Handbrake Caliper
Recently acquired a part built MDA which requires handbrake calipers. The car has cast alloy uprights with GT40 cast on them. There are two threaded holes ready to take a caliper @ 3 1/2” centres. The discs are 20mm wide and have Wilwoods fitted for general braking...
Tried uploading a photo but a message saying security token required!??:sad:
Mark
Hi Mark
Do a search for Brembo handbrake calipers, looks like they were fitted to Jaguar 'S' type & I believe the current Lotus Exige uses them. This is what you want.
Andy
Hi Mark,
This might be what you are looking for.
The non-mounted caliper is mine and that one is off a Ferrari 360. I'm quite sure this is what MDA used for their factory builds...
Cheers,
Mattias
Hi Mark,
Mick at Southern GT was selling them, apparently they virtually the only ones that will get a 40 through IVA and even they are marginal.
