounds.
All you do is pin a sheet of graph paper to your garage wall where the pointer strikes (the further away, the more accurately you can measure) & you can plot the amount of 'steer' as you raise the suspension on, say,wooden blocks, 1 inch at a time.
you can easily clip the pointer on different parts of the suspension & track & mark the different radii of the various suspension components (as pointed out by Phil).
Best Regards,
Julian West is offline
Old 10-09-06, 09:14 AM   #11 (permalink)
IanAnderson's Avatar
IanAnderson
Gold Supporter
GT40: Dax 40 Mk1 (Rover3.9EFi)
Rep Power: 17 IanAnderson is a jewel in the rough
Re: bump steer
Julian
That really is simple but must be pretty effective.
Can on of the Gurus please explain at what ride height the chassis should be to set the bump steer? Presumably it is set at a nominal (say)4.5 inches. But correct me now if I am wrong the bump multiplies the further from neutral you go, so do you try and set it with less movement under braking (Say) 2.5 inches to end of travel or when under power (Say) 5.5 inches.
Reason I ask is if you are doing 120mph (or more) and the nose is up higher than at rest and you get movement the resulting car "wander" could be uncontrolable compared to under hard braking the "wander" would be less (Lower speed times change of angle).
Yes I accept you are trying to minimise the movement but at what end of the travel is the lowest movement required?
IanAnderson is offline
Old 10-09-06, 09:38 AM   #12 (permalink)
lotus-62's Avatar
lotus-62
GT40: netherlands
Rep Power: 3 lotus-62 is on a distinguished road
Re: bump steer
nose up because of lift means less pressure on your tyre = drop.you can have a little steer on drop but not on bump (like cornering,no pressure on the inboard tyre
lotus-62 is offline
Old 10-09-06, 01:17 PM   #13 (permalink)
aero's Avatar
aero
2 Tenths
GT40: Currently designing scratch built mid engine sports car.
Rep Power: 6 aero will become famous soon enough
Re: bump steer
Question about the laser bump steer method. How do you account for the fact that even with absolutely zero bumpsteer, the dot will still move side to side because of the fact that the upright / hub moves in an arc?
Concerning the ride height at which to set bump steer - I would personally minimize it at ride height since this is where it will bite you the hardest. The big reason for setting bump steer is to keep the car from darting around while driving in a straight line. Obviously you also want the wheels to do what you intend when turn the wheel and subject the chassis to a roll angle; this is the other big reason for doing it. With any half way decent suspension design you should be able to get the bump steer minimized enough that it doesn't matter what ride height you choose, just make sure it's good throughout the whole range.
Currently designing a sports car:
Mid engine (what else is there?)
Audi 3.6 V8. (ok, there are others)
40" high (what else is there?)
aero is offline
Old 10-09-06, 01:51 PM   #14 (permalink)
speed220mph's Avatar
speed220mph
GT40: ERA GT
Rep Power: 7 speed220mph is on a distinguished road
Re: bump steer
Bill: Get a copy of Fred Puhn's book "How to Make Your Car Handle". It covers about everything you'll ever need concerning bump steet, roll steer, camber change, anti-features and a lot of other stuff about suspensions and the effects of aero and braking on handling.
Tom
"History does not entrust the care of freedom to the weak or timid."
- Dwight D. Eisenhower
speed220mph is offline
Old 10-09-06, 08:01 PM   #15 (permalink)
CCX33911
GT40: Virginia
Re: bump steer
Sorry for the short post. The laser idea is good except for it does not take into account the track change versus actual steering. If the wheels move inward under bump (normal for typical setups) it will show up as a laser movement toward the center of the car even if there is no bump steer. Most systems measure the relative motion of the front and rear of a tire/wheel. Ride height should be set to the actual as used track condition (weight, fluids, fuel, etc.).
Gary
CCX33911 is offline
Old 10-10-06, 09:29 AM   #16 (permalink)
Julian West
7 Tenths
GT40: GTD
Re: bump steer
Before I go any further, I am not a suspension expert, just sharing ideas for discussion.
Sure Chris, Gary, I hear what you are saying & the laser idea doesn't take any geo into account, it is simply a way of plotting the movement of a particular part of the suspension.
I guess you could use the same method to plot the arc of the outer ends of the top & bottom wishbones & compare this to the arc taken off the hub. In an ideal world (ie minimal bump-steer) the arc taken off the hub would be somewhere inbetween the two arc taken off the balljoints.
WDYT??
Old 10-10-06, 12:33 PM   #17 (permalink)
CCX33911
GT40: Virginia
Re: bump steer
Thats an idea. Take a laser on the upper ball joint for example (which you know is not towing in/out) versus the one on the hub. Look at the differences in motion.
Sorry if I come off as short, but new job has me working many hours and I just jump in to the point. I am certainly up for fresh ideas, etc.
Gary
CCX33911 is offline
Old 10-10-06, 03:18 PM   #18 (permalink)
jac mac's Avatar
jac mac
Smile Re: bump steer
WDYT??
How is this going to help Bill who needs to calculate his rack install height so that he can drill /machine the clearance holes in the correct position on his nicely polished/turned panels in situ, before he can even begin to work out rack and tie rod lengths. Until he has his rack in place he cannot proceed.
Clamp the laser to the upright[ with coilover & steering removed] and plot laser arc on wall while lifting suspension thru travel without bumping upright, then refit steering arm, replot arc & compare.
Jac Mac
jac mac is offline
Old 10-10-06, 04:06 PM   #19 (permalink)
speed220mph
GT40: ERA GT
Re: bump steer
This laser deal doesn't take into account tread change and anti-dive features, so using a laser as described can screw up bump steer badly if you use this method to locate steering pivots.
The most accurate way of doing a bump-steer check is with a surfaces plate mounted to a hub, then position two dial indicators level with each other to stands sitting on the floor. With the indicator plungers compressed and at the indicator set a zero, run the suspension up and down. By the way, you have to remove the coil-over assembly and support the car while doing this. After moving the suspension up and down from ride height one inch at a time, record suspension position and indicator readings. Calculations will give you toe in inches or degrees, whichever way you prefer to go.
Another quicker, but not as accurate way of doing bump steer is to support the car at whichever end you be checking--in your case, Bill, the front--, remove the coil-over units, set each wheel on turn plates and jack the front up and down from ride height. You can then read out toe directly at turn plates at each position.
A quick check can be done by setting the front wheels with the coil-overs intalled, then get someone to step in the front bay behind the radiator and read the change in turn-plate degrees. Ideally, there shouldn't be any change. You'll can also check for any bump steer in rebound by raising the front in increments with a jack. There are other methods of checking bump steer, but they all involve moving the wheels up and down a prescribed amount and measuring bump one way or another.
Digg this Post!Add Post to del.icio.usBookmark Post in Technorati
