| Notices | Hi member,
Enjoy the forum!
| | GT40 Tech - Chassis,Brakes,Tires,&Wheels Chassis and Handling. |
08-02-07, 06:47 PM
#1 (permalink)
| | Maily Rookie
Rep Power: 2  | Chassis Weight Hi All.
I'm new to all this, and just curious as to how much the bare chassis weighs.
RCR Alloy, looks fantastic
The original chassis and Tube framed chassis.
Cheers everyone and thanks
Ray |
08-02-07, 06:56 PM
#2 (permalink)
| | gt40fran Sponsoring Vendor
Join Date: Sep 2001 Location: Manufacturer of GT40: Michigan,USA
| Re: Chassis Weight RCR weighs a shade over 300lbs including fuel tanks...
Make sure to add the weight of the aluminum cladding and fuel tanks to any tube chassis for an apples to apples comparison....
RCR-40..Mk1, 2 and Mk4
RCR-70 Mk3b
RCR-70 Spider
RCR-P4
Superlite Coupe
RCR917
XJ13 for SCF www.RACECARREPLICAS.COM www.superlitecars.com |
08-03-07, 06:54 AM
#3 (permalink)
| | Maily Rookie
Rep Power: 2  | Re: Chassis Weight Thank you Fran.............. |
08-03-07, 07:16 PM
#4 (permalink)
| Re: Chassis Weight The original Mk1 steel chassis with steel roof ...no tanks weighs in around 385lbs ....or there abouts...
RCR-70 Mk3b
RCR-70 Spider
RCR-P4
Superlite Coupe
RCR917
08-03-07, 07:16 PM
#5 (permalink)
| | Scott Calabro Supporting Vendor
Join Date: Oct 2006 Location: New England GT40: TS40 # 875
Rep Power: 9  | Re: Chassis Weight Hi Fran,
When you say a shade over 300 lbs., what is a "shade"?
If you would allow me, I'd like to take a stab at guessing your mono's weight from just a few simple deductions.
A 4x8 sheet of aluminum, depending on alloy, as far as I can tell without knowing the actual alloy, weighs on average 110-120 lbs. per sheet at the thickness you provide, (6mm/.250"). Or 3.4 - 3.75 lbs. per square foot.
So allowing for the benefit of the doubt, and without the roll bar that an RCR has to have, would mean that, using conservative figures, your mono has about 3 sheets of aluminum used in its construction, or 96 sq. ft.
Totaling 330 - 360 lbs.
The only thing I can't get my head around is how you only need 3, 4x8 sheets or 96 sq.ft. of aluminum to build a mono.
I have not included any of the extruded aluminum re-inforcements shown in pictures of the RCR mono.
Please help me to understand how an RCR tub is built.
Thanks,
Scott |
08-03-07, 07:20 PM
#6 (permalink)
| Re: Chassis Weight Ah Scott ...
you are assuming that all the material is 6 mm ...which it is not and that 100% of all the sheet is being used....again which it is not....
Many of the guys on the forum have picked up one end of the bare chassis with me holding the other.....why the concern Scott...???
An aluminum Lola Mk3b original tub weights 115lbs......
RCR-70 Mk3b
RCR-70 Spider
RCR-P4
Superlite Coupe
RCR917
08-03-07, 07:26 PM
#7 (permalink)
Rep Power: 9  | Re: Chassis Weight No concern at all.
Just wondering.
Oh by the way, the little red tach needle below you avatar is inoperative.
Its the one that lets everyone know who's online.
Cheers,
Scott |
08-03-07, 07:27 PM
#8 (permalink)
| Re: Chassis Weight Must have stalled when I dropped the clutch a little too quickly.....
I see it as Red....????
RCR-70 Mk3b
RCR-70 Spider
RCR-P4
Superlite Coupe
RCR917
08-03-07, 07:36 PM
#9 (permalink)
Rep Power: 9  | Re: Chassis Weight Good job fixing it Fran!
S |
08-03-07, 07:38 PM
#10 (permalink)
| Re: Chassis Weight Just needed an Optima battery to keep her running.....
