| Notices | Hi member,
Enjoy the forum!
Why not start with your first post today and become an active part of GT40s.com now! And, if you find you enjoy GT40s.com think about becoming a Forum Supporter. | | GT40 Tech - Chassis,Brakes,Tires,&Wheels Chassis and Handling. |
03-24-08, 03:09 PM
#1 (permalink)
| | simonjrwinter serial GT40 owner
Rep Power: 24  | Hub nut thread? Ok, this may be a stupid question, but which rear driveshaft/hub goes on which side?
I would guess that the R/H threaded driveshaft goes on the right side (drivers side UK) and the L/H threaded driveshaft on the left side. Am I right?
Simon
__________________ GTD with Southern GT rear end. Lowered engine and gearbox. 302, R21T gearbox with LSD. |
03-24-08, 03:14 PM
#2 (permalink)
| | Brian Magee Bronze Supporter
Rep Power: 11  | Re: Hub nut thread? Yes Simon, Green, R/H thread = right (offside), White, L/H thread = left (nearside)
Brian.
__________________ GTD, 289, ZF. |
03-24-08, 03:19 PM
#3 (permalink)
Rep Power: 24  | Re: Hub nut thread? Brian,
Thought so, many thanks.
Simon
03-24-08, 04:34 PM
#4 (permalink)
| | Mike Drew Silver Supporter
Join Date: Feb 2005 Location: Vacaville, CA GT40: (Someday) Super
Rep Power: 6  | Re: Hub nut thread? An easy way to remember this is to remember that the nuts must 'back off'. That is, they are rotated towards the rear of the car to remove them.
__________________ Mike Drew, Vacaville, CA (MikeLDrew@aol.com)
'72 De Tomaso Pantera, '66 Contemporary 427 Cobra, '66 Shelby GT-350 clone, and gearing up for a Superformance Mk 1.... |
03-25-08, 12:27 AM
#5 (permalink)
Rep Power: 20   | Re: Hub nut thread?
__________________ Russ
Most parts now sourced. Body 80% done. Chassis, rollcage 95% finished. Suspension 70% built. Engine starting to build, and trans in a million pieces. http://www.gt40s.com/forum/gt40-buil...atchbuilt.html |
03-25-08, 02:24 AM
#6 (permalink)
| | jac mac 10 tenths
Rep Power: 18   | Re: Hub nut thread? Dont think so, If I am not mistaken they are talking about the nut on the drive flange where the splined axle attaches, Not the 'Knock Off' which You & Mike have so much fun debating. |
03-25-08, 03:21 AM
#7 (permalink)
| | Cliffbeer2 2 Tenths
Rep Power: 4  | Re: Hub nut thread? The question (which hub, RH or LH, goes on which side) logically and necessarily relates to the knock-off spinner because the direction of rotation of the spinner (RH/LH thread) dictates the answer. It's one question with one correct answer... |
03-25-08, 04:23 AM
#8 (permalink)
| | Dimi Lifetime Premier Supporter
Join Date: May 2006 Location: Bondi, Sydney, GT40: DRB Chassis 68
Rep Power: 5  | Re: Hub nut thread? Isn't it amazing how one question can receive many different answers.
Looking at one problem from different angles can give dozens of different answers.
I guess that is what being human is all about.
Dimi
__________________ |
03-25-08, 10:08 AM
#9 (permalink)
Rep Power: 11  | Re: Hub nut thread? Simon
Can I pre-empt your next question. The torque setting for these HUB NUTS is 200 ft lbs.
Brian.
