| Re: from french newbie kva help Since KVA was the first and most, if not all, of the kits evolved from it, I would have to guess that the body could be put on either a GTD or Tornado chassis. You might want to check with Andy Sheldon at Tornado to get his opinion.
I am kind of surprised that some of the GTD guys haven't chimed in on this. My guess is that if any modifications would be needed, it would be to the body itself. Fibreglass requires less specialized equipment to work with than a steel chassis and I suspect the cutting and welding is what you are hesitating about.
Lynn
