Go Back   GT40s.com > >
Thread Tools Display Modes
Old 9th June 2018, 03:19 PM   #1
johnny cobra's Avatar
johnny cobra
4 Tenths
GT40: Tornado GT 40.
Vacuum pumps.
Hi all I am looking at fitting a pump to my servos . Mine just don't feel like they are working properly . Have to press pedal quite hard . My question is has any body fitted an electric servo pump and any for or against ..
Thanks all .. John.
Tornado 40 330 BHP IVA passed ........
johnny cobra is offline   Reply With Quote
Old 9th June 2018, 04:43 PM   #2
Larry L.
GT40: none. YET.
Re: Vacuum pumps.
I've now installed about 4 different electric auxiliary vac pumps (various brands)...'am now trying to get my 5 FIFTH ONE to work...and NONE to date have worked as they should OR worked in one fashion or another for any longer than an hour-or-so running time.
If you find one that actually WORKS AS ADVERTISED and works for longer than an hour or two of running time - PLEASE let me know!
Larry L. is offline   Reply With Quote
Old 10th June 2018, 04:00 AM   #3
johnny cobra
4 Tenths
Re: Vacuum pumps.
Hi Larry … Im looking at a pump from a Citroen berlingo van. It must work on them . Take a look on Ebay that is were I have seen it ..
Old 10th June 2018, 05:03 AM   #4
Larry L.
GT40: none. YET.
Re: Vacuum pumps.
Copy that. 'Will do...
Edit:
Is this it?
FOR CITROEN BERLINGO C15 DISPATCH XSARA 1.9D 1998 > NEW BRAKE VACUUM PUMP | eBay
Old 10th June 2018, 05:17 AM   #5
johnny cobra
4 Tenths
Re: Vacuum pumps.
The one I am looking at is electric . That one runs of the cam end I think Larry m8 .
John
Old 10th June 2018, 05:23 AM   #6
Larry L.
GT40: none. YET.
Re: Vacuum pumps.
That's the only one I saw.
'Will now do what I should have done in the 1st place: insert the word "electric"!
Edit: no luck there either...'will tackle it after DAWN!
Old 10th June 2018, 05:38 AM   #7
johnny cobra
4 Tenths
Re: Vacuum pumps.
Edit: no luck their either...'will tackle it after DAWN!
LOL go for it .
Old 10th June 2018, 05:39 AM   #8
johnny cobra
4 Tenths
Re: Vacuum pumps.
Bosch vacuum pump ..
Old 10th June 2018, 10:23 AM   #9
johnny cobra
4 Tenths
Re: Vacuum pumps.
Larry Take a look on Car builder Solutions they have a full kit . I have just seen it ..
Old 10th June 2018, 02:42 PM   #10
Hendrickx Paul's Avatar
Hendrickx Paul
Silver Supporter
France
GT40: RED KVA MKIII
Re: Vacuum pumps.
hello, other decent solution is to find the combination of alternator/vacuum pump which can be find onthe nissan petrol diesel 4x4 some mutshibusi diesel engine equipped 4x4
thats the way i'm going in my build
as example:MITSUBISHI L200 2.5 4D56 TD DIESEL BRAND NEW ALTERNATOR + VAC PUMP 1998-2006 | eBay
hope this could help
Paul
Vacuum pumps.-alternator-vauum-pump-mitsubshi-gt40-jpg
Only Robinson crusoe got things done by Friday
Hendrickx Paul is offline   Reply With Quote
Old 11th June 2018, 01:34 AM   #11
Brian Kissel
Re: Vacuum pumps.
Larry,
Here is one on this side of the pond.
New Alternator Fits Mitsubishi 1986-13 Pajero Shogun L200 L300 Montero Delica | eBay
or, what about one of the manual style, off a 5.7 olds diesel ?
If you are not living on the edge, you are taking up too much space !!!!
Brian Kissel is offline   Reply With Quote
Old 11th June 2018, 06:47 AM   #12
Larry L.
GT40: none. YET.
Re: Vacuum pumps.
The one that popped up is below. Oddly enough it appears to be the exact one I presently have and 'am trouble shooting! Currently, I'm awaiting a replacement relay for it.
Electric Vacuum Pump
Item No. VACPUMP
222.00 incl VAT
12 volts
Old 11th June 2018, 06:55 AM   #13
Larry L.
GT40: none. YET.
Re: Vacuum pumps.
Paul
Originally Posted by Brian Kissel View Post
Larry,
'Will check these out...but, 'would prefer to use a 'stand alone' unit such as the one above - if I can find one that actually works.
Old 11th June 2018, 10:43 AM   #14
JP Verweij's Avatar
JP Verweij
Netherlands
GT40: KVA mk2
Re: Vacuum pumps.
I normaly use the Hella UP28 for this aplication which works great.
The Hella UP 28 pulls 25inHg ( I measured that).
Bit of searching on eBay normaly found for around $100.-
Volvo's have them.
Hooked these up to the brakelight switch so when hitting the brake the pump starts sucking.
I Have converted two cars allready who drive for years now.
JP Verweij is offline   Reply With Quote
Old 11th June 2018, 11:22 AM   #15
Mark IV's Avatar
Mark IV
I Have No Life
GT40: Superformance
Re: Vacuum pumps.
I have seen this unit as I have a former employee who works for the company: Electric Vacuum Pump Kits | Vacuum Pump Parts and Accessories
If you inquire ask for Greg and tell him I sent you.
The GT 40 reunion at the Glen in 1989 was as close to Heaven as I'll get...
Mark IV is offline   Reply With Quote
Old 11th June 2018, 04:29 PM   #16
Larry L.
GT40: none. YET.
Re: Vacuum pumps.
Thanks, Rick. 'Appreciate it.
I'll wait 'til I see if the replacement relay does the trick. If it doesn't, I'll give him a call and see if he can shed some light on things.
According to the 'meter, the stinkin' relay has to be the fly in the ointment.
Old 14th June 2018, 11:35 AM   #17
johnny cobra
4 Tenths
Re: Vacuum pumps.
I have just fitted a UP 28 pump .. makes a world of difference … LARRY …
Old 14th June 2018, 07:19 PM   #18
Larry L.
GT40: none. YET.
Re: Vacuum pumps.
'Replacement relay still not here...so, I don't know what I'll end up doing/getting.
Do you know what the 'start up/shut off range' is on the UP 28? I'm looking for something that provides 15 inches-or-so 'on' / 25 inches-or-so 'off'...
Old 15th June 2018, 01:44 AM   #19
johnny cobra
4 Tenths
Re: Vacuum pumps.
Im told its 25inches m8 ...
Old 15th June 2018, 09:51 AM   #20
Larry L.
GT40: none. YET.
Re: Vacuum pumps.
Copy that. 'Will keep the '28 in mind, sir.
Tags
body, john, pedal, pump, question
Forum Jump
