Old 01-22-08, 09:50 AM   #1 (permalink)
simonjrwinter's Avatar
simonjrwinter
serial GT40 owner
GT40: GTD
Rep Power: 24 simonjrwinter has a spectacular aura about
GTD rear upright conversion
The rear GTD uprights I have, were originally made for drum brakes (see first pic)
I've obtained a rear disc setup from a MK 3 granada and am trying to see about adapting the rear uprights to fit the discs.
After removing the drum assembly, I found a plate with a 70mm hole (approx) welded over the main body of the upright. The main part of the upright has an 82mm hole in it, suitable for the flange on the base of the hub to fit inside. I think I should replace the 5mm steel I removed with a section of plate to re-strengthen the upright and to give the bolts holding the hub in place something to "bite" on. I think however, before I go any further, I should get some "cosworth" hubs, as the "ears" for the calipers, stick out further and mean I won't have to chop away at the fabric of the upright.
All the welding will be done by a competent welder friend of mine who builds chassis and race cars, so if there are any structural issues, he will put me right. I'm just asking if anyone else has converted their hubs and if there's anything else I should take into consideration. Any advice much appreciated.
Simon
GTD with Southern GT rear end. Lowered engine and gearbox. 302, R21T gearbox with LSD.
simonjrwinter is offline
Old 01-22-08, 09:52 AM   #2 (permalink)
simonjrwinter
serial GT40 owner
GT40: GTD
Re: GTD rear upright conversion
More pics
Old 01-22-08, 10:03 AM   #3 (permalink)
simonjrwinter
serial GT40 owner
GT40: GTD
HHMMMMM...........it now seems that I may already have the correct (longer) hub carriers. This may entail some reliefs being cut into the upright!
Old 01-22-08, 11:37 AM   #4 (permalink)
jjs
Rep Power: 2 jjs is on a distinguished road
Cosworth hub "ears" for caliber are only 10 mm longer than Sierra/Scorpio/Granada mk3 ones; is that enough?
You may have noticed that bearing -inside- and outside diameters are not similar between "drumhub" and "dischub"; must use stub and flange (not sure about terms) from Si/Sc/Gr for 100 mm joint or 2wd Cossy for 108 mm joint.
Escort RS Cosworth -93 Motorsport Edition
Sierra RS Cosworth 2D -86 --> RS500
Sierra RS Cosworth 2D -86 GrA ex-works rallycar
jjs is offline
Old 01-22-08, 11:57 AM   #5 (permalink)
Ron Earp's Avatar
Site Administrator
Simon, you've been around here long enough to know this belongs in the suspension section.....
Ron Earp is offline
Old 01-22-08, 11:59 AM   #6 (permalink)
simonjrwinter
serial GT40 owner
GT40: GTD
Red face Re: GTD rear upright conversion
Yes, sorry Ron, just wanted it to get to the widest audience for criticism. Please feel free to move it.
Simon
Old 01-22-08, 04:27 PM   #7 (permalink)
MikeP's Avatar
MikeP
2 Tenths
GT40: GTD
Rep Power: 5 MikeP is on a distinguished road
The last time I was at Southern GT Mick Sollis had some fabricated new uprights for a GTD which use the Mk3 granada /scorpio hubs. Check out with Mick as they would be very much lighter than what you have.
MikeP is offline
Old 01-22-08, 05:21 PM   #8 (permalink)
simonjrwinter
serial GT40 owner
GT40: GTD
Thanks mike,
I'l probably stick with the GTD uprights for the time being.
If anyone has any closeups of Disc braked rear uprights I'd be grateful to see how they differ from drums.
Simon
Old 01-23-08, 02:40 AM   #9 (permalink)
brettmcc's Avatar
brettmcc
GT40: RSGTD
Rep Power: 19 brettmcc is a name known to all
Simon,
Come round and see mine. They are off the car at the moment. You can take all the pics you want. I also have Micks's rear uprights.
Brett
PS Working at home today (Wednesday)
brettmcc is offline
