Old 03-25-08, 05:58 AM   #1 (permalink)
simonjrwinter's Avatar
simonjrwinter
serial GT40 owner
GT40: GTD
Rep Power: 24 simonjrwinter has a spectacular aura about
Disc brake bolts....strength?
On a GTD front hub, I need to attach the disc brakes via five bolts to the hub.
I'm guessing these need to be some sort of "upgraded" bolt rather than just a standard bolt that fits?
Do they need to be hi-tensile or hardened in some way?
As it's a safety critical item, I'd rather get it right.
Simon
GTD with Southern GT rear end. Lowered engine and gearbox. 302, R21T gearbox with LSD.
simonjrwinter is offline
Old 03-25-08, 06:15 AM   #2 (permalink)
Malcolm's Avatar
Malcolm
Gold Supporter
GT40: GTD
Rep Power: 29 Malcolm has a brilliant futureMalcolm has a brilliant futureMalcolm has a brilliant futureMalcolm has a brilliant futureMalcolm has a brilliant future
Re: Disc brake bolts....strength?
Stronger the better in my view. 12.8 bolts should be ok.
Malcolm
GTD40, Prosport 3000 Spyder, Lotus 51c, Mazda MAX5 MX5 (Spec Miata) and Porsche 996 C4S
Malcolm is offline
Old 03-25-08, 04:42 PM   #3 (permalink)
JhnC40
GT40: Tornado
Rep Power: 2 JhnC40 has a spectacular aura about
Hi Simon,
I'm currently upgrading the brakes on my car and fitting Hi Spec 4 pot calipers on the front with vented discs. With the original hub I have used M10 High Tensile (?10.9) and as I needed nuts too, am using M10 aerotight rather than nyloc.
Hope this helps.
John
Tornado TS40
Lotus Europa
Porsche 911 (now sold)
JhnC40 is offline
Old 03-25-08, 05:18 PM   #4 (permalink)
simonjrwinter
serial GT40 owner
GT40: GTD
Managed to get some 12.9 bolt which should do the trick.
Simon
Old 03-25-08, 08:45 PM   #5 (permalink)
MReid's Avatar
MReid
4 Tenths
GT40: RCR Mk1
Rep Power: 6 MReid is just really nice
12.9 is perfect. Don't use nylocks as the rotor heat can melt the nylon.
Have fun with your build! - Mark
FFR Daytona Coupe
RCR Gt40 Mk1 in the garage, and underway!
MReid is offline