RCR-70 Mk3b
RCR-70 Spider
RCR-P4
Superlite Coupe
RCR917
08-03-07, 09:02 PM
#11 (permalink)
| | dlindemann Rookie
Join Date: Dec 2005 Location: Minnesota, USA GT40: SLC on order!
Rep Power: 3  | Re: Chassis Weight Quote:
... | I for one, can attest to the fact that the RCR chassis is VERY light. I was able to easily lift the rear of one of one with Fran lifting the front - really amazing. If only I could find someone to buy my S1 Esprit.......
Dave L |
08-03-07, 10:16 PM
#12 (permalink)
| | Dlampe Silver Supporter
Join Date: Jun 2006 Location: Centralia IL GT40: RCR GT 40
Rep Power: 9  | Re: Chassis Weight Fran's answer is accurate. My chassis weight is around 307 lbs without the full cage. The cage will add about 45-50 lbs as I remember. I weighed it all. Next question! |
08-04-07, 03:42 AM
#13 (permalink)
| | Andy Sheldon Sponsoring Vendor
Join Date: Oct 2001 Location: England GT40: Tornado TS40
Rep Power: 10  | Re: Chassis Weight Our spaceframe chassis requires minimal panelling.
It requires 2 x 8' X 4' sheets, 1 X 6' X 3' sheet and a floorpan all in 16 gauge to cover the required areas.
The total weight of this material is 105 lbs.
Therefore this amount of material in 1/4" would weigh approx 4 times as much which is 420lbs and there is not enough there to complete a mono chassis by far.
I am looking forward to weighing both of our monos when they are completed.
Which is heaviest. A ton of feathers or a ton of bricks?
Andy |
08-04-07, 05:58 AM
#14 (permalink)
Rep Power: 20   | Re: Chassis Weight Hell, what are we trying to build here?
1/4" plate?
We should be building a nice nimble sportscar  not a great lumbering tank!!
__________________ Russ
Most parts now sourced. Body 80% done. Chassis, rollcage 95% finished. Suspension 70% built. Engine starting to build, and trans in a million pieces. http://www.gt40s.com/forum/gt40-buil...atchbuilt.html |
08-04-07, 08:00 AM
#15 (permalink)
Rep Power: 10  | Re: Chassis Weight Russ
Our 40s are spaceframe based and the lightest cars available at a shade over 2000 lbs.
As a comparison a GTD weighs 2600 to 2700 lbs.
Andy |
08-04-07, 09:26 AM
#16 (permalink)
| | Brian McCarthy Bronze Supporter
Join Date: Nov 2001 Location: Up in the sticks GT40: GTD
Rep Power: 11  | Re: Chassis Weight If things continue to go well up here, we'll "soon" have some comparative data for Tornado, R.F., GTD, an original and a bottoms up scratch built car, that is provided of course the owners which to participate in such a comparison.
Of course we have to scale em without the owners sitting in them:-)
Brian
__________________ ...GTD-40
...LHD-LHS
...302 Roller Block
...R-21
...BRM Pin Drive wheels
...Gulf livery |
08-04-07, 03:18 PM
#17 (permalink)
| | jac mac 10 tenths
Rep Power: 18   | Re: Chassis Weight Mine weighs 273 lb, but I 'know' of another thats lighter still !
Jac Mac |
08-04-07, 04:41 PM
#18 (permalink)
Join Date: Nov 2003 Location: Heathrow, London, UK GT40: Dax 40 Mk1 (Rover3.9EFi)
Rep Power: 17  | Re: Chassis Weight No idea on the DAX chassis weight but at SVA with full tanks it was1150kg
OK with a Rover 3.9EFi and Renaut Box
08-04-07, 06:23 PM
#19 (permalink)
| | wolodymyr Bronze Supporter
Rep Power: 9  | Re: Chassis Weight Based on my partially completed solidworks model of the DAX chassis, the steel spaceframe only is 230lb, one or two small bits to add, so lets say 250. I emphasise that I have yet to check some thicknesses, so the final answer could go up further. I havent added any ally floor pan or other panels yet, so these and tanks etc are not included.
Dave
__________________ DAX 302 Installing Alloy Rad |
08-04-07, 07:09 PM
#20 (permalink)
Rep Power: 20   | Re: Chassis Weight Quote:
Originally Posted by jac mac  | | |
