| Re: zf transaxle or porsche 930? Javla
The reason that you have limited space with the corvair transaxle is that years ago there was a kit that made it possible to use that gearbox, but it included a new front bearing retainer and input shaft, these were mounted to the opposite side of the gearbox...essentially it was turned around...the problem here was that the axle centerline was moved further back necessitating a forward mounting of the motor, they worked ok but it is a 4 speed, and cast iron..seriously heavy in my opinion. If you decide on the G50 box keep in mind that the ring gear can't be flipped in this gearbox, so the whole box must be inverted, Kennedy makes an adapter to do this, using a porsche clutch, and this box is really strong, but when inverted the axle centerline is about 5" higher and unless you lower the motor substanstailly you can have some really steep angles on the cv joints. You should be able to get a G50 box much cheaper than the ZF, but the changes involved may make the ZF a lot easier to deal with
Phil |
