Old 08-20-03, 02:41 AM   #1 (permalink)
dazzle
GT40: Blaine, WA, USA
Rep Power: 7 dazzle is on a distinguished road
AN versus JIC Fittings
I am currently working on the fuel system. I plan to put a good portion of it "below deck" - inside the right rear part of the chassis. I have been searching for the requisite AN fittings and came across JIC 37degree fittings that appear to be the same as the AN ones only in steel and brass instead of anodized aluminum. As much of this will be below deck has anyone had experiences with mix/match of these two types of fittings. The only minor difference I can find is in the 2A vs. 3A thread.
It would save a bunch of money - as long as they work?
dazzle is offline
Old 08-20-03, 09:16 PM   #2 (permalink)
patbarry's Avatar
Gold Supporter
GT40: Houston, Texas
Re: AN versus JIC Fittings
If I'm not mistaken, AN are 37 degree also. But perhaps you already knew that. I think I have a reference book around here somewhere...
patbarry is offline
Old 08-20-03, 10:00 PM   #3 (permalink)
patbarry's Avatar
Gold Supporter
I found the aeroquip catalog on the web http://www.aeroquip.com/media/A-SPPE-MC0001-E.pdf (can't figure out how to make it link). On page 6 they list some of the fittings as "JIC/SAE/AN". Now, I know JIC and SAE are the same, just different terminology, so I guess this means that they are all the same. Or maybe I'm just reading it wrong, but I don't think so.
patbarry is offline
Old 08-20-03, 10:59 PM   #4 (permalink)
CCX33911
GT40: Virginia
Rep Power: 20 CCX33911 is on a distinguished road
I know that SAE is 45 deg, and AN is 37 deg. Not sure about JIC.
CCX33911 is offline
Old 08-21-03, 02:44 AM   #5 (permalink)
DC
DC's Avatar
4 Tenths
GT40: Hertfordshire, UK
Rep Power: 11 DC is just really nice
Quote from my supplier's product manual:
"SAE 37deg, formally known as JIC and sometimes called AN (Air Force/Navy) is an American Thread and almost universal for performance appplications. SAE straight is often called UNF, this and SAE 45deg, used in airconditioning applications, share the same thread dimensions as SAE 37deg, except -12 SAE 45deg which is 14 tpi"
So it appears AN and JIC are the same but SAE comes in various flavours. Hope this helps.
I have mixed nickel plated steel and anodised ally on a air bleed, you must oil the joints to stop welding them when you tighten. I dont think there's a performance difference just a weight penalty.
DC is offline
Old 08-21-03, 08:56 PM   #6 (permalink)
patbarry's Avatar
Gold Supporter
Well I was wrong - the link I listed above does work. I think everyone is right when it comes to defining the fittings, myself, Dave and Gary, you just gotta be specific when you order.
patbarry is offline
Old 08-26-03, 01:21 AM   #7 (permalink)
40bud's Avatar
40bud
7 Tenths
GT40: GTD Finished in
Rep Power: 15 40bud is on a distinguished road
Timely discussion! I am in the process of converting part of my system to hard lines. How to I connect the hard line to the AN 37 degree? All the flaring tools seem to be 45 degre.
40bud is offline
Old 08-26-03, 02:23 PM   #8 (permalink)
MikeDD's Avatar
MikeDD
GT40: DRB
Check Summit or Jeg's...I seem to recall Earls and others offer AN adapter fittings.
MikeD
MikeDD is offline
Old 08-26-03, 05:48 PM   #9 (permalink)
Rep Power: 6 andy1 is on a distinguished road
If this is for a braking system (though it wouldn't have to be), try http://www.inlinetube.com/ They list a flare (SAE) to AN adapter, 3/16" or 1/4" to -3 AN.
Andy
[ QUOTE ]
[/ QUOTE ]
andy1 is offline
Old 08-26-03, 06:11 PM   #10 (permalink)
I forgot to mention, Inline Tube also offers a 37 degree flaring tool. Read the info on their site with regard to what is used where and with what fittings.
Andy
andy1 is offline
Old 08-26-03, 08:57 PM   #11 (permalink)
CCX33911
GT40: Virginia
Take a look at Carroll Smiths book Nuts, Bolts and plumbing handbook.
http://www.amazon.com/exec/obidos/tg...glance&s=books
CCX33911 is offline
Old 08-26-03, 10:49 PM   #12 (permalink)
patbarry's Avatar
Gold Supporter
I bought my 37 degree flaring tool from Harbor Freight for about $140. After reading Carroll's book (good comment Gary), I simply could not see myself trying to make a 45 flare fit a 37 fitting. And that's all I got to say about that.
patbarry is offline
Old 08-27-03, 08:05 PM   #13 (permalink)
40bud's Avatar
40bud
7 Tenths
Thanks Andy. I will order tomorrow.
40bud is offline
Old 08-27-03, 10:15 PM   #14 (permalink)
CCX33911
GT40: Virginia
www.speedwaymotors.com sells a 37 degree tool (which appears to be the Imperial) for $54.00 I have used my Imperial with great success.
37 Degree Flare Tool
CCX33911 is offline
Old 08-28-03, 02:34 AM   #15 (permalink)
40bud's Avatar
40bud
7 Tenths
Thanks Gary, you just saved me about $40. I figure using as much hard line as possible should eliminate most problems with MTBE, alcohol, racing fuels etc. All I should need is a short length of that expensive super hose from the regulator to the carb.
40bud is offline
