Old 07-03-09, 11:55 AM   #1 (permalink)
aladinsane's Avatar
aladinsane
GT40: Tornado
Caliper Location
I am installing new front suspension components including Wilwood calipers and rotors.
Does it make any difference whether the caliper is mounted forward of the spindle or behind the the spindle, i.e. performance or installation?
Not paying attention, I ordered a set of Wilwood calipers for my front suspension and specified "front" not thinking it means "forward mount". During setup I couldn't understand why my bleed screws were in the wrong location unless the caliper was positioned forward of the spindle. If there is no difference as to where the caliper is mounted then I'll mount it forward but if for any reason there is then I need to return them and order the right part number.
Tornado TS40, Dart Alum 351\427, 8 Stack EFI
G50\52 w\cooler, cable side shift, Halibrand KO, Hoosiers
aladinsane is offline
Old 07-03-09, 12:30 PM   #2 (permalink)
IanAnderson's Avatar
IanAnderson
Gold Supporter
GT40: Dax 40 Mk1 (Rov
Re: Caliper Location
Tim
I asked the same question last year after being stuck in a jam for a few hours and looking at the wheels around my car
Some mounted front, some top and some rear (never saw any on the bottom)
The concensus was it made no difference so long as the steering arms etc could be accommodated
Chera
Isn
DAX GT40. Rover 3.9 EFi, Worked by John Eales.
IanAnderson is offline
Old 07-03-09, 12:48 PM   #3 (permalink)
aladinsane's Avatar
aladinsane
GT40: Tornado
Thanks Ian, good point, I bet your right. The steering arm may be the deciding factor here.
Old 07-03-09, 01:50 PM   #4 (permalink)
wolodymyr's Avatar
wolodymyr
GT40: DAX40
Tim,
when I installed my Wilwoods (radial Mount) I designed and had an adapter made up. Everything was good except that the adapter clashed with the bottom radius arm and limited steering lock a bit. I did some grinding of the adapter to get the lock back and all was ok. Just something for you to consider.
Look for threads started by me to find the ones on brakes if you are interested.
regards
Dave
DAX 302 Seat Belts Installed
wolodymyr is offline
Old 07-03-09, 01:53 PM   #5 (permalink)
jimbo's Avatar
jimbo
Silver Supporter
GT40: Mark VI, #1149
Mine all ended up on the back. But I don't think it makes a difference. Maybe for really serious driving, the calipers would cool off faster if they were in front, in the airstream. But for my level of driving, I don't think it makes a difference, honestly.
Mark I monocoque under construction
Safir Mk I body
ZF-2 transaxle
302 w/Webers
jimbo is offline
Old 07-04-09, 02:07 AM   #6 (permalink)
aladinsane's Avatar
aladinsane
GT40: Tornado
Thanks guys, further review of my current setup reveals what Ian eluded to. The caliper will interfer with the steering arm if mounted forward so I'll send these calipers back to Wilwood and replace with a rear mount setup. Chalk up another learning experience as a DIY'er.
Dave, I read your thread regarding your radial mounts and you did a nice job. I think I would have to "clock" my mount up around 10-11 o'clock to clear the steering arm thus defeating the the ease of bleeding the brakes.
Old 07-04-09, 01:41 PM   #7 (permalink)
Mike Drew's Avatar
Mike Drew
Silver Supporter
GT40: None, yet!
Tim--forgive me if I'm insulting your intelligence. But sometimes the obvious is easy to overlook, and I'd rather suggest something and risk insulting you, then keep silent and let you suffer the consequences.
You didn't specify which calipers you have (other than the brand), which spindles, which system of mounting etc. so I'm making wild guesses here. But the cars I'm most familiar with (Panteras) have 'mirrored' mounting ears for the calipers on both front and rear of each spindle, so that a caliper could theoretically be mounted in either location. (The car uses a single spindle on both sides of the car, with a bolt on 'left' and 'right' steering arm). The only issues are of clearance with the other items, i.e. steering gear etc.
If you can physically mount your calipers in the desirable location on your spindles, but when you do so the bleeder screws are in the wrong place, can you just switch the calipers side-to-side and resolve the issue?
Mike Drew, Vacaville, CA (
'72 De Tomaso Pantera, '66 Contemporary 427 Cobra, '66 Shelby GT-350 clone, and gearing up for a Superformance Mk 1....
Mike Drew is offline
Old 07-04-09, 04:30 PM   #8 (permalink)
jac mac's Avatar
jac mac
I Have No Life
New Zealand
Only if the piston dias are all the same, if the piston dias are staggered..eg 1.875/1.75 then the caliper must remain on the same side of car but bleeders/pipes etc swapped to suit front/rear position--- then it gets messy with Willwoods as pipes are imbedded in silicon to dampen vibration/fracture problems etc.
Jac Mac
jac mac is offline
Old 07-05-09, 03:06 AM   #9 (permalink)
Jim C's Avatar
Jim C
Gold Supporter
GT40: RF 105
I like mounting on the back if I can.
If you plan on brake ducts the air is pumped into the center of the disk as the disk acts as a fan moving the air outwardly not inward,much easier ducting on the front than the rear.
Jim
Occupation Automotive
Interests are
Fabrication and design
Building my car
Sydney Australia
Jim C is offline
Old 07-05-09, 08:18 AM   #10 (permalink)
egoman's Avatar
egoman
Canada
Most brakes are mounted with their mass towards the center of the car to reduce polar moment. I realize that this is a small amount of weight but you take all advantages that you are given. For a race car this would be a no brainer, but for a street car convenience may win out.
egoman is offline
Old 07-05-09, 01:30 PM   #11 (permalink)
aladinsane's Avatar
aladinsane
GT40: Tornado
Mike, feel free to question my intelligence. My girlfriend does so on a daily basis, to the point that I've grown to question myself for every thought through my simple mind .
As Jac Mac correctly points out, I am attempting to fit #6585\6584 6 pot lug mount. They are a multi diameter piston therefore specific to one side or the other. They're mounting on a new set of aluminum uprights provided by Tornado.
Jim C and egoman, good point.
Similar Threads
Wilwood 4 pot handbrake caliper Mudgey GT40 Tech - Chassis,Brakes,Tires,&Wheels 2 09-17-08 10:23 AM
Braake Caliper Placement IanAnderson GT40 Tech - Chassis,Brakes,Tires,&Wheels 20 01-02-08 10:46 PM
Caliper Recognition IanAnderson GT40 Tech - Chassis,Brakes,Tires,&Wheels 11 06-22-06 06:06 PM
Cosworth caliper pictures..anyone? simonjrwinter GT40 Tech - Chassis,Brakes,Tires,&Wheels 4 11-26-04 02:52 AM
Caliper Identification huntsen GT40 Tech - Chassis,Brakes,Tires,&Wheels 7 11-21-03 04:57 AM
