| Notices | Hi member,
Enjoy the forum!
07-21-03, 06:55 PM
#1 (permalink)
| | Paul Bearman 4 Tenths
Join Date: Oct 2001 Location: UK, Kent GT40: Ex GTD40 owner,
Rep Power: 12  | 12V Air compressor Can anyone reccomend a small/lightweight air compressor that will run on 12V. I have done a quick search of my local suppliers but no success.
The unit needs to produce around 15-20psi.
Regards, Paul. |
07-21-03, 09:20 PM
#2 (permalink)
Rep Power: 6  | Re: 12V Air compressor Both KAB and Isringhausen make small compact air compressors to inflate the air bag in operator seats used in trucks and machinery.I do not know about Isri but KAB use it in their 55 model air seat.You might try some of the wreckers first.Compressor will inflate to 120psi if required.Regards |
07-21-03, 11:13 PM
#3 (permalink)
| | 3 Tenths
Rep Power: 11  | Re: 12V Air compressor The Mercedes SLK has a small compressor as standard to blow up the spare if required. This may be a line of enquiry. Regards |
07-22-03, 02:40 PM
#4 (permalink)
| | David Morton Lifetime Premier Supporter
Join Date: Nov 2002 Location: Marlow, England GT40: The Jewel on th
| Re: 12V Air compressor Paul,
There are all sorts of things here in Italy but do you know what cubic feet per minute you need and what's it's purpose to give some sort of clue. I use 12v compressors to put up 12m masts on my equipment and they are supplied by Clark Mast Teksam Ltd. in the Isle of Wight, but they are rather heavy with all sorts of safety cutouts and controls etc.
Dave |
07-24-03, 02:22 PM
#5 (permalink)
Rep Power: 12  | Re: 12V Air compressor Dave,
I am looking into the possibility of a pneumatic gearchange system. The development is still in it's early stages & may or may not be a viable option. I'll let you guys know how we get on. |
07-24-03, 04:04 PM
#6 (permalink)
| Re: 12V Air compressor Paul, That would be amazing but ... surely it would need reasonably high pressure to use small enough rams to be effective. Hydraulic and/or wire control using selsyn/desyn was a consideration on mine but then discounted in favour of a remarkeable series of levers and rod ends operating a single shaft.
regards
Dave M |
07-24-03, 05:55 PM
#7 (permalink)
| | p thompson Administrator
Join Date: Aug 2002 Location: Milland, West S GT40: None
| Re: 12V Air compressor Hi Paul,
Roy and I have toyed with such an idea, to the point of identifying suitable cylinder rams. They can be sourced from as little as 10mm bore of varying stroke. We considered using a bottle of compressed gas for mobile testing purposes and a diving bottle for bench testing. (both suitably regulated to say about 8 bar) The small disposable mig bottles you can get can provide 100psi+ and could possibly be the basis of a resevoir topped by a small electric compressor.
When we went to SPA a couple of years ago, we came across a caterham or similar that was indeed fitted with a pneumatic shifter (USA sourced) that was contolled by a small box of electronics via two push buttons on the steering wheel. The system was all the more useful for the driver to whom we spoke with, as he had unfortunately lost an arm in a previous accident (motorcycle?). EauRouge in a 40 was great but with only one hand on about a 10" steering wheel - very brave!!
Good luck Paul and keep us posted.
(ps - keypad is being posted tomorrow - sorry for delay) |
07-24-03, 10:57 PM
#8 (permalink)
| | CCX33911 10 tenths
Rep Power: 19  | Re: 12V Air compressor How about doing it with hydraulics and using a OEM ABS pump and some sort of solenoid valves? |
