I bought AVO's to replace my Spax. 1 way adjustable.
The minimum clamping length of the AVO is smaller than the Spax. So the ride hight is for the rear too high.
Open close length of avi shocks are:
Front 14' and 9.5'
Rear 15' and 10'
When looking at the length recommendations they say that the ideal spring length should be 9' front and rear? Could not find clear values in the forum to confirm.
For spring rate I learned after reading the forum that
Front 275lb
Rear 350lb
should be OK for road use and occasionally track use? I was wondering what the standard GTD spring values are?
So before fixing the suspensions I wanted some advice from the specialist...
Make these values sense or didn’t I do my homework properly...
THANKS..
Front 14' and 9.5'
Rear 15' and 10'
Front 275lb
Rear 350lb
THANKS..
